It should be available after compiling Haiku. HaikuDepot app is not very useful, packages are usually already present at moment of system install or should be compiled manually.
It should be available in “generated” directory after compiling Haiku or in optional packages in Haiku image. Optional packages can be selected in Installer.
You can run something like find . -name haiku_devel.hpkg -type f to find exact HPKG file location.
It will be a chiplet SOC with lots of ram attached directly to the SOC and just as much extensible ram. it will be a pretty big SOC,bigger than the AMD EPYC processors actually…
That would be cool, but I would be happy with a smaller SBC that I can use to breathe new life into old laptop housings, especially the weird / quirky old “toughbook” style devices that are cheapily available due to bios lock. A few mods on those things (passively cooled + full aluminium / magnesium housing) and they’d be great “workstations”. Probably the more difficult stuff would be to get the display already installed working with that…
I installed this by copying it into /system/packages/ under Haiku but configuring SDL is getting no further as it seems that package doesn’t include as or a substitute command.
I have my doubts that USB mass storage is working properly just yet under Haiku rv64. I have got Tracker to successfully mount FAT32 USB disks and I can browse them OK using tracker but whenever I try to cat a text file or copy a file from the USB disk to anywhere I get Bad address errors.
I had tried to install haiku_devel.hpkg by copying it from a FAT32 USB disk but I don’t think that is a viable option yet. I’ll have to copy it onto my haiku disk using Haiku x86.
After a long hiatus I came back to play with this. I followed Clee’s instructions above and got Haiku booting on NVMe on my VisionFive 2 but it hangs at the third icon (devices).
It seems to hang at MMC Bus manager. Any pointers ? I built from the latest hrev (57649). Should I build an old one to match the device_manager2 branch ?
(I have tried with the latest firmware, but also 3.04. I am not sure if the issue with firmwares earlier than 3.1.5 is still happening?).
Took me a while to understand it would boot on SSD with 1-0 and on NVME with 1-1 . To update the images I usually just boot to Debian on the SD card and DD it to the second partition
Here’s the end of the serial output:
DeviceManager::DoDPC
0xffffffc0073e9510.DeviceNodeImpl::Probe("MMC Bus Manager")
0xffffffc0073e9510.DeviceNodeImpl::ProbeDriver("bus_managers/mmc/driver/v1", 0)
fState.multipleDrivers: 0
MmcBusDriver::Init()
mmc_bus: Reset the bus...
[!] MmcDriver::ExecuteCommand: timeout when executing command
mmc_bus: CMD0 result: Operation timed out
[!] driver do not support device or internal driver error
[!] failed to probe driver "bus_managers/mmc/driver/v1" for node "MMC Bus Manager"
0xffffffc0073e9390.DeviceNodeImpl::Probe("MMC Bus Manager")
0xffffffc0073e9390.DeviceNodeImpl::ProbeDriver("bus_managers/mmc/driver/v1", 0)
mmc_bus: Reset the bus...```
Edit: Reading my own message I start to think I shouldn’t have built the mmc image to run from a nvme disk ?. I am a bit confused :-)
It’s a 8 GB VisionPro 2 and the NVME is a WD Blue SN580 (which works fine when use on linux). Well it works fine to write the image. I only booted linux from the SD card, in order to write such image (which I rsync from my Intel build machine).
Now my only frustration (aside from my own build failing) is everyhing seems to be working with @X512 's build … except the mouse / keyboard. Tried quite a few here but without success.
I read above mouse & keyboard can’t work together yet. Is there a common characteristis of keyboard / mouse that work ?
Not that I am on firmware 3.15 . Is it ok to use latest firmware nowadays ? I always get a bit confused reading old remarks in the thread.
