Profiles in webpositive?
is it possible to make different browser agents in webpositive? i want to use i2p but it asks to create a different browser profile. it says that your anonymous internet shouldnt be accessed on your browser profile because then all the cookies and cache will conflict and then i will be leaked (defeating point of anonymous internet). any way to solve this in webpositive?
No,this is currently not supported.
As you can see in https://grok.nikisoft.one/opengrok/xref/haiku/src/apps/webpositive/BrowserApp.cpp?r=f849a8775ee9de1d5a1f2f50ca89d67f4a3813fe#103 the cookie store path is unconditionally always set to B_USER_SETTINGS_DIRECTORY/WebPositive/Cookies.
If you don’t mind a few manual steps,you can rename the cookie folder or move it somewhere else,then use I2P and when you’re done with it,rename/move it back.
WebPositive doesn’t store any cache,so that’s no problem at all,only the cookies.
thanks, but what is b_users settings directory?
B_USER_SETTINGS_DIRECTORY translates to /boot/home/config/settings so the full path would be /boot/home/config/settings/WebPositive/Cookies.
But I’ve just seen that besides Cookies,there are 3 other files in the WebPositive folder that contain the cookies and need to be moved/renamed: cookie.jar.db, cookie.jar.db-shm, cookie.jar.db-wal
