我是中国用户但 R1/Alpha 4.1无法安装 becjk-1.0.1-2-x86_gcc2.hpkg
目前无法输入中文
Hello Shen. You need a more recent build to install hpkg. Please, download it from here:
https://download.haiku-os.org/
In a recent build, you can install any hpkg using the HaikuDepot application included.
hai
我测试过多个最新版本都存在些问题
比如播放一些视频会不够流畅,所以我才选择了 R1 / Alpha 4.1
Hai
I’ve tested many of the latest versions, and there are problems
For example, playing some video is not smooth enough, so I chose R1 / Alpha 4.1
https://download.haiku-os.org/nightly-images/x86_gcc2_hybrid/
http://packages.haiku-os.org/haikuports/master/repo/x86_gcc2/current/packages/qmplay2_x86-15.05.30-2-x86_gcc2.hpkg work fine!!!
hpkg包管理系统是4.1版本之后采用的。想用hpkg包就只能用最近的nightly镜像。
若实在想用R1/Alpha 4.1,可以找旧的包格式的becjk (https://github.com/HaikuArchives/BeCJK/releases)。
谢谢你提供的下载
新版总是很多问题
所以R1 / Alpha 4.1更适合我
Thank you
very good
