I tried to get the official Debian engineering release build 202303 to run, but I had HDMI issues. I got the same error as others had reported, but for some reason I could not resolve it. I assumed I needed to update the firmware based on other comments.
Arch booted without any trouble on an SD card, 32GB. The image found here: VisionFive2 - Google Drive Its quite funny that Arch works as advertised, but the official release has so many problems.
Once logged into the system I followed the steps.
pacman -S mtd-utils
flashcp -A -v /home/user/VisionFive2/firmware/u-boot-spl.bin.normal.out /dev/mtd0
flashcp -A -v /home/user/VisionFive2/firmware/visionfive2_fw_payload.img /dev/mtd2
The directory listed above has changed in the latest Arch build image. Tab completion works so just hit the tab key after typing firmw, and the correct directory will populate.
I compiled Haiku from the official sources following the guide, and wrote the haiku-mmc.image to my SD card, but that doesnât work. I will at this point assume that I am missing something.
Returning to the official documentation, I burned haiku-master-hrev57076 to my SD card in the hopes of getting anything. Finally, after checking the switches position, I tried all combinations. I got something other than an error on the console.
Returning to my freshly compiled image on SD card, I tried once more.
This is known issue tracked at #18432. It seems unrelated to RISC-V and specific to VL805-Q6 USB 3 chip. Hopefully issue can be fixed soon. For now various screen keyboards like KeyMap or my ScreenKeyboard can be used as workaround.
You may want to create new BFS partition in DriveSetup and run Installer to use more NVMe disk space.
Yes, it seems that USB keyboard is working but not at the same time as USB mouse, the mouse seems to override the keyboard when attached. I donât see why Haiku wouldnât be usable when this is fixed, ethernet works and a few more apps get built, if you can live without sound. I tried attaching my USB soundcard and Haiku mistakes it as a HID device when it seems you have supposedly enabled USB audio support? Ethernet isnât fully working yet is it? I think we also have the option of borrowing the VF ethernet driver from OpenBSD.
Iâve noticed that although my backspace key works correctly in the Haiku keymap program, backspace functions as space in the Haiku terminal. All the other keys seem to work fine in the teminal.
Does jam not give us an option to define the size of the Haiku partition? If not, we should be able to hack the Haiku build scripts to create a larger partition rather than creating a second one.
When I say USB soundcard its actually just a USB headphone jack adapter, a
4c4a:4155 Jieli Technology UACDemoV1.0
According to lsusb. These are the most affordable and most widely compat. USB audio devices. They work OOTB with Android, Linux, Windows, FreeBSD and its the only USB audio device Iâve ever got to work with NetBSD. They cost about ÂŁ1.
Iâm happy to send one to X512 even tho the postage would be more than its worth
What about a VNC server is compiled to RISC-V?
this would solve the USB problem temporarily, i.e. SSH and VNC, you enter the system from another computer. I like it so much in the case of sbc tiles.
Ethernet doesnât seem to be fully working yet anyway so no, its probably not an option yet and I wouldnât want to use anyway if it was an option.
EDIT
Iâve just learned about the Haiku remote desktop, which apparently works kinda like X forwarding.
Again, I have no real interest in this nor using Haiku as any kind of headless server. Itâs supposed to be a desktop OS so mouse and keyboard input are must haves IMO.
VisionFive2 is specific. Itâs an SBC board, I have my own, I want to use it not as a Destop, but as a network-managed IoT center. I know that the main vision is to produce a system for Desktop, but as I wrote above, SBC is not an ideal computer for everyday use.
BTW. VNC is unofficial on BearShere or BeSly repository, I donât remember where
While technically possible, It do not fit intended Haiku use case â to be desktop operating system. USB support should be fixed, some bugs also seems affect Haiku USB support in general, including x86 hardware.
Attempting to follow danboidâs footsteps, I re-built and burned the image to my nvme drive.
I have tried just burning the image, as well as manually assigning a GTP table and writing the files to the partitions. I get the following error on the console:
ethernet@16030000 Waiting for PHY auto negotiation to complete⊠TIMEOUT !
phy_startup() failed: -110FAILED: -110ethernet@16040000 Waiting for PHY auto negotiation to complete⊠TIMEOUT !
phy_startup() failed: -110FAILED: -110ethernet@16030000 Waiting for PHY auto negotiation to complete⊠TIMEOUT !
phy_startup() failed: -110FAILED: -110StarFive #
U-Boot is configured to boot from NVMe using UEFI.
visionfive2 branch is used.
@minimum-mmc build target is used. @minimum-raw image need additional preparations like manually making ESP partition and copying Haiku EFI boot loader.
Haiku image is written to NVMe, not SD card. SD card is not supported yet by Haiku and you will get âno boot partitions!â KDL.
