Hello,
I’m trying to install Haiku to a partition of an IDE drive from Linux and got some problems :
sudo jam -q [...] AddDirectoryToContainerCopyFilesScript beos/etc/licenses/-/data/etc/licenses InitScript1 generated/haiku.image-unzip-files BuildHaikuImage1 /dev/hda6 Creating image ... Partition::SetTo(): active: 80 Partition::SetTo(): active: 0 intel: _ParsePrimary(): partition 1: bad location, ignoring Partition::SetTo(): active: 0 intel: _ParsePrimary(): partition 2: bad location, ignoring Partition::SetTo(): active: 0 Error: Invalid partition index 6. Populating image ... Deleting old MIME database ... Installing MIME database ... Unmounting ... ...updated 309 target(s)...
So makebootable doesn’t seems to work (I tried to run “makebootable /dev/hda6” (after setting correctly LD_LIBRARY_PATH so it can find the required libs) and I got the same error message).
The hard drive was partitioned with fdisk v2.12r. (2 primary partitions + 2 logical)
Disk /dev/hda: 76.8 GB, 76869918720 bytes 255 heads, 63 sectors/track, 9345 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/hda1 * 1 1868 15004678+ 7 HPFS/NTFS /dev/hda2 1869 7820 47809440 83 Linux /dev/hda3 7821 9345 12249562+ 5 Extended /dev/hda5 7821 8319 4008186 82 Linux swap / Solaris /dev/hda6 8320 9345 8241313+ b W95 FAT32
(I also have some SCSI drives inside.)
