Hi
Is it possible to download from Haikudepot previous versions of an application?
Each time I try it I get a ‘404 Not Found’ error.
Hi
That’s what I’m trying:
I tried it using WebPositive, Dooble and Falkon. It fails trying to download previous versions of any application.
If I try to download current versions, it works ok.
I tried outside Haiku with same results.
It seems that previous versions are not available at the moment indeed.
Not totally sure but I think the older versions aren’t all being kept around (server storage isn’t cheap I guess), you could always ask someone if they could build you an older version for a package that isn’t available anymoere (if it doesn’t come with a ton of dependencies also not being around).
