Problem encountered when record the screen using BeScreenCapture
Hello everyone,
I encountered a problem when using the screen recording program. When it was working, the memory usage kept increasing until it filled up the memory, causeing lag. When I stopped recording, the momory was not released and I need to exit the program to solve it. :upside_down_face:
You might want to report the issue over BeScreenCapture repo, or perhaps @jackburton (its author) can chime in here.
For what it is worth… from a comment on a BeScreenCapture issue…
(on version >= 2.5.2):
[…] It will now hit the disk only after it has exhausted almost all the available memory, so disk shouldn’t be a bottleneck anymore.
So, high memory usage might just be normal and desirable behaviour (except for it ending in lag on the system, of course).
I observed it for a while longer, and found that the program ran out of memory then started using swap space, at which point the system started to slow down.
Thank you, I will move to GitHub.
Hi,
it’s fixed in new version 2.9.1.
Should be already available.
Thanks for reporting in the github issue tracker!
I changed it back recently to writing directly on disk because on 32 bit the address space is simply not big enough.
The memory usage should stay low during recording now.
Thank you very much! :slightly_smiling_face:
