Thank for your Help your tricks work fine.
Watch:
I’m a beginner in C++ and OpenGL.
I have done one think I don’t really understand in the code.
it this line…
virtual void MouseMoved(BPoint Coord,uint32 intoView,const BMessage * msg2);
That seem to be un function declaration but the preset is “virtual” and after void…I don’t really understand what is doing this virtual.
I put this line in the code under a Class with public functions.(I guess very not sure)…I have copied the prototype of the line above it to do it.
class SampleGLView : public BGLView
public:
SampleGLView(BRect frame, uint32 type);
virtual void AttachedToWindow(void);
virtual void FrameResized(float newWidth, float newHeight);
virtual void MessageReceived(BMessage * msg);
virtual void KeyDown(const char* bytes, int32 numBytes);
void Render(void);
after the core of the function…
void SampleGLView::MouseMoved(BPoint Coord,uint32 intoView,const BMessage * msg2)
//Teste si la souris bouge dans la fenêtre ou pas.
if(intoView==1)
cout<<"Vous etes dans la fenetre\n";
cout<<"X:"<<Coord.x<<"| Y:"<<Coord.y<<"\n";
else
cout<<"Vous etes hors de la fenetre\n";
And that work perfectly. (Display the Coordinate of the mouse when we are inside the Window). I have just erase too the lines about DirectConnected and the cursor is Ok now. (–>the transparancy work well).
But I don’t understand why I don’t must to push the include file “View.h” in the code for it work. MouseMoved and KeyDown seem to be function from that include. But the app work nice now so.
Full code:
// sample BGLView app from the Be Book, modified to stress direct mode support.
#include <stdio.h>
#include <Application.h>
#include <DirectWindow.h>
#include <CheckBox.h>
#include <GLView.h>
#include <GL/glu.h>
#include <iostream>
using namespace std;
#define REDRAW_MSG 'rdrw'
public:
void Render(void);
private:
void gInit(void);
void gDraw(float rotation = 0);
void gReshape(int width, int height);
float width;
float height;
float rotate;
class SampleGLWindow : public BDirectWindow
public:
SampleGLWindow(BRect frame, uint32 type);
~SampleGLWindow();
virtual bool QuitRequested();
// virtual void DirectConnected( direct_buffer_info *info );
private:
SampleGLView *theView;
BMessageRunner *updateRunner;
class SampleGLApp : public BApplication
public:
SampleGLApp();
private:
SampleGLWindow *theWindow;
SampleGLApp::SampleGLApp()
: BApplication("application/x-vnd.Haiku-GLDirectMode")
BRect windowRect;
uint32 type = BGL_RGB|BGL_DOUBLE|BGL_DEPTH;
windowRect.Set(50, 50, 350, 350);
theWindow = new SampleGLWindow(windowRect, type);
SampleGLWindow::SampleGLWindow(BRect frame, uint32 type)
: BDirectWindow(frame, "GLDirectMode", B_TITLED_WINDOW, 0)
float minWidth = 0.0f;
float maxWidth = 0.0f;
float minHeight = 0.0f;
float maxHeight = 0.0f;
GetSizeLimits(&minWidth, &maxWidth, &minHeight, &maxHeight);
SetSizeLimits(50.0f, maxWidth, 50.0f, maxHeight);
BRect r = Bounds();
r.InsetBy(10, 10);
theView = new SampleGLView(r, type);
AddChild(theView);
Show();
updateRunner = new BMessageRunner(BMessenger(theView),
new BMessage(REDRAW_MSG), 1000000/60 /* 60 fps */);
theView->Render();
SampleGLWindow::~SampleGLWindow()
delete updateRunner;
bool SampleGLWindow::QuitRequested()
theView->EnableDirectMode(false);
be_app->PostMessage(B_QUIT_REQUESTED);
return true;
/*void SampleGLWindow::DirectConnected(direct_buffer_info *info)
theView->DirectConnected(info);
theView->EnableDirectMode(true);
SampleGLView::SampleGLView(BRect frame, uint32 type)
: BGLView(frame, "SampleGLView", B_FOLLOW_ALL_SIDES, 0, type), rotate(0)
width = frame.right-frame.left;
height = frame.bottom-frame.top;
void SampleGLView::AttachedToWindow(void)
BGLView::AttachedToWindow();
LockGL();
gInit();
gReshape(width, height);
UnlockGL();
MakeFocus();
void SampleGLView::FrameResized(float newWidth, float newHeight)
BGLView::FrameResized(newWidth, newHeight);
LockGL();
width = newWidth;
height = newHeight;
gReshape(width,height);
UnlockGL();
Render();
void SampleGLView::gInit(void)
glClearColor(0.0, 0.0, 0.0, 0.0);
glEnable(GL_DEPTH_TEST);
glDepthMask(GL_TRUE);
void SampleGLView::gDraw(float rotation)
/* Clear the buffer, clear the matrix */
glClear (GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT);
glLoadIdentity();
/* A step backward, then spin the cube */
glTranslatef(0, 0, -5);
glRotatef(rotation, 0, 0, 1);
glRotatef(rotation, 1, 0.6, 0);
/* We tell we want to draw quads */
glBegin (GL_QUADS);
/* Every four calls to glVertex, a quad is drawn */
glColor3f (0, 0, 0);
glVertex3f (-1, -1, -1);
glColor3f (0, 0, 1);
glVertex3f (-1, -1, 1);
glColor3f (0, 1, 1);
glVertex3f (-1, 1, 1);
glColor3f (0, 1, 0);
glVertex3f (-1, 1, -1);
glColor3f (1, 0, 0);
glVertex3f ( 1, -1, -1);
glColor3f (1, 0, 1);
glVertex3f ( 1, -1, 1);
glColor3f (1, 1, 1);
glVertex3f ( 1, 1, 1);
glColor3f (1, 1, 0);
glVertex3f ( 1, 1, -1);
/* No more quads */
glEnd ();
/* End */
glFlush ();
void SampleGLView::gReshape(int width, int height)
glViewport(0, 0, width, height);
if (height) { // Avoid Divide By Zero error...
glMatrixMode(GL_PROJECTION);
glLoadIdentity();
gluPerspective(45, width / (float) height, 1, 500);
glMatrixMode(GL_MODELVIEW);
void SampleGLView::MessageReceived(BMessage * msg)
switch (msg->what) {
case REDRAW_MSG:
Render();
/* Rotate a bit more */
rotate++;
break;
default:
BGLView::MessageReceived(msg);
void SampleGLView::KeyDown(const char *bytes, int32 numBytes)
static bool moved = false;
switch (bytes[0]) {
//Si on appuye sur Espace on sswitch et on déplace le champ d'OpenGL
case B_SPACE:
if (moved) {
MoveBy(-30, -30);
moved = false;
} else {
MoveBy(30, 30);
moved = true;
break;
default:
BView::KeyDown(bytes, numBytes);
break;
if(intoView==1)
else
int main(int argc, char *argv[])
int y=0,x=0;
SampleGLApp *app = new SampleGLApp;
app->Run();
delete app;
return 0;
void SampleGLView::Render(void) {
LockGL();
gDraw(rotate);
SwapBuffers();
UnlockGL();
For view the Coordinate you must run the app from a terminal.
Thank
