Ahoy folks,
Seems finally I could reduce to one suspected package which can cause usb_disk read errors on my Haiku USB key installs
→ as it strongly USB related
→ the well known error messages for me appeared only AFTER, when I issued the following install portion of packages
pkgman install dillo_plus dooble epiphany falkon httrack kristall ladybird links lynx netsurf otter_browser qupzilla qutebrowser retawq w3m webkit_gtk_demo zeal
the suspected package is libusb,
precisely libusb-1.0.26-2-x86_64.hpkg
~> pkgman search libusb
Status Name Description
hamlib Ham radio backend rig control library
hxcfloppyemulator Command-line tools for the HxC floppy emulator
libgusb Glib wrapper around libusb1
libgusb_devel Glib wrapper around libusb1 (development files)
libgusb_source Glib wrapper around libusb1 (source files)
S libusb A library that provides generic access to USB devices
libusb_compat An API wrapper for libusb
libusb_compat_devel An API wrapper for libusb (development files)
libusb_compat_source An API wrapper for libusb (source files)
libusb_debuginfo A library that provides generic access to USB devices (debug info)
libusb_devel A library that provides generic access to USB devices (development files)
libusb_docs A library that provides generic access to USB devices
libusb_examples A library that provides generic access to USB devices
libusb_source A library that provides generic access to USB devices (source files)
libusbmuxd A client library to multiplex connections from and to iOS devices
libusbmuxd_debuginfo A client library to multiplex connections from and to iOS devices (debug info)
libusbmuxd_devel A client library to multiplex connections from and to iOS devices (development files)
libusbmuxd_source A client library to multiplex connections from and to iOS devices (source files)
Seems it is dependency for Web/Epiphany
~> pkgman uninstall libusb
The following changes will be made:
in system:
uninstall package epiphany-43.1-1
uninstall package gcr-3.41.1-3
uninstall package gnupg-2.4.3-1
uninstall package libusb-1.0.26-2
Continue? [yes/no] (yes) : no
Errors in syslog BEFORE these packages installed :
~> grep -E -i error /boot/system/var/log/syslog | grep -E -v -i deferred
2024-04-02 09:26:45 USER: Error in AllUnarchived method of object of type 5BView
2024-04-02 09:26:45 USER: An error occured during unarchival, cleaning up.
2024-04-02 09:26:46 DAEMON 'DHCP': /dev/net/iprowifi4965/0: DHCP status = No error
~> df -h
Mount Type Total Free Flags Device
/boot bfs 14.0 GiB 8.8 GiB QAM-P-W /dev/disk/usb/0/0/0
/boot/system packagefs 4.0 KiB 4.0 KiB QAM-P--
/boot/home/config packagefs 4.0 KiB 4.0 KiB QAM-P--
/boot/system/var/shared_memory
ramfs 0 30.8 GiB QAM-PRW
/BFS_DL bfs 15.2 GiB 11.9 GiB QAM-P-W /dev/disk/usb/0/0/2
~> pkgman install dillo_plus dooble epiphany falkon httrack kristall ladybird links lynx netsurf otter_browser qupzilla qutebrowser retawq w3m webkit_gtk_demo zeal
Errors in syslog AFTER these packages installed :
[system] Applying changes ...
[system] Changes applied. Old activation state backed up in "state_2024-04-02_09:50:46"
[system] Cleaning up ...
[system] Done.
2024-04-02 09:51:12 KERN: usb error ehci 2: qtd (0x84ae00) error: 0x2c008d40
2024-04-02 09:51:12 KERN: usb_disk: request_sense: key: 0x03; asc: 0x11; ascq: 0x00; Unrecovered read error
2024-04-02 09:51:12 KERN: usb_disk: block read failed when filling partial buffer: I/O error
2024-04-02 09:51:12 KERN: usb_disk: read failed: I/O error
2024-04-02 09:51:12 KERN: unknown: [1563096623: 1507] ReadFileData(4763615, 0xffffffffb7490000, 10947) failed to read data: I/O error
