Is there still someone working on the CDDA-Filesystem? I have read that Axel Dörfler was working on this Filesystem, (*** Removed - I see that CDDA is part of the Haiku Source code).
Does this work under Haiku 64 bit? Using an external USB DVD/CD Player it does not mount the Audio CD. Data-DVD mounts perfect.
It seems to be an issue with USB device. Just tried on a Sata drive and it worked fine. With an external usb dvd-writer it fails.
I guess it is not a problem with the cdda-fs driver, but with the usb support.
