Scaling factor or dpi, is it not changable?
One of the PCs I use Haiku beta 5 on is a old netbook with a low-res screen. Some content like webpages don’t look well because of it. Is there no way to reduce the scaling? MX Linux at least has this feature and does it on this netbook quite well and making more things fit on screen.
Screen setting does have dpi written there but there is no option for changing.
Reduce the font size, most UI elements will reduce with it after you restart applications.
DPI means “dots per inch” it’s a property of the screen, not a setting.
For webpositive you can use increase and decreasize size in the menu.
