Screen reader
A friend of mine is interesting in checking out Haiku, however they need a screen reader. Does a screen reader exist for Haiku or are there any ongoing efforts towards making one?
There is no support for that builtin in Haiku, and AFAIK I don’t think there is a third party screen reader support either.
I really hope someone will jump and state I’m wrong.
i have heard of lynx browser having screenreader support
is your friend fully blind or just visually impaired? if so then setting high contrast colours and changing the
text size is possible in haiku and can help
All I know is that they’re blind enough to need a systemwide screen reader.
you might be out of luck then. ask others for help
The question was not about lynx. What did your messages here add? You comment on many topics with replies that don’t really add much.. please don’t respond just to add noise to discussions…
For a screen reader to be useful, you need a text to speech engine that will work with most languages and resources that are going with. That part is almost covered by recent additions for LTR languages. RTL and complex scripts languages will be a problem as they are for text rendering.
For the reader part, there’s nothing yet. I guess that due to Haiku specific features, it will also be difficult to borrow an existing software from a linux or a bsd distro. At least, it will need to be adapted and certainly few parts of the system will need adjustment. Just reading doesn’t work. Some things are needing a description like window interacting with each others.
That won’t be an easy task and, before that, Haiku needs LTR and complex scripts rendering.
So, it will take quite some time before Haiku get ready for this.
I already once thought about doing something like that as a gsoc thing. The speech engine I would’ve picked would probably be flite. I think that a bigger problem would be getting that data. You’d need to get data from BViews (and also when to get that data from BViews, when to read the text of a BView). You’d also need to be aware of non-native applications that don’t rely on the Be/Haiku API. Also, I think that keyboard-only navigation would need to be greatly improved in order to be usable without a screen
But maybe I’m thinking that things are harder than they actually are. Problem for me is that I only partially know the requirements a screenreader has to fulfill. I could perhaps ask a friend of mine about this
