Unfortunately, compilation o SBCL fails and I have no clue of how to debug this. Can somebody help? Here is the dump:
Debug information for team /boot/home/Repository/sbcl/src/runtime/sbcl (14167):
CPU(s): 2x Intel Core 2
Memory: 11.75 GiB total, 976.27 MiB used
Haiku revision: hrev53635 Dec 14 2019 07:19:40 (x86_64)
Active Threads:
thread 14333: team 14167 debug task
thread 14167: sbcl (main)
state: Debugged
Frame IP Function Name
0x30de80 0x1000c138dd ?
Unable to retrieve disassembly for IP 0x1000c138dd: address not contained in any valid image.
Frame memory:
[0x30de68] ... ....c~...... 17 00 10 20 00 00 00 00 63 7e c6 05 10 00 00 00
[0x30de78] ........ 00 00 00 00 00 00 00 00
0x30df28 0x1000c26b9d ?
0x30df78 0x100141587c ?
0x30dfe0 0x1001d8c043 ?
0x30e040 0x1001d8cc63 ?
0x30e070 0x1001d9f51c ?
0x30e098 0x1001d9e63c ?
0x30e120 0x1001176dcc ?
0x30e148 0x10011780ab ?
0x30e1d0 0x100117e564 ?
0x30e200 0x100142b0c3 ?
0x30e270 0x100142a725 ?
0x30e2d8 0x100117bd38 ?
0x30e350 0x10011d133d ?
0x30e380 0x100117c98d ?
0x30e3f8 0x10011d108d ?
0x30e470 0x10011d1155 ?
0x30e550 0x10011d5fcc ?
0x30e610 0x1001179cce ?
0x30e6e0 0x10011d5960 ?
0x30e7d0 0x10011d3fb1 ?
0x30e880 0x100117299d ?
0x30e9f0 0x10011d4dd0 ?
0x30eaf8 0x10011d7186 ?
0x30ec00 0x1002929983 ?
0x30ece0 0x10011726a4 ?
0x30ee20 0x100292971d ?
0x30eee8 0x1001e3770a ?
0x30ef10 0x1001e38344 ?
0x30f140 0x100208ffba ?
0x30f290 0x100208f718 ?
0x30f350 0x1001179cce ?
0x30f510 0x100208f133 ?
0x30f618 0x100209267c ?
0x30f6a0 0x1002090c21 ?
0x30f7a8 0x1002092855 ?
0x30f880 0x1002091f5b ?
0x30f930 0x100209444e ?
0x30f9f8 0x1001e3791c ?
0x30fa10 0x1001e380f5 ?
0x30fbc0 0x1000d9c96a ?
0x30fd88 0x1000d9ec19 ?
0x30fe48 0x1002231e18 ?
0x30ff08 0x1002231b6f ?
0x30ffc8 0x1002231262 ?
0x7fbdf51eacc0 0x21af40b92b8 call_into_lisp + 0x40
0x7fbdf51eade0 0x21af40a859b sbcl_main(int, char**, char**) + 0x58b (/boot/home/Repository/sbcl/src/runtime/runtime.c:766)
Variables:
envp: 0x7fbdf51eb698 {
*envp: XDG_CONFIG_DIRS=/boot/system/settings
core: No such file or directory
sbcl_argv: No such file or directory {
*sbcl_argv: Unavailable
embedded_core_offset: 0
initial_function: No such file or directory
memsize_options {
dynamic_space_size: 203001917272
thread_control_stack_size: 203001919368
thread_tls_bytes: 203001921176
present_in_core: 0
have_hardwired_spaces: No such file or directory
0x7fbdf51eae00 0x21af4098999 _start + 0x39
0x7fbdf51eae40 0x103e75495c3 runtime_loader + 0x103
00000000 0x7ff99212c260 commpage_thread_exit + 0
Registers:
rip: 0x0000001000c138dd
rsp: 0x000000000030de68
rbp: 0x000000000030de80
rax: 0x0000001005c68003
rbx: 0x0000000020100017
rcx: 0x0000001000ac8993
rdx: 0x0000001005c19213
rsi: 0x000000100276b023
rdi: 0x0000001005a06ff3
r8: 0x0000001005c67e63
r9: 0x0000001005c19213
r10: 0x0000001005c67e63
r11: 0x000000002010004f
r12: 0x0000000020100017
r13: 0x0000000000512000
r14: 0x0000000020100017
r15: 0x0000001005c19213
cs: 0x002b
ds: 0x0000
es: 0x0000
fs: 0x0000
gs: 0x0000
ss: 0x0023
st0: 0
st1: 0
st2: 0
st3: 0
st4: 0
st5: 0
st6: 0
st7: 0
mm0: {0, 0, 0, 0}
mm1: {0, 0, 0, 0}
mm2: {0, 0, 0, 0}
mm3: {0, 0, 0, 0}
mm4: {0, 0, 0, 0}
mm5: {0, 0, 0, 0}
mm6: {0, 0, 0, 0}
mm7: {0, 0, 0, 0}
xmm0: {0, 0, 0, 0, 0, 0, 0, 0}
xmm1: {0, 0, 0, 0, 0, 0, 0, 0}
xmm2: {0, 0x4160, 0, 0, 0, 0, 0, 0}
xmm3: {0, 0x4160, 0, 0, 0, 0, 0, 0}
xmm4: {0, 0, 0, 0, 0, 0, 0, 0}
xmm5: {0, 0, 0, 0, 0, 0, 0, 0}
xmm6: {0, 0, 0, 0, 0, 0, 0, 0}
xmm7: {0, 0, 0, 0, 0, 0, 0, 0}
xmm8: {0, 0, 0, 0, 0, 0, 0, 0}
xmm9: {0, 0, 0, 0, 0, 0, 0, 0}
xmm10: {0, 0, 0, 0, 0, 0, 0, 0}
xmm11: {0, 0, 0, 0, 0, 0, 0, 0}
xmm12: {0, 0, 0, 0, 0, 0, 0, 0}
xmm13: {0, 0, 0, 0, 0, 0, 0, 0}
xmm14: {0, 0, 0, 0, 0, 0, 0, 0}
xmm15: {0, 0, 0, 0, 0, 0, 0, 0}
Loaded Images:
ID Text Base Text End Data Base Data End Type Name
142187 0xbb75c3000 0xbb75ca000 0xbb77c9000 0xbb77ca000 lib /boot/system/lib/libbsd.so
142177 0x627ffa2000 0x6281820000 0x6281a1f000 0x6281a20000 lib /boot/system/lib/libicudata.so.57.1
142174 0x666cef4000 0x666cf35000 0x666d134000 0x666d13d000 lib /boot/system/lib/libnetwork.so
142173 0x7b2fc72000 0x7b2ff86000 0x7b30185000 0x7b301b3000 lib /boot/system/lib/libbe.so
142178 0xb96dcd2000 0xb96df4f000 0xb96e14e000 0xb96e163000 lib /boot/system/lib/libicui18n.so.57.1
142184 0x103e0a36000 0x103e0a52000 0x103e0c51000 0x103e0c52000 lib /boot/system/lib/libz.so.1.2.11
142171 0x103e7535000 0x103e7556000 0x103e7755000 0x103e7757000 lib /boot/system/runtime_loader
142190 0x124bf64d000 0x124bf65e000 0x124bf85e000 0x124bf85f000 lib /boot/system/lib/libroot-addon-icu.so
142181 0x1265d528000 0x1265d533000 0x1265d733000 0x1265d734000 lib /boot/system/lib/libiculx.so.57.1
142185 0x1369c352000 0x1369c41b000 0x1369c61a000 0x1369c61b000 lib /boot/system/lib/libzstd.so.1.4.4
142180 0x15266bd1000 0x15266c26000 0x15266e26000 0x15266e29000 lib /boot/system/lib/libicule.so.57.1
142183 0x15cdee2a000 0x15cdefc2000 0x15cdf1c1000 0x15cdf1d6000 lib /boot/system/lib/libicuuc.so.57.1
142182 0x168a89b4000 0x168a89e3000 0x168a8be3000 0x168a8c17000 lib /boot/system/lib/libicutu.so.57.1
142179 0x1726474a000 0x17264756000 0x17264955000 0x17264957000 lib /boot/system/lib/libicuio.so.57.1
142176 0x174625ae000 0x17462710000 0x17462910000 0x17462924000 lib /boot/system/lib/libstdc++.so.6.0.25
142175 0x18edeb46000 0x18edeca4000 0x18edeea3000 0x18edeef6000 lib /boot/system/lib/libroot.so
142186 0x1981b347000 0x1981b35d000 0x1981b55c000 0x1981b55d000 lib /boot/system/lib/libgcc_s.so.1
142172 0x21af4088000 0x21af40c4000 0x21af42c3000 0x21af42ce000 app /boot/home/Repository/sbcl/src/runtime/sbcl
142170 0x7ff99212c000 0x7ff992134000 0x00000000 0x00000000 system commpage
Areas:
ID Base End Size (KiB) Protection Locking Name
422512 0x00100000 0x00101000 4 rwx full sbcl mmap area
422511 0x00101000 0x00102000 4 rwx full sbcl mmap area
422513 0x00102000 0x00103000 4 rwx full sbcl mmap area
422514 0x00103000 0x00104000 4 rwx full sbcl mmap area
422510 0x00104000 0x00105000 4 rwx full sbcl mmap area
422516 0x00105000 0x00106000 4 rwx full sbcl mmap area
422517 0x00106000 0x00107000 4 rwx full sbcl mmap area
422515 0x00107000 0x00108000 4 rwx full sbcl mmap area
422533 0x00108000 0x00109000 4 rwx full sbcl mmap area
422532 0x0010e000 0x0010f000 4 rwx full sbcl mmap area
422509 0x00110000 0x005a3000 4684 rwx full sbcl mmap area
422506 0x00699000 0x0069b000 8 rwx full sbcl mmap area
422501 0x00998000 0x009a0000 32 rwx full sbcl mmap area
422492 0x00e01000 0x00e19000 96 rw- full rld heap
422491 0x014cb000 0x014e3000 96 rw- full rld heap
422490 0x04682000 0x04692000 64 rw- full rld heap
422489 0x06708000 0x06718000 64 rw- full rld heap
422502 0x20000000 0x20008000 32 rwx full sbcl mmap area
422498 0x20008000 0x20100000 992 rwx full sbcl mmap area
422503 0x20100000 0x20108000 32 rwx full sbcl mmap area
422499 0x20108000 0x20200000 992 rwx full sbcl mmap area
422500 0x20200000 0x20300000 1024 rwx full sbcl mmap area
422488 0x6d2495000 0x6d249d000 32 rw- full rld heap
422486 0xbb75c3000 0xbb75ca000 28 r-x full libbsd.so_seg0ro
422487 0xbb77c9000 0xbb77ca000 4 rw- full libbsd.so_seg1rw
422505 0x1000000000 0x10023e8000 36768 rwx full sbcl mmap area
422504 0x10023e8000 0x10028d0000 5024 rwx full sbcl mmap area
422519 0x10028d0000 0x1003298000 10016 rwx full sbcl mmap area
422518 0x1003298000 0x10032a0000 32 rwx full sbcl mmap area
422521 0x10032a0000 0x1003340000 640 rwx full sbcl mmap area
422520 0x1003340000 0x1003348000 32 rwx full sbcl mmap area
422523 0x1003348000 0x1003440000 992 rwx full sbcl mmap area
422522 0x1003440000 0x1003448000 32 rwx full sbcl mmap area
422525 0x1003448000 0x10084b0000 82336 rwx full sbcl mmap area
422524 0x10084b0000 0x10084b8000 32 rwx full sbcl mmap area
422527 0x10084b8000 0x10099d8000 21632 rwx full sbcl mmap area
422526 0x10099d8000 0x10099e8000 64 rwx full sbcl mmap area
422529 0x10099e8000 0x1009a48000 384 rwx full sbcl mmap area
422528 0x1009a48000 0x1009a50000 32 rwx full sbcl mmap area
422531 0x1009a50000 0x1009e58000 4128 rwx full sbcl mmap area
422530 0x1009e58000 0x1040000000 886432 rwx full sbcl mmap area
422450 0x14fee55000 0x14fee56000 4 rw-S, u:(0x100) full rld_debug
422449 0x2f43db1000 0x2f43dc1000 64 rw- full rld heap
422465 0x627ffa2000 0x6281820000 25080 r-x full libicudata.so.57.1_seg0ro
422466 0x6281a1f000 0x6281a20000 4 rw- full libicudata.so.57.1_seg1rw
422456 0x666cef4000 0x666cf35000 260 r-x full libnetwork.so_seg0ro
422457 0x666d134000 0x666d137000 12 rw- full libnetwork.so_seg1rw
422458 0x666d137000 0x666d13d000 24 rw- full libnetwork.so_seg2rw
422493 0x673f261000 0x673f331000 832 rw-, u:(0x100) full heap
422454 0x7b2fc72000 0x7b2ff86000 3152 r-x full libbe.so_seg0ro
422455 0x7b30185000 0x7b301b3000 184 rw- full libbe.so_seg1rw
422467 0xb96dcd2000 0xb96df4f000 2548 r-x full libicui18n.so.57.1_seg0ro
422468 0xb96e14e000 0xb96e163000 84 rw- full libicui18n.so.57.1_seg1rw
422480 0x103e0a36000 0x103e0a52000 112 r-x full libz.so.1.2.11_seg0ro
422481 0x103e0c51000 0x103e0c52000 4 rw- full libz.so.1.2.11_seg1rw
422447 0x103e7535000 0x103e7556000 132 r-x full runtime_loader_seg0ro
422448 0x103e7755000 0x103e7757000 8 rw- full runtime_loader_seg1rw
422507 0x124bf64d000 0x124bf65e000 68 r-x full libroot-addon-icu.so_seg0ro
422508 0x124bf85e000 0x124bf85f000 4 rw- full libroot-addon-icu.so_seg1rw
422473 0x1265d528000 0x1265d533000 44 r-x full libiculx.so.57.1_seg0ro
422474 0x1265d733000 0x1265d734000 4 rw- full libiculx.so.57.1_seg1rw
422482 0x1369c352000 0x1369c41b000 804 r-x full libzstd.so.1.4.4_seg0ro
422483 0x1369c61a000 0x1369c61b000 4 rw- full libzstd.so.1.4.4_seg1rw
422471 0x15266bd1000 0x15266c26000 340 r-x full libicule.so.57.1_seg0ro
422472 0x15266e26000 0x15266e29000 12 rw- full libicule.so.57.1_seg1rw
422478 0x15cdee2a000 0x15cdefc2000 1632 r-x full libicuuc.so.57.1_seg0ro
422479 0x15cdf1c1000 0x15cdf1d6000 84 rw- full libicuuc.so.57.1_seg1rw
422475 0x168a89b4000 0x168a89e3000 188 r-x full libicutu.so.57.1_seg0ro
422476 0x168a8be3000 0x168a8be5000 8 rw- full libicutu.so.57.1_seg1rw
422477 0x168a8be5000 0x168a8c17000 200 rw- full libicutu.so.57.1_seg2rw
422469 0x1726474a000 0x17264756000 48 r-x full libicuio.so.57.1_seg0ro
422470 0x17264955000 0x17264957000 8 rw- full libicuio.so.57.1_seg1rw
422462 0x174625ae000 0x17462710000 1416 r-x full libstdc++.so.6.0.25_seg0ro
422463 0x17462910000 0x1746291c000 48 rw- full libstdc++.so.6.0.25_seg1rw
422464 0x1746291c000 0x17462924000 32 rw- full libstdc++.so.6.0.25_seg2rw
422459 0x18edeb46000 0x18edeca4000 1400 r-x full libroot.so_seg0ro
422460 0x18edeea3000 0x18edeeb2000 60 rw- full libroot.so_seg1rw
422461 0x18edeeb2000 0x18edeef6000 272 rw- full libroot.so_seg2rw
422484 0x1981b347000 0x1981b35d000 88 r-x full libgcc_s.so.1_seg0ro
422485 0x1981b55c000 0x1981b55d000 4 rw- full libgcc_s.so.1_seg1rw
422451 0x21af4088000 0x21af40c4000 240 r-x full sbcl_seg0ro
422452 0x21af42c3000 0x21af42c7000 16 rw- full sbcl_seg1rw
422453 0x21af42c7000 0x21af42ce000 28 rw- full sbcl_seg2rw
422445 0x7fbdf41e7000 0x7fbdf51ed000 16408 rw-s full sbcl_14167_stack
422444 0x7fd7bdb87000 0x7fd7bdb8b000 16 rw- full user area
422446 0x7ff99212c000 0x7ff992134000 32 r-xS full commpage
Protection Flags: r - read, w - write, x - execute, s - stack, o - overcommit, c - cloneable, S - shared, k - kernel
Semaphores:
ID Count Last Holder Name
422761 0 12684 some BBlockCache lock
422763 0 12684 token space
422810 0 9819 Catalog
422812 0 -2752 some BLocker
422815 0 5859 LocaleRosterData
422821 0 -2752 BLooperList lock
422822 0 2752 some BLocker
422823 0 -2752 AppServerLink_sLock
422824 0 -2752 some BLocker
