SDL2/SDL3 Drop event problem
Hi,
I’m facing a subtle but nontheless annoying issue with the current SDL2/SDL3 libraries and maybe someone can give me a hint if either I’m doing something wrong or if this is a bug in the library.
Problem: Drag and Drop to the SDL window does not work.
For demonstration purposes, I wrote the following minimum demo:
#include <stdio.h>
#include <SDL3/SDL.h>
typedef unsigned char boolean;
#define TRUE (1)
#define FALSE (0)
int main(int argc, char **argv)
	SDL_Window *window=NULL;
	SDL_Event event;
	boolean quit=FALSE;
	SDL_Init(SDL_INIT_VIDEO);
	window=SDL_CreateWindow("Drop Test",640,480,0);
	while(!quit)
		while(SDL_PollEvent(&event))
			switch(event.type)
				case SDL_EVENT_QUIT:
					quit=TRUE;
					break;
				case SDL_EVENT_DROP_BEGIN:
					fprintf(stdout,"event: DROP_BEGIN\n");
					break;
				case SDL_EVENT_DROP_FILE:
					fprintf(stdout,"event: DROP_FILE\n");
					break;
				case SDL_EVENT_DROP_TEXT:
					fprintf(stdout,"event: DROP_TEXT\n");
					break;
				case SDL_EVENT_DROP_COMPLETE:
					fprintf(stdout,"event: DROP_COMPLETE\n");
					break;
				case SDL_EVENT_DROP_POSITION:
					fprintf(stdout,"event: DROP_POSITION\n");
					break;
				default:
					break;
	return 0;
As soon as something is dropped on the window, no event is created but the following error message is spit out in the Terminal:
BHandler w>Drop Test: MessageReceived() couldn't understand the message:
BMessage('DATA') {
        src_window = (type = 'PNTR')(size = 8)
        click_pt = BPoint(x:994.000000, y:43.000000)
        TrackerViewToken = (type = 'MSNG')(size = 24)
        refs = entry_ref(device=3, directory=1572870, name="notes.txt", path="/boot/home/Desktop/notes.txt")
        buttons = int32(0x1 or 1)
        _drop_point_ = BPoint(x:639.000000, y:385.000000)
        _drop_offset_ = BPoint(x:31.125000, y:15.750000)
It does not matter if I use SDL2 or SDL3, it’s the same behavior.
Any ideas?
With kind regards,
Egon
hi egrath,
iirc this is a problem with the actual Haiku port implementation of sdl2, it has to learn to handle this.
The error message comes from the BView/BWindow form the sdl side where it prints messages it does not handle iirc.
I might take a look at this tommorow, but can’t upstream because of github so might share a patch here if I have time for it.
This sounds great if you may have a patch for it! Would vastly improve the project I’m currently working on (getting Mini vMac in shape for inclusion in the Depot)
I recently got commit access to SDL repository. So let me know if you have a patch, I’ll send it their way.
Hi, sorry I did not have time to look at this since my pc kind of broke :slight_smile:
