Right-click to Copy / Paste etc
I know BeOS never had this, but
Would it be easy (and acceptable to the Haiku Board of Directors) to have a similar functionality to other OSes and Firefox, etc. whereby in a text entry box or even in the Haiku text control used by Styled Edit to get a pop-up context menu for cut, paste, select all, etc. when right clicking on selected text.
Screen shot: http://www.geocities.com/hey68you/firefox_rightclick.png
Apologies if there is already a forum thread on this or even if there is already an open ticket for this.
Thanks,
hey68you
It from former me this lacks already, on example in StylesEdit or Terminal. I speak with certain programmer even, he wrote, from thenwork on half day :smiley: Unfortunately, he does in Haiku now heavier thing . Therefore I favour your idea fully :wink:
I second this :smiley:
It would be quite useful.
@hey68you: What system is that (from the screenshot)?
I think this is a good idea.
Please search on Trac and see if there is already an Enhancement Ticket for this. If not, please add one.
@nutela: The screenshot is just Firefox on my BeOS R5 net_server.
I don’t see an open enhancement for this yet but before I add one, I was just wondering from the user experience (not in the code) how this will work together with the already existing functionality whereby if text string is selected the right-click drag n drop will let you copy (or move with in StyledEdit) the selected text.
Any thoughts?
[quote=hey68you]I was just wondering from the user experience (not in the code) how this will work together with the already existing functionality whereby if text string is selected the right-click drag n drop will let you copy (or move with in StyledEdit) the selected text.
[/quote]
I don’t see any conflict here as current drag-and-drop uses both mouse keys in StyledEdit. In many other applications like the Mail right key is used for context menu.
+1 on this feature request.
Every text entry control should have, per default, an “Edit Actions” popup menu with Copy/Cut/Paste/Select All actions associated to the secondary mouse click. The app in question should be able to disable/override the said popup menu, of course.
The popup menu should be “sticky”, as ALL of them should be, IMO (does anyone really tolerates non-sticky menues?).
BiPolar
http://dev.haiku-os.org/ticket/3831
Any progress with context menu (copy,paste etc.) in text editor and terminal?
