We have a thread for Haiku screenshots, but I’d like to also start one for those of us still running BeOS, whether on bare metal or via virtualization!
Here’s a couple of screenshots from my BeOS 5.0.3 VM running through VirtualBox. Specs on the VM are 256 MB RAM, 64MB VRAM, SB16 sound, 8GB HDD, and with Intel PRO/1000 T Server NIC.
This is a PowerMac 9500 180/MP with dual 604e’s running at 180MHz and 130MB RAM
The 9500 I have had since circa 2001. It has a load of history for me and is pretty nostalgic. I am going to be coding on it again pretty soon, so hopefully will start a dev diary or two on those projects. It’ll mainly be making things work that BeOS PowerPC has missing. I probably want more RAM, but as putting it in is really hard, I’ll probably hold off on that for now… lol! (you need to gut the machine.)
This is an Umax C500 with a 603e running at 180MHz and 80MB RAM. It is also running the OS from an SD Card in an SD to IDE adapter.
The Umax is a new addition and is pretty sweet. I have replaced the hard drive to make it easer to swap out the hard drive… it’s now just an MicroSD card in an adapter! I don’t think it changed the performance much. I need to get an L2 cache chip for the Umax and I think that will speed it up slightly, but other than that it is a great machine.
I was going to grab one from my BeOS machine, even though it’s pretty much a vanilla install right now, but then remembered that I don’t have it on the network yet. I did have it on with a 3com card but couldn’t get that working form Windows on there. Put a Realtek 8139(a) card in there and can’t get that to work with any drivers in BeOS, just doesn’t show up.
All the “drivers” are just hex-edited versions of the original driver, patching in the required device ID. Same is required for the eepro100 Intel driver. If you can get the device ID (from Devices) it will make finding the right driver a lot easier.
