Good day! I have a problem booting Haiku on my Asus eepc 2g surf.
Loading stops at stage 4. The loading process for CPU modules does not work. This laptop has a Celeron M533 processor. Loading was fine before. I could use the operating system perfectly, after which I installed Windows XP. I’m currently having trouble installing the haiku back.
Boot Haiku
Right before you see the bootloader screen (the row of icons on a black page), tap the space key quickly.
A menu should appear.
Choose Select safe mode options
Did not help. The booting also stops with another flash drive. And the laptop freezes completely. (There is no reaction to Ctrl+Alt+Del). Could this problem be caused by an incorrectly partitioned built-in hard drive?
I mean, recreate the usb boot drive from the site´s ISO.
You said it booted before. Did it boot from the hard disk, after installation, or only from the usb ? Was it with Beta4 ? Are you trying with the same , or are you trying with one of the nightlies ?
Hard disk capacity 2 gigabytes. But I won’t install a system on it. I’ll install it on SD card. That’s what I used to do. And yes, the OS used to boot from both HDD and USB storage.
And can you check which version did you use before ?
Also, how much RAM does the machine have ?
Because " … The x86 32-bit release of Haiku will run on a Pentium or better CPU with 384 MiB of RAM (as long as virtual memory is activated), 1.5 GiB of storage space and a VESA compliant video card." …
The specs I found for that machine say only 256MB RAM
I’ve already tried it. I recorded the system image onto a USB drive and tried to boot. I posted the log of this launch above. I haven’t inserted a sd card when loading yet.
