so i installed the package screenkeyboard. instantly an onscreen keyboard appeared and i couldnt use the deskbar at all or disable it. so i uninstalled the programme from terminal. the programme is still here, even after rebooting. help me
update : i managed to open haikudepot directly from the terminal and uninstall it. if you ever run into this problem press ctrl+alt+del and select open terminal. then go to /boot/system/apps and type HaikuDepot and from there you can uninstall it
i cant share an image of it, it crashes webpositive
I assume you couldn’t use Deskbar, because you have it as bar at the screen bottom and the screenkeyboard obscures it. Weird though that the screenkeyboard persists when you’ve uninstalled it from Terminal. For me it disappeared as soon as I confirmed “pkgman uninstall screenkeyboard” in Terminal. For you it didn’t even after a reboot. Maybe you accidentally canceled the uninstall and didn’t realize it?
Anyway. You could also right-click the Desktop and navigate to /system/preferences and open the Deskbar prefs to change it’s location so it’s no longer obscured. Or to /system/apps/HaikuDepot to uninstall the screenkeyboard. Or right-click the Desktop and choose “Open Terminal” from the addons.
thanks, i already uninstalled it from haikudepot
