Are there a working SD card reader (PC installation)?
example
If it is internally connected trough USB then it should work.
Just to satisfy my curiosity I plugged in a Belkin Universal Media Reader F4U003 that my dad must have bought almost ten years ago. It works. They are still available on ebay from time to time and probably elsewhere
The other ones (connected through pci) should also work but the driver was only tested on a single machine I think. I will complete the driver on my new laptop soon and hopefully it will fix issues for other people too
So far I haven’t had a working card reader. How can I help with driver development? Syslog or other info? Send to you or in the bug tracker?
In the bugtracker, otherwise it will just get lost in my mailbox.
But first I want to get it working on my own computer. It’s hard to debug things remotely with just syslogs.
My laptop has one, I use it to write to SD cards for homebrew on the wii, it works fine.
