Trying to port some software to haiku, does it support qt5? If not are there other versions of qt or can i use java?
Qt5 is available and there are many applications based on Qt5 available in the HaikuDepot already.
There’s even Qt6,the newer version,already.
Java should work on Haiku,too,but I don’t know if it’s still actively maintained.
There’s also Qt6
Haiku+OpenJDK
Ancestris 12 = nightly (for Linux, for MacOS should too) works on Haiku 64bit out-of-the-box and almost perfectly.
Under Haiku 32bit there are problems with the window size and position display.
@korli made it possible (mainly or entirely)!
