RTL8723BE wifi adapter and bluetooth not working?
the adapter in Devices of Network?
i see the RTL8723BE wifi adapter don’t be list in the Network? and i can’t use the adapter to connect internet.
why?
i also can’t use my bluetooth to connect any devices like my phone. i don’t know why.
should i use some command? or or do some adjust?
Only pairing is implemented. Treat Bluetooth support as non-existing in Haiku.
The “Devices” application merely lists all devices connected to the machine. Not all of them may actually be supported by Haiku.
The RTL8723BE is not supported by FreeBSD’s Realtek WiFi drivers, so Haiku does not support it either.
