I downloaded initially the VM for r3 and that works fine. I can access the network. however the startup disk is quite small and can’t be resized.
So, I downloaded the .iso installer image and make a new VMware instance, and installed haiku. However, now I can’t get a network connection. In network control panel, no devices are listed. I have tried both in bridged modes and in NAT modes, sharing mac connection. Rebooted after each change for good measure.
However with listdev, I do see that the network controller is being detected.
however, nothing ever shows up in network control panel and i cant browse the web.
Interestingly when I first tried to copy the results of listdev, the terminal froze. I had to force-kill it. Then on rebooting haiku, haiku froze entirely mid-startup. A bit spooky interms of instability… no big deal as I had just installed and just did a reinstall to fix it, but hopefully it will be more stable on an ongoing basis.
I tried this again using virtualbox 4.1.2 for mac os x 10.6.8.
Interestingly, had the exact same issue. No net connectivity, no devices showing up in network control panel. I’d like to get back into Haiku on Virtualbox to troubleshoot more (havent done a listdev), but I can’t boot into it again (see separate, virtualbox hangs thread).
Does Haiku not know how to use the device driver that was identified? Do I need to emulate something else or do some configuration on the OOB install to get networking working?
[quote=frankenburps]I tried this again using virtualbox 4.1.2 for mac os x 10.6.8.
Does Haiku not know how to use the device driver that was identified? Do I need to emulate something else or do some configuration on the OOB install to get networking working?[/quote]
What driver does it use? try intel driver
