i recently installed several versions of the haiku-nightlies (most recently 40448 gcc2-hybrid), but i can’t get the ralinkwifi driver working.
the card is ok, i had it working under several other (mostly useless) os-es.
"KERN: [ralinkwifi] (ral) could not allocate interrupt resource"
Maybe interrupt (sharing) issue (?) but you should try installing firmware first to see if that makes the card work or not.
The log shows this device doesn’t have an interrupt line assigned. Haiku’s PCI code reports it as line zero, which means none. To get the device working it needs an interrupt, most commonly the BIOS will do this assignment during startup, but Haiku also needs to be able to do this at runtime.
It’s possible that you can work around this by tweaking BIOS options labelled e.g. “PnP OS” or by manually assigning the IRQ line if there’s a feature which lets you do that.
[quote=tonestone57] "KERN: [ralinkwifi] (ral) could not allocate interrupt resource"
Maybe interrupt (sharing) issue (?) but you should try installing firmware first to see if that makes the card work or not.[/quote]
i forgot to mention that i ran the install-wifi-firmwares.sh, but as far as i know the ralink firmwares are included.
anyway, i had no luck with that.
[quote=NoHaikuForMe]The log shows this device doesn’t have an interrupt line assigned. Haiku’s PCI code reports it as line zero, which means none. To get the device working it needs an interrupt, most commonly the BIOS will do this assignment during startup, but Haiku also needs to be able to do this at runtime.
It’s possible that you can work around this by tweaking BIOS options labelled e.g. “PnP OS” or by manually assigning the IRQ line if there’s a feature which lets you do that.[/quote]
well that’s the worst part of all, the bios on this laptop is the lamest one i’ve ever seen, it has only options for boot order, date and memory allocated to the videocard. I already searched for a bios upgrade but this machine is ancient, and i don’t believe the upgraded version has more features.
is there any possibility that the OS can do this irq assignment? (or do any of you know some other way around this?) I mean either inside (maybe some parameters for the driver or the pci code) or outside Haiku (I’m not much into custom bios hacking but there may be something out there)
I have seen few people able to resolve the IRQ issue by disabling their wired network card. Sometimes an IRQ conflict happens for some people.
To see your IRQ list, in terminal type: kernel_debugger
then ints
you will see int X, where X=0 to 15 plus any device using that IRQ
then type exit to leave
You can disable wired card (and audio card too) by removing their drivers from Haiku. Then they won’t take up any IRQs. Maybe you get lucky and then WiFi works.
Why not use your wired network? Seems your wired network card was detected but dhcp was not working for you.
ok i updated to 40501, i looked at my irq list, and practically removed every driver i could (including usb, ps2, audio, wired network), but sadly nothing helped, the wifi card still reports the same error.
Btw, there’s a line in the syslog which i don’t understand:
KERN: ioapic explicitly disabled, not using ioapics for interrupt routing
maybe enabling this feature would help me?
i’m not using the wired interface because all my other devices use the same wifi router, so i had to pull the cable off my wifi router to download the optional packages (and the firmwares).
[quote=gif]Btw, there’s a line in the syslog which i don’t understand:
[/quote]
Yes, but no. Having working interrupt routing would help you, in that then your WiFi could work. Having IOAPIC support could be a step in that direction.
But as far as I can tell Haiku’s IOAPIC support is “explicitly” disabled because it simply doesn’t work. So enabling this (you might be able to from the “safe mode” menu) is likely to just crash the PC.
But as far as I can tell Haiku’s IOAPIC support is “explicitly” disabled because it simply doesn’t work. So enabling this (you might be able to from the “safe mode” menu) is likely to just crash the PC.[/quote]
is there any possibility that the OS can do this irq assignment? (or do any of you know some other way around this?) I mean either inside (maybe some parameters for the driver or the pci code) or outside Haiku (I’m not much into custom bios hacking but there may be something out there)[/quote]
does your bios have a PlugandPlay Aware/capable OS setting ? If so set it to NO instead of Yes. That should get the bios to assing IRQ’s are boot time. Which in thoery should get your wireless card to work.
Since you removed things like usb, ps2, audio, wired networking and still couldn’t get an IRQ then you’re out of luck. Doing this would have freed up IRQs for the card to use without IRQ sharing.
Some systems had buggy IRQ/MP table or buggy BIOSes. I will guess that is the case with your laptop. BIOS upgrade was the way to fix this.
hey, thanks for all the help so far, it’s much appreciated.
i debugged the free’d irq-s constantly with the kernel_debugger, but it seems it tried to acquire something i couldn’t free. (i even moved the ata driver but that resulted in a livecd boot ;D)
i just burned the bios upgrade cd at my workplace, i’ll take my shot with it in a few hours. (but to be honest i don’t expect much).
i wasn’t sure these two symptoms were connected, but with acpi i also didn’t have usb working. after playing around with drivers, by removing the acpi and ehci driver, usb started to work (i thought it was ehci, but it may be that only acpi was the one)
so i’ll dig myself into this also, i’m not that giving up type regarding Haiku
thanks again, you’re all great help:)
((as for the wired thing, i also prefer wired plainly for the sake of speed/response, but we have a newborn baby and it’s just super complex now to move around rooms with cables))
You can also disable ACPI with safe-mode. You get to safe-mode by holding down SHIFT key right at very start of booting Haiku.
ACPI can be disabled from the kernel (text) file to make this change permanent.
EHCI = USB 2.0
UHCI (Intel & VIA) & OHCI (SiS, Nvidia) = USB 1.x
Seems like buggy BIOS like that Toshiba link I provided. That person disabled ACPI and things worked better for him. See if that helps your situation.
Understand that your issue sounds more about getting (being assigned) an IRQ. Which points to a BIOS issue and trying to work around it. ie: buggy or Plug N Play BIOS,
i tried several variations yesterday evening, (i used space to get the boot menu) and tried to disable acpi, and/or enable ioapic, combined with moving drivers out of the kernel drivers folder and/or leaving them in their original place.
i got mixed results but the wifi card was never initialized. it’s interesting that if every driver is in their original place and i go with the safe boot acpi disable option, then Haiku freezes at boot (is there any way to see the initializations via textmode?). USB only works if I remove the acpi driver by hand from the kernel drivers along the ehci driver.
[quote=gif]i tried several variations yesterday evening, (i used space to get the boot menu) and tried to disable acpi, and/or enable ioapic, combined with moving drivers out of the kernel drivers folder and/or leaving them in their original place.
i’m running out of ideas :|[/quote]
When you get to safe mode you will see options for debugging output. You can set it to on screen debugging.
You have done everything possible to get it working. At some point you will have to give up. It seems like BIOS issue and I do not think you can get around it with Haiku.
You have disabled ACPI, enabled IOAPIC, removed other drivers (to free IRQs), etc.
