I want to port RVGL (Revolt) and the python script works good. Then there was a bash which use ldconfig.
ldconfig doesn’t exists under Haiku. Is there a possibility to work around?
It is not even open source.
I have the original game from Windows.
But the question was, is there a replacement for ldconfig?
It can be that other programs (not this game) use also ldconfig.
Put your libs in the correct place, for example in $libDir or into a directory called “lib” beside the executable.
Thank you, i will try.
if you only need to change the place it looks for libs check the en var LIBRARY_PATH, it includes the before mentioned lib/ by default which should be sufficient for most cases.
To make it clear: libraries and binaries are not interchangeable between platforms, so do not expect the linux binaries will somehow magically start work on Haiku even if you put them into a specific folder. They just wont.
ldconfig is used in linux to build a mapping of library sonames to filenames and paths. In Haiku, we don’t have such a mechanism, so:
If ldconfig is run in your script with no arguments, it is likely that you can simply remove it or comment it out.
Thank you for your answers.
I see today that the game works under 32Bit on Ubuntu 20. Not under 64Bit. So i closed my investigation. And a port to haiku make no sence (different issue)
regards lorglas
