Kernel Emulation on Windows allows you to run x86 Linux native binaries under MS-Windows. No recompiling is required. The goal is to be able to run your favorite distro without dual-booting or using emulation products such as Vmware, Qemu or coLinux
POSIX API for Win2K-XP. Mainly implemented in the driver. Included: write-on-copy fork, threads, mutexes, spins, condvars, rwlocks, signals ... Signals/cancelation interrupt all waitable syscalls, NT syscalls are automaticaly restarted.
I’m not sure what the value of this is… Most linux software is available in source form, and usually POSIX-compliant (allowing it to be somewhat easily compiled on other POSIX platforms).
BeOS and Haiku are already POSIX-compliant (although BeOS is lacking some basic and important POSIX functionality - which hopefully Haiku will have)… a project that creates a POSIX layer for Win2k/XP (which is already somewhat POSIX-compliant itself) seems pretty useless - especially with cygwin already out there. And furthermore, it’s windows-specific, so it won’t help Haiku/BeOS at all since the Win32 API obviously doesn’t exist for them.
