I was wondering if anybody here had experience running BeOS in Bochs. I have my current setup:
# You may now use double quotes around pathnames, in case
# your pathname includes spaces.
# CONFIG_INTERFACE
# The configuration interface is a series of menus or dialog boxes that
# allows you to change all the settings that control Bochs's behavior.
# There are two choices of configuration interface: a text mode version
# called "textconfig" and a graphical version called "wx". The text
# mode version uses stdin/stdout and is always compiled in. The graphical
# version is only available when you use "--with-wx" on the configure
# command. If you do not write a config_interface line, Bochs will
# choose a default for you.
# NOTE: if you use the "wx" configuration interface, you must also use
# the "wx" display library.
#config_interface: textconfig
#config_interface: wx
# DISPLAY_LIBRARY
# The display library is the code that displays the Bochs VGA screen. Bochs
# has a selection of about 10 different display library implementations for
# different platforms. If you run configure with multiple --with-* options,
# the display_library command lets you choose which one you want to run with.
# If you do not write a display_library line, Bochs will choose a default for
# you.
# The choices are:
# x use X windows interface, cross platform
# win32 use native win32 libraries
# carbon use Carbon library (for MacOS X)
# beos use native BeOS libraries
# macintosh use MacOS pre-10
# amigaos use native AmigaOS libraries
# sdl use SDL library, cross platform
# svga use SVGALIB library for Linux, allows graphics without X11
# term text only, uses curses/ncurses library, cross platform
# rfb provides an interface to AT&T's VNC viewer, cross platform
# wx use wxWindows library, cross platform
# nogui no display at all
#display_library: amigaos
#display_library: beos
#display_library: carbon
#display_library: macintosh
#display_library: nogui
#display_library: rfb
#display_library: sdl
#display_library: term
#display_library: win32
#display_library: wx
#display_library: x
# ROMIMAGE:
# You now need to load a ROM BIOS into F0000-FFFFF. Normally, you can
# use a precompiled BIOS in the bios/ directory of the source tree,
# named BIOS-bochs-latest.
# You can also use the environment variable $BXSHARE to specify the
# location of the BIOS.
romimage: file=$BXSHARE/BIOS-bochs-latest, address=0xf0000
#romimage: file=bios/BIOS-bochs-2-processors, address=0xf0000
#romimage: file=bios/BIOS-bochs-4-processors, address=0xf0000
#romimage: file=bios/rombios.bin, address=0xf0000
# MEGS
# set this to the default number of Megabytes of memory you want
# to emulate. You may also pass the '-megs xyz' option to bochs
# The default is 32MB, most OS's won't need more than that.
#megs: 256
megs: 128
#megs: 64
#megs: 32
#megs: 16
#megs: 8
# OPTROMIMAGE[1-4]:
# You may now load up to 4 optional ROM images. Be sure to use a
# read-only area, typically between C8000 and EFFFF. These optional
# ROM images should not overwrite the rombios (located at
# F0000-FFFFF) and the videobios (located at C0000-C7FFF).
# Those ROM images will be initialized by the bios if they contain
# the right signature (0x55AA).
# It can also be a convenient way to upload some arbitary code/data
# in the simulation, that can be retrieved by the boot loader
#optromimage1: file=optionalrom.bin, address=0xd0000
#optromimage2: file=optionalrom.bin, address=0xd1000
#optromimage3: file=optionalrom.bin, address=0xd2000
#optromimage4: file=optionalrom.bin, address=0xd3000
# VGAROMIMAGE
# You now need to load a VGA ROM BIOS into C0000.
#vgaromimage: bios/VGABIOS-lgpl-latest
#vgaromimage: bios/VGABIOS-elpin-2.40
vgaromimage: $BXSHARE/VGABIOS-elpin-2.40
# FLOPPYA:
# Point this to pathname of floppy image file or device
# This should be of a bootable floppy(image/device) if you're
# booting from 'a'.
# You can set the initial status of the media to 'ejected' or 'inserted'.
# floppya: 2_88=path, status=ejected (2.88M 3.5" floppy)
# floppya: 1_44=path, status=inserted (1.44M 3.5" floppy)
# floppya: 1_2=path, status=ejected (1.2M 5.25" floppy)
# floppya: 720k=path, status=inserted (720K 3.5" floppy)
# floppya: 360k=path, status=inserted (360K 5.25" floppy)
# floppya: 320k=path, status=inserted (320K 5.25" floppy)
# floppya: 180k=path, status=inserted (180K 5.25" floppy)
# floppya: 160k=path, status=inserted (160K 5.25" floppy)
# The path should be the name of a disk image file. On unix, you can use
# a raw device name such as /dev/fd0 on Linux. On WinNT and Win2k, use
# drive letters such as a: or b: as the path. Raw floppy access is not
# supported on Windows 95 and 98.
#floppya: 1_44=/dev/fd0, status=inserted
#floppya: file=floppy.img, status=inserted
#floppya: 1_44=/dev/fd0H1440, status=inserted
#floppya: 1_2=../1_2, status=inserted
#floppya: 1_44=a:, status=inserted
floppya: 1_44=floppy.img, status=inserted
#floppya: 1_44=/dev/rfd0a, status=inserted
# FLOPPYB:
# See FLOPPYA above for syntax
#floppyb: 1_44=b:, status=inserted
floppyb: 1_44=floppy.img, status=inserted
#floppya: file=./beos/floppy.img, status=inserted
# ATA0, ATA1, ATA2, ATA3
# ATA controller for hard disks and cdroms
# ata[0-3]: enabled=[0|1], ioaddr1=addr, ioaddr2=addr, irq=number
# These options enables up to 4 ata channels. For each channel
# the two base io addresses and the irq must be specified.
# ata0 is enabled by default, with ioaddr1=0x1f0, ioaddr2=0x3f0, irq=14
# Examples:
# ata0: enabled=1, ioaddr1=0x1f0, ioaddr2=0x3f0, irq=14
# ata1: enabled=1, ioaddr1=0x170, ioaddr2=0x370, irq=15
# ata2: enabled=1, ioaddr1=0x1e8, ioaddr2=0x3e0, irq=11
# ata3: enabled=1, ioaddr1=0x168, ioaddr2=0x360, irq=9
ata1: enabled=0, ioaddr1=0x170, ioaddr2=0x370, irq=15
ata2: enabled=0, ioaddr1=0x1e8, ioaddr2=0x3e0, irq=11
ata3: enabled=0, ioaddr1=0x168, ioaddr2=0x360, irq=9
# ATA[0-3]-MASTER, ATA[0-3]-SLAVE
# This defines the type and characteristics of all attached ata devices:
# type= type of attached device [disk|cdrom]
# mode= only valid for disks [flat|concat|external|dll|sparse|vmware3]
# mode= only valid for disks [undoable|growing|volatile]
# path= path of the image
# cylinders= only valid for disks
# heads= only valid for disks
# spt= only valid for disks
# status= only valid for cdroms [inserted|ejected]
# biosdetect= type of biosdetection [none|auto], only for disks on ata0 [cmos]
# translation=type of transation of the bios, only for disks [none|lba|large|rechs|auto]
# model= string returned by identify device command
# journal= optional filename of the redolog for undoable and volatile disks
# Point this at a hard disk image file, cdrom iso file, or physical cdrom
# device. To create a hard disk image, try running bximage. It will help you
# choose the size and then suggest a line that works with it.
# In UNIX it may be possible to use a raw device as a Bochs hard disk,
# but WE DON'T RECOMMEND IT. In Windows there is no easy way.
# In windows, the drive letter + colon notation should be used for cdroms.
# Depending on versions of windows and drivers, you may only be able to
# access the "first" cdrom in the system. On MacOSX, use path="drive"
# to access the physical drive.
# The path, cylinders, heads, and spt are mandatory for type=disk
# The path is mandatory for type=cdrom
# Default values are:
# mode=flat, biosdetect=auto, translation=auto, model="Generic 1234"
# The biosdetect option has currently no effect on the bios
# Examples:
# ata0-master: type=disk, mode=flat, path=10M.sample, cylinders=306, heads=4, spt=17
# ata0-slave: type=disk, mode=flat, path=20M.sample, cylinders=615, heads=4, spt=17
# ata1-master: type=disk, mode=flat, path=30M.sample, cylinders=615, heads=6, spt=17
# ata1-slave: type=disk, mode=flat, path=46M.sample, cylinders=940, heads=6, spt=17
# ata2-master: type=disk, mode=flat, path=62M.sample, cylinders=940, heads=8, spt=17
# ata2-slave: type=disk, mode=flat, path=112M.sample, cylinders=900, heads=15, spt=17
# ata3-master: type=disk, mode=flat, path=483M.sample, cylinders=1024, heads=15, spt=63
# ata3-slave: type=cdrom, path=iso.sample, status=inserted
ata0-master: type=disk, mode=flat, path="image.be", cylinders=1065, heads=16, spt=63
#ata0-slave: type=cdrom, path=D:, status=inserted
#ata0-slave: type=cdrom, path=/dev/cdrom, status=inserted
#ata0-slave: type=cdrom, path="drive", status=inserted
#ata0-slave: type=cdrom, path=/dev/rcd0d, status=inserted
# BOOT:
# This defines your boot drive.
# You can either boot from 'floppy', 'disk' or 'cdrom'
# legacy 'a' and 'c' are also supported
# Examples:
# boot: floppy
# boot: disk
# boot: cdrom
# boot: c
# boot: a
boot: floppy
#boot: disk
# IPS:
# Emulated Instructions Per Second. This is the number of IPS that bochs
# is capable of running on your machine. Read the note in config.h
# on how to find this. Make sure to recompile after.
# IPS is used to calibrate many time-dependent events within the bochs
# simulation. For example, changing IPS affects the frequency of VGA
# updates, the duration of time before a key starts to autorepeat, and
# the measurement of BogoMips and other benchmarks.
# Examples:
# Machine Mips
# ________________________________________________________________
# 650Mhz Athlon K-7 with Linux 2.4.4/egcs-2.91.66 2 to 2.5 Mips
# 400Mhz Pentium II with Linux 2.0.36/egcs-1.0.3 1 to 1.8 Mips
# 166Mhz 64bit Sparc with Solaris 2.x approx 0.75 Mips
# 200Mhz Pentium with Linux 2.x approx 0.5 Mips
ips: 600000
# CLOCK:
# This defines the parameters of the clock inside Bochs:
# SYNC:
# TO BE COMPLETED (see Greg explaination in bug #536329)
# TIME0:
# Specifies the start (boot) time of the virtual machine. Use a time
# value as returned by the time(2) system call. If no time0 value is
# set or if time0 equal to 1 (special case) or if time0 equal 'local',
# the simulation will be started at the current local host time.
# If time0 equal to 2 (special case) or if time0 equal 'utc',
# the simulation will be started at the current utc time.
# Syntax:
# clock: sync=[none|slowdown|realtime], time0=[timeValue|local|utc]
# Example:
# clock: sync=none, time0=local # Now (localtime)
# clock: sync=slowdown, time0=315529200 # Tue Jan 1 00:00:00 1980
# clock: sync=none, time0=631148400 # Mon Jan 1 00:00:00 1990
# clock: sync=realtime, time0=938581955 # Wed Sep 29 07:12:35 1999
# clock: sync=realtime, time0=946681200 # Sat Jan 1 00:00:00 2000
# clock: sync=none, time0=1 # Now (localtime)
# clock: sync=none, time0=utc # Now (utc/gmt)
# Default value are sync=none, time0=local
#clock: sync=none, time0=local
# FLOPPY_BOOTSIG_CHECK: disabled=[0|1]
# Enables or disables the 0xaa55 signature check on boot floppies
# Defaults to disabled=0
# Examples:
# floppy_bootsig_check: disabled=0
# floppy_bootsig_check: disabled=1
#floppy_bootsig_check: disabled=1
# LOG:
# Give the path of the log file you'd like Bochs debug and misc. verbage
# to be written to. If you really don't want it, make it /dev/null. :^(
# Examples:
# log: ./bochs.out
# log: /dev/tty
#log: /dev/null
log: bochsout.txt
# LOGPREFIX:
# This handles the format of the string prepended to each log line.
# You may use those special tokens :
# %t : 11 decimal digits timer tick
# %i : 8 hexadecimal digits of cpu0 current eip
# %e : 1 character event type ('i'nfo, 'd'ebug, 'p'anic, 'e'rror)
# %d : 5 characters string of the device, between brackets
# Default : %t%e%d
# Examples:
# logprefix: %t-%e-@%i-%d
# logprefix: %i%e%d
#logprefix: %t%e%d
# LOG CONTROLS
# Bochs now has four severity levels for event logging.
# panic: cannot proceed. If you choose to continue after a panic,
# don't be surprised if you get strange behavior or crashes.
# error: something went wrong, but it is probably safe to continue the
# simulation.
# info: interesting or useful messages.
# debug: messages useful only when debugging the code. This may
# spit out thousands per second.
# For events of each level, you can choose to crash, report, or ignore.
# TODO: allow choice based on the facility: e.g. crash on panics from
# everything except the cdrom, and only report those.
# If you are experiencing many panics, it can be helpful to change
# the panic action to report instead of fatal. However, be aware
# that anything executed after a panic is uncharted territory and can
# cause bochs to become unstable. The panic is a "graceful exit," so
# if you disable it you may get a spectacular disaster instead.
panic: action=ask
error: action=report
info: action=report
debug: action=ignore
#pass: action=fatal
# DEBUGGER_LOG:
# Give the path of the log file you'd like Bochs to log debugger output.
# If you really don't want it, make it /dev/null or '-'. :^(
# Examples:
# debugger_log: ./debugger.out
#debugger_log: /dev/null
#debugger_log: debugger.out
debugger_log: -
# COM1:
# This defines a serial port (UART type 16550A). You can specify a device
# to use as com1. This can be a real serial line, or a pty. To use a pty
# (under X/Unix), create two windows (xterms, usually). One of them will
# run bochs, and the other will act as com1. Find out the tty the com1
# window using the `tty' command, and use that as the `dev' parameter.
# Then do `sleep 1000000' in the com1 window to keep the shell from
# messing with things, and run bochs in the other window. Serial I/O to
# com1 (port 0x3f8) will all go to the other window.
#com1: enabled=1, dev=/dev/ttyp9
# PARPORT1:
# This defines a parallel (printer) port. When turned on and an output file is
# defined the emulated printer port sends characters printed by the guest OS
# into the output file. On some platforms a device filename can be used to
# send the data to the real parallel port (e.g. "/dev/lp0" on Linux, "lpt1" on
# win32 platforms).
# Examples:
# parport1: enabled=1, file="parport.out"
# parport1: enabled=1, file="/dev/lp0"
# parport1: enabled=0
# SB16:
# This defines the SB16 sound emulation. It can have several of the
# following properties.
# All properties are in the format sb16: property=value
# midi: The filename is where the midi data is sent. This can be a
# device or just a file if you want to record the midi data.
# midimode:
# 0=no data
# 1=output to device (system dependent. midi denotes the device driver)
# 2=SMF file output, including headers
# 3=output the midi data stream to the file (no midi headers and no
# delta times, just command and data bytes)
# wave: This is the device/file where wave output is stored
# wavemode:
# 0=no data
# 1=output to device (system dependent. wave denotes the device driver)
# 2=VOC file output, incl. headers
# 3=output the raw wave stream to the file
# log: The file to write the sb16 emulator messages to.
# loglevel:
# 0=no log
# 1=only midi program and bank changes
# 2=severe errors
# 3=all errors
# 4=all errors plus all port accesses
# 5=all errors and port accesses plus a lot of extra info
# dmatimer:
# microseconds per second for a DMA cycle. Make it smaller to fix
# non-continous sound. 750000 is usually a good value. This needs a
# reasonably correct setting for IPS.
# For an example look at the next line:
#sb16: midimode=1, midi=/dev/midi00, wavemode=1, wave=/dev/dsp, loglevel=2, log=sb16.log, dmatimer=600000
# VGA_UPDATE_INTERVAL:
# Video memory is scanned for updates and screen updated every so many
# virtual seconds. The default is 300000, about 3Hz. This is generally
# plenty. Keep in mind that you must tweak the 'ips:' directive
# to be as close to the number of emulated instructions-per-second
# your workstation can do, for this to be accurate.
# Examples:
# vga_update_interval: 250000
vga_update_interval: 300000
# using for Winstone '98 tests
#vga_update_interval: 100000
# KEYBOARD_SERIAL_DELAY:
# Approximate time in microseconds that it takes one character to
# be transfered from the keyboard to controller over the serial path.
# Examples:
# keyboard_serial_delay: 200
keyboard_serial_delay: 250
# KEYBOARD_PASTE_DELAY:
# Approximate time in microseconds between attempts to paste
# characters to the keyboard controller. This leaves time for the
# guest os to deal with the flow of characters. The ideal setting
# depends on how your operating system processes characters. The
# default of 100000 usec (.1 seconds) was chosen because it works
# consistently in Windows.
# If your OS is losing characters during a paste, increase the paste
# delay until it stops losing characters.
# Examples:
# keyboard_paste_delay: 100000
# FLOPPY_COMMAND_DELAY:
# Time in microseconds to wait before completing some floppy commands
# such as read/write/seek/etc, which normally have a delay associated.
# I had this hardwired to 50,000 before.
# Examples:
# floppy_command_delay: 50000
# MOUSE:
# This option prevents Bochs from creating mouse "events" unless a mouse
# is enabled. The hardware emulation itself is not disabled by this.
# You can turn the mouse on by setting enabled to 1, or turn it off by
# setting enabled to 0. Unless you have a particular reason for enabling
# the mouse by default, it is recommended that you leave it off.
# You can also toggle the mouse usage at runtime (middle mouse button on
# X11 and SDL, F12 on Win32).
# Examples:
# mouse: enabled=1
# mouse: enabled=0
mouse: enabled=0
# private_colormap: Request that the GUI create and use it's own
# non-shared colormap. This colormap will be used
# when in the bochs window. If not enabled, a
# shared colormap scheme may be used. Not implemented
# on all GUI's.
# Examples:
# private_colormap: enabled=1
# private_colormap: enabled=0
# fullscreen: ONLY IMPLEMENTED ON AMIGA
# Request that Bochs occupy the entire screen instead of a
# window.
# Examples:
# fullscreen: enabled=0
# fullscreen: enabled=1
#fullscreen: enabled=0
#screenmode: name="sample"
# ne2k: NE2000 compatible ethernet adapter
# Examples:
# ne2k: ioaddr=IOADDR, irq=IRQ, mac=MACADDR, ethmod=MODULE, ethdev=DEVICE, script=SCRIPT
# ioaddr, irq: You probably won't need to change ioaddr and irq, unless there
# are IRQ conflicts.
# mac: The MAC address MUST NOT match the address of any machine on the net.
# Also, the first byte must be an even number (bit 0 set means a multicast
# address), and you cannot use ff:ff:ff:ff:ff:ff because that's the broadcast
# address. For the ethertap module, you must use fe:fd:00:00:00:01. There may
# be other restrictions too. To be safe, just use the b0:c4... address.
# ethdev: The ethdev value is the name of the network interface on your host
# platform. On UNIX machines, you can get the name by running ifconfig. On
# Windows machines, you must run niclist to get the name of the ethdev.
# Niclist source code is in misc/niclist.c and it is included in Windows
# binary releases.
# script: The script value is optionnal, and is the name of a script that
# is executed after bochs initialize the network interface. You can use
# this script to configure this network interface, or enable masquerading.
# This is mainly useful for the tun/tap devices that only exist during
# Bochs execution. The network interface name is supplied to the script
# as first parameter
# ne2k: ioaddr=0x240, irq=9, mac=fe:fd:00:00:00:01, ethmod=fbsd, ethdev=en0 #macosx
# ne2k: ioaddr=0x240, irq=9, mac=b0:c4:20:00:00:00, ethmod=fbsd, ethdev=xl0
# ne2k: ioaddr=0x240, irq=9, mac=b0:c4:20:00:00:00, ethmod=linux, ethdev=eth0
# ne2k: ioaddr=0x240, irq=9, mac=b0:c4:20:00:00:01, ethmod=win32, ethdev=MYCARD
# ne2k: ioaddr=0x240, irq=9, mac=fe:fd:00:00:00:01, ethmod=tap, ethdev=tap0
# ne2k: ioaddr=0x240, irq=9, mac=fe:fd:00:00:00:01, ethmod=tuntap, ethdev=tun0, script=./tunconfig
# KEYBOARD_MAPPING:
# This enables a remap of a physical localized keyboard to a
# virtualized us keyboard, as the PC architecture expects.
# If enabled, the keymap file must be specified.
# Examples:
# keyboard_mapping: enabled=1, map=gui/keymaps/x11-pc-de.map
keyboard_mapping: enabled=0, map=
# KEYBOARD_TYPE:
# Type of keyboard return by a "identify keyboard" command to the
# keyboard controler. It must be one of "xt", "at" or "mf".
# Defaults to "mf". It should be ok for almost everybody. A known
# exception is french macs, that do have a "at"-like keyboard.
# Examples:
# keyboard_type: mf
#keyboard_type: mf
# USER_SHORTCUT:
# This defines the keyboard shortcut to be sent when you press the "user"
# button in the headerbar. The shortcut string can be a combination of
# these key names: "alt", "bksp", "ctrl", "del", "esc", "f1", "f4", "tab"
# and "win". Up to 3 keys can be pressed at a time.
# Example:
# user_shortcut: keys=ctrlaltdel
#user_shortcut: keys=ctrlaltdel
# other stuff
#magic_break: enabled=1
#cmosimage: cmos.img
#load32bitOSImage: os=nullkernel, path=../kernel.img, iolog=../vga_io.log
#load32bitOSImage: os=linux, path=../linux.img, iolog=../vga_io.log, initrd=../initrd.img
#i440fxsupport: enabled=1
usb1: enabled=1, ioaddr=0xFF80, irq=10
#text_snapshot_check: enable
# for Macintosh, use the style of pathnames in the following
# examples.
# vgaromimage: :bios:VGABIOS-elpin-2.40
# romimage: file=:bios:BIOS-bochs-latest, address=0xf0000
# floppya: 1_44=[fd:], status=inserted
# The following directives are DEPRECATED
# Please convert them to the new syntax or remove them
# The DISKC option is deprecated. Use ATA* options instead.
# DISKC: file=, cyl=, heads=, spt=
# Point this at a hard disk image file. To create
# a hard disk image, try running bximage. It will help you choose the
# size and then suggest a diskc line that works with it.
# Examples:
# diskc: file=10M.sample, cyl=306, heads=4, spt=17
# diskc: file=20M.sample, cyl=615, heads=4, spt=17
# diskc: file=30M.sample, cyl=615, heads=6, spt=17
# diskc: file=46M.sample, cyl=940, heads=6, spt=17
# diskc: file=62M.sample, cyl=940, heads=8, spt=17
# diskc: file=112M.sample, cyl=900, heads=15, spt=17
# diskc: file=483M.sample, cyl=1024, heads=15, spt=63
#diskc: file="30M.sample", cyl=615, heads=6, spt=17
# The DISKD option is deprecated. Use ATA* options instead.
# DISKD:
# See DISKC above for syntax
# NOTE: diskd and cdromd must not be used together!
#diskd: file="diskd.img", cyl=615, heads=6, spt=17
# The CDROMD option is deprecated. Use ATA* options instead.
# CDROMD:
# cdromd: dev=/dev/cdrom, status=inserted
# cdromd: dev=/dev/cdrom, status=ejected
# cdromd: dev=e:, status=ejected
#cdromd: dev=D:, status=inserted
#cdromd: dev=/dev/cdrom, status=inserted
#cdromd: dev="drive", status=inserted
# The TIME0 directive is DEPRECATED. Use the CLOCK directive instead
# TIME0:
# set or if time0 equal to 1 (special case), the simulation will be
# started at the current time of the host.
# Examples:
# time0: 1 # Now
# time0: 315529200 # Tue Jan 1 00:00:00 1980
# time0: 631148400 # Mon Jan 1 00:00:00 1990
# time0: 938581955 # Wed Sep 29 07:12:35 1999
# time0: 946681200 # Sat Jan 1 00:00:00 2000
#time0: 938581955
# The PIT directive is DEPRECATED. Use the CLOCK directive instead
# PIT:
# The PIT is the programmable interval timer. It has an option that tries to
# keep the PIT in sync with real time. This feature is still experimental,
# but it may be useful if you want to prevent Bochs from running too fast, for
# example a DOS video game. Be aware that with the realtime pit option, your
# simulation will not be repeatable; this can a problem if you are debugging.
#pit: realtime=1
# NEWHARDDRIVESUPPORT: enabled=[0|1]
# The old harddrive code is not maintened any more.
# Default value is enabled=1
#newharddrivesupport: enabled=1
The config file loads fine and I can even start the emulation:
Then the kernel boots:
From there on its stuck on that screen. It will not respond to anything. Is there anybody else here that uses Bochs emulator for BeOS? Any input will help. If I get this working, I might be able to create a tutorial for others
I’ve been eyeballing that for a while, but qemu looks pretty promising. I’ll give it a shot Thanks
