Porting qtox to haiku...help needed!
Hi,
After a successfull compilation (without video support & a couple of functionalities), qtox crashes at start, the output from the terminal shows, a lock/unlock shared memory issue, as i am not a developper i have no clue what to do next?
If some devs could take a look and help me that would be great.
here is the term output:
~/Desktop/qTox/build> ./qtox
plainFont: Regular Regular 14
monoFont: DejaVu Sans Mono Book 13
menuFont: Lucida Sans 400Norm BAS Regular 14
[16:42:47.762] ../src/persistence/settings.cpp:117 : Debug: No settings file found, using defaults
[16:42:47.764] ../src/persistence/settings.cpp:121 : Debug: "Loading settings from :/conf/qtox.ini"
[16:42:47.773] ../src/ipc.cpp:46 : Debug: Our global IPC ID is  2798026154482673633
[16:42:47.787] ../src/ipc.cpp:68 : Debug: Failed to attach to the global shared memory, giving up
[16:42:47.802] ../src/main.cpp:170 : Debug: built on:  16:28:38 Feb 17 2016 ( 1455722505 )
[16:42:47.802] ../src/main.cpp:171 : Debug: commit:  49b8a48888b2f003f5c684b6967180ca3a65c318
[16:42:47.803] ../src/ipc.cpp:143 : Warning: isCurrentOwner failed to access the memory, returning false
Kill Thread
and this is the crash report:
Debug information for team /boot/home/Desktop/qTox/build/qtox (3394):
CPU(s): 2x Intel Pentium 4
Memory: 1022.69 Mio total, 429.03 Mio used
Haiku revision: hrev50095 Feb 11 2016 14:48:38 (BePC)
Active Threads:
thread 3397: BApplication_thread
thread 3398: pthread func
thread 3399: team 3394 debug task
thread 3394: qtox (main)
state: Exception (Segment violation)
	Frame		IP			Function Name
	0x721c8fe8	0x1b1fb64	IPC::postEvent(QString const&, QByteArray const&, unsigned int) + 0xc4
		Disassembly:
			IPC::postEvent(QString const&, QByteArray const&, unsigned int):
			0x01b1faa0:               55  push %ebp
			0x01b1faa1:             89e5  mov %esp, %ebp
			0x01b1faa3:               57  push %edi
			0x01b1faa4:               56  push %esi
			0x01b1faa5:               53  push %ebx
			0x01b1faa6:           83ec44  sub $0x44, %esp
			0x01b1faa9:           8d45c8  lea -0x38(%ebp), %eax
			0x01b1faac:           8b7d0c  mov 0xc(%ebp), %edi
			0x01b1faaf:       e8a3faf7ff  call 0x1a9f557
			0x01b1fab4:     81c31ca54900  add $0x49a51c, %ebx
			0x01b1faba:               57  push %edi
			0x01b1fabb:               50  push %eax
			0x01b1fabc:       e8bf2cf7ff  call 0x1a92780
			0x01b1fac1:           8b55c8  mov -0x38(%ebp), %edx
			0x01b1fac4:           83c40c  add $0xc, %esp
			0x01b1fac7:             31c0  xor %eax, %eax
			0x01b1fac9:         837a0410  cmp $0x10, 0x4(%edx)
			0x01b1facd:             7f0e  jg 0x1b1fadd
			0x01b1facf:           8b7d10  mov 0x10(%ebp), %edi
			0x01b1fad2:             8b0f  mov (%edi), %ecx
			0x01b1fad4:   81790480000000  cmp $0x80, 0x4(%ecx)
			0x01b1fadb:             7e36  jle 0x1b1fb13
			0x01b1fadd:             8b0a  mov (%edx), %ecx
			0x01b1fadf:             85c9  test %ecx, %ecx
			0x01b1fae1:             751d  jnz 0x1b1fb00
			0x01b1fae3:           8945c4  mov %eax, -0x3c(%ebp)
			0x01b1fae6:               50  push %eax
			0x01b1fae7:             6a04  push $0x4
			0x01b1fae9:             6a01  push $0x1
			0x01b1faeb:               52  push %edx
			0x01b1faec:       e8cfabf7ff  call 0x1a9a6c0
			0x01b1faf1:           83c410  add $0x10, %esp
			0x01b1faf4:           8b45c4  mov -0x3c(%ebp), %eax
			0x01b1faf7:           8d65f4  lea -0xc(%ebp), %esp
			0x01b1fafa:               5b  pop %ebx
			0x01b1fafb:               5e  pop %esi
			0x01b1fafc:               5f  pop %edi
			0x01b1fafd:               5d  pop %ebp
			0x01b1fafe:               c3  ret
			0x01b1faff:               90  nop
			0x01b1fb00:               41  inc %ecx
			0x01b1fb01:             74f4  jz 0x1b1faf7
			0x01b1fb03:         f0832a01  lock sub $0x1, (%edx)
			0x01b1fb07:           0f95c1  setnz %cl
			0x01b1fb0a:             84c9  test %cl, %cl
			0x01b1fb0c:             75e9  jnz 0x1b1faf7
			0x01b1fb0e:           8b55c8  mov -0x38(%ebp), %edx
			0x01b1fb11:             ebd0  jmp 0x1b1fae3
			0x01b1fb13:           83ec0c  sub $0xc, %esp
			0x01b1fb16:           8b4508  mov 0x8(%ebp), %eax
			0x01b1fb19:           83c028  add $0x28, %eax
			0x01b1fb1c:               50  push %eax
			0x01b1fb1d:           8945c0  mov %eax, -0x40(%ebp)
			0x01b1fb20:       e8db28f7ff  call 0x1a92400
			0x01b1fb25:           83c410  add $0x10, %esp
			0x01b1fb28:             84c0  test %al, %al
			0x01b1fb2a:     0f8460020000  jz 0x1b1fd90
			0x01b1fb30:           83ec0c  sub $0xc, %esp
			0x01b1fb33:           8b7508  mov 0x8(%ebp), %esi
			0x01b1fb36:               56  push %esi
			0x01b1fb37:       e87450f7ff  call 0x1a94bb0
			0x01b1fb3c:           83c410  add $0x10, %esp
			0x01b1fb3f:           8945bc  mov %eax, -0x44(%ebp)
			0x01b1fb42:             31d2  xor %edx, %edx
			0x01b1fb44:           83c010  add $0x10, %eax
			0x01b1fb47:             eb1b  jmp 0x1b1fb64
			0x01b1fb49:   8db42600000000  lea (%esi), %esi
			0x01b1fb50:             85c0  test %eax, %eax
			0x01b1fb52:           0f94c1  setz %cl
			0x01b1fb55:               42  inc %edx
			0x01b1fb56:       05a8000000  add $0xa8, %eax
			0x01b1fb5b:             84c9  test %cl, %cl
			0x01b1fb5d:             741f  jz 0x1b1fb7e
			0x01b1fb5f:           83fa1f  cmp $0x1f, %edx
			0x01b1fb62:             771a  ja 0x1b1fb7e
			0x01b1fb64:     8b8898000000  mov 0x98(%eax), %ecx <--
		Frame memory:
			[0x721c8fa0]  |..r...........r   7c 90 1c 72 00 00 00 00 e8 eb fb 01 b8 8f 1c 72
			[0x721c8fb0]   ^X. ^X..H`.....   20 5e 58 18 20 5e 58 18 c8 48 60 18 02 00 00 00
			[0x721c8fc0]  ............,...   8f 00 00 00 0f a1 ba 01 fa a2 ba 01 2c f8 05 05
			[0x721c8fd0]  .y_.............   c8 79 5f 18 02 00 00 00 04 00 00 00 d0 9f fb 01
			[0x721c8fe0]  |..rp..r           7c 90 1c 72 70 90 1c 72
	0x721c90a8	0x1a9ed89	main + 0xd79
	0x721c90e8	0x1a9f5ad	_start + 0x4d
	0x721c9138	0x9d506f	runtime_loader + 0xdf
	00000000	0x62108250	commpage_thread_exit + 0
	Registers:
		  eip:	0x01b1fb64
		  esp:	0x721c8fa0
		  ebp:	0x721c8fe8
		  eax:	0x00000010
		  ebx:	0x01fb9fd0
		  ecx:	0x00000000
		  edx:	0x00000000
		  esi:	0x01fbebc0
		  edi:	0x721c907c
		   cs:	0x001b
		   ds:	0x0023
		   es:	0x0023
		   fs:	0x0063
		   gs:	0x0023
		   ss:	0x0023
		  st0:	0.45
		  st1:	220
		  st2:	5.37e+08
		  st3:	0
		  st4:	4.86e+07
		  st5:	1.14e+03
		  st6:	3.58e+08
		  st7:	1.46e+15
		  mm0:	{0x7f77, 0x5ae3, 0xe54e, 0xe6a5}
		  mm1:	{0, 0, 0, 0xdc00}
		  mm2:	{0, 0, 0xfff8, 0xffff}
		  mm3:	{0, 0, 0, 0}
		  mm4:	{0, 0, 0xd680, 0xb955}
		  mm5:	{0, 0, 0, 0x8ec0}
		  mm6:	{0, 0, 0xf800, 0xaa7a}
		  mm7:	{0x2000, 0xa611, 0xbac3, 0xa57e}
		 xmm0:	{0x6d20, 0x6d65, 0x726f, 0x2c79, 0x7220, 0x7465, 0x7275, 0x696e}
		 xmm1:	{0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff, 0xffff}
		 xmm2:	{0, 0, 0, 0, 0, 0, 0, 0}
		 xmm3:	{0x2, 0, 0, 0, 0, 0, 0, 0}
		 xmm4:	{0x3, 0, 0x1, 0, 0, 0, 0, 0}
		 xmm5:	{0xf21, 0x693d, 0xd801, 0x40e5, 0, 0, 0, 0}
		 xmm6:	{0x9ede, 0x9edd, 0x9edd, 0x3fdd, 0, 0, 0, 0}
		 xmm7:	{0, 0, 0, 0, 0, 0, 0, 0}
Loaded Images:
ID Text Base Text End Data Base Data End Type Name
41590 0x002ef000 0x0030b000 0x0030b000 0x0030c000 lib /boot/system/lib/libswresample.so.1.2.101
41608 0x00504000 0x00520000 0x00520000 0x00522000 lib /boot/system/lib/libsupc++.so
41569 0x0052e000 0x005da000 0x005da000 0x005de000 lib /boot/system/lib/libsqlite3.so.0.8.6
41615 0x00625000 0x00649000 0x00649000 0x0064b000 lib /boot/system/add-ons/Qt5/platforms/libqhaiku.so
41606 0x006c2000 0x0082d000 0x0082d000 0x00839000 lib /boot/system/lib/libicuuc.so.56.1
41587 0x0083d000 0x0084e000 0x0084e000 0x00850000 lib /boot/system/lib/libbz2.so.1.0.6
41552 0x008bd000 0x008c6000 0x008c6000 0x008c7000 lib /boot/system/lib/libtoxav.so.0.0.0
41594 0x008e3000 0x008fc000 0x008fc000 0x008fd000 lib /boot/system/lib/libtheoradec.so.1.1.4
41556 0x00907000 0x009a6000 0x009a6000 0x009b2000 lib /boot/system/lib/libvpx.so.1.0.0
41549 0x009c4000 0x009e0000 0x009e0000 0x009e1000 lib /boot/system/runtime_loader
41612 0x00a01000 0x00af8000 0x00af8000 0x00afa000 lib /boot/system/lib/libtextencoding.so
41593 0x00bc6000 0x00c0c000 0x00c0c000 0x00c0e000 lib /boot/system/lib/libtheoraenc.so.1.1.2
41559 0x00ce2000 0x00ece000 0x00ece000 0x00eda000 lib /boot/system/lib/libavformat.so.56.40.101
41588 0x00f41000 0x00f58000 0x00f58000 0x00f59000 lib /boot/system/lib/libz.so.1.2.8
41577 0x00fe0000 0x0100f000 0x0100f000 0x01011000 lib /boot/system/lib/libQt5Xml.so.5.5.1
41591 0x01017000 0x01091000 0x01091000 0x010a3000 lib /boot/system/lib/libvorbisenc.so.2.0.11
41604 0x010a7000 0x010b1000 0x010b1000 0x010b3000 lib /boot/system/lib/libiculx.so.56.1
41567 0x010b9000 0x010f4000 0x010f4000 0x010f6000 lib /boot/system/lib/libjpeg.so.9.1.0
41582 0x010fa000 0x01112000 0x01112000 0x01113000 lib /boot/system/lib/libgcc_s.so.1
41618 0x01176000 0x011f1000 0x011f1000 0x011f5000 lib /boot/system/lib/libfreetype.so.6.12.0
41571 0x011f6000 0x01228000 0x01228000 0x0122a000 lib /boot/system/lib/libfilteraudio.so.0.0.0
41563 0x01230000 0x01395000 0x01395000 0x0139e000 lib /boot/system/lib/libswscale.so.3.1.101
41573 0x013a4000 0x013e8000 0x013e8000 0x013ea000 lib /boot/system/lib/libQt5Svg.so.5.5.1
41572 0x013f0000 0x01436000 0x01436000 0x01439000 lib /boot/system/lib/libQt5OpenGL.so.5.5.1
41560 0x0144c000 0x01451000 0x01451000 0x01452000 lib /boot/system/lib/libavdevice.so.56.4.100
41584 0x014a0000 0x014d7000 0x014d7000 0x014df000 lib /boot/system/lib/libnetwork.so
41557 0x01526000 0x01584000 0x01584000 0x0158e000 lib /boot/system/lib/libsodium.so.13.2.0
41551 0x015f2000 0x01624000 0x01624000 0x01626000 lib /boot/system/lib/libtoxcore.so.0.0.0
41566 0x016dd000 0x0171c000 0x0171c000 0x01725000 lib /boot/system/lib/libjasper.so.1.0.0
41581 0x01731000 0x0187d000 0x0187d000 0x0188b000 lib /boot/system/lib/libstdc++.so.6.0.21
41595 0x0189d000 0x018af000 0x018af000 0x018b1000 lib /boot/system/lib/libspeex.so.1.5.0
41558 0x018ba000 0x018f2000 0x018f2000 0x018f5000 lib /boot/system/lib/libopenal.so.1.13.0
41553 0x0190e000 0x01910000 0x01910000 0x01911000 lib /boot/system/lib/libtoxencryptsave.so.0.0.0
41555 0x01926000 0x01968000 0x01968000 0x01969000 lib /boot/system/lib/libopus.so.0.5.2
41617 0x0196d000 0x0199f000 0x0199f000 0x019a5000 lib /boot/system/lib/libfontconfig.so.1.9.0
41578 0x019d2000 0x01a03000 0x01a03000 0x01a05000 lib /boot/system/lib/libQt5Sql.so.5.5.1
41550 0x01a1a000 0x01fb3000 0x01fb3000 0x01fbf000 app /boot/home/Desktop/qTox/build/qtox
41570 0x01fbf000 0x01fc8000 0x01fc8000 0x01fc9000 lib /boot/system/lib/libqrencode.so.3.4.4
41607 0x01fc9000 0x01fcd000 0x01fcd000 0x01fce000 lib /boot/system/lib/libbsd.so
41564 0x01fcf000 0x01ff9000 0x01ff9000 0x01ffa000 lib /boot/system/lib/libpng16.so.16.20.0
41562 0x01ffd000 0x02062000 0x02062000 0x02077000 lib /boot/system/lib/libavutil.so.54.31.100
41599 0x02077000 0x0208b000 0x0208b000 0x0208c000 lib /boot/system/lib/libtranslation.so
41592 0x0208f000 0x020b7000 0x020b7000 0x020b8000 lib /boot/system/lib/libvorbis.so.0.4.8
41611 0x020b9000 0x020be000 0x020be000 0x020bf000 lib /boot/system/lib/libogg.so.0.8.2
41554 0x020c0000 0x020c1000 0x020c1000 0x020c3000 lib /boot/system/lib/libtoxdns.so.0.0.0
41586 0x020c3000 0x0210b000 0x0210b000 0x021ba000 lib /boot/system/lib/libmodplug.so.1.0.0
41585 0x021bc000 0x02249000 0x02249000 0x0224e000 lib /boot/system/lib/libmedia.so
41602 0x02251000 0x0225b000 0x0225b000 0x0225c000 lib /boot/system/lib/libicuio.so.56.1
41580 0x02263000 0x02296000 0x02296000 0x0229a000 lib /boot/system/lib/libGL.so
41609 0x0229c000 0x022b6000 0x022b6000 0x022b8000 lib /boot/system/lib/libpostproc.so.53.3.100
41576 0x022bb000 0x023cf000 0x023cf000 0x023d3000 lib /boot/system/lib/libQt5Network.so.5.5.1
41597 0x023d3000 0x02538000 0x02538000 0x02546000 lib /boot/system/lib/libicuuc.so.55.1
41568 0x02546000 0x02622000 0x02622000 0x02667000 lib /boot/system/lib/libroot.so
41614 0x02669000 0x02679000 0x02679000 0x0267b000 lib /boot/system/lib/libroot-addon-icu.so
41610 0x02687000 0x026a6000 0x026a6000 0x026a8000 lib /boot/system/lib/libavresample.so.2.1.0
41603 0x026b8000 0x0270a000 0x0270a000 0x0270c000 lib /boot/system/lib/libicule.so.56.1
41565 0x0272f000 0x02785000 0x02785000 0x02788000 lib /boot/system/lib/libtiff.so.3.9.6
41605 0x02795000 0x027bf000 0x027bf000 0x027f3000 lib /boot/system/lib/libicutu.so.56.1
41619 0x0280a000 0x02873000 0x02873000 0x02875000 lib /boot/system/lib/libQt5DBus.so.5.5.1
41561 0x028b6000 0x034b2000 0x034b2000 0x03b48000 lib /boot/system/lib/libavcodec.so.56.60.100
41620 0x03b90000 0x03cb4000 0x03cb4000 0x03cbc000 lib /boot/system/lib/libxml2.so.2.9.3
41575 0x03cc3000 0x0416a000 0x0416a000 0x0417e000 lib /boot/system/lib/libQt5Gui.so.5.5.1
41574 0x04272000 0x04788000 0x04788000 0x047a3000 lib /boot/system/lib/libQt5Widgets.so.5.5.1
41583 0x048c6000 0x04b9f000 0x04b9f000 0x04bba000 lib /boot/system/lib/libbe.so
41589 0x04d3a000 0x04f42000 0x04f42000 0x04f47000 lib /boot/system/lib/libavfilter.so.5.40.101
41579 0x04f59000 0x05424000 0x05424000 0x05430000 lib /boot/system/lib/libQt5Core.so.5.5.1
41596 0x05529000 0x0576e000 0x0576e000 0x0577b000 lib /boot/system/lib/libicui18n.so.55.1
41616 0x05784000 0x058fe000 0x058fe000 0x0590c000 lib /boot/system/lib/libtracker.so
41598 0x05910000 0x071c8000 0x071c8000 0x071c9000 lib /boot/system/lib/libicudata.so.55.1
41600 0x073eb000 0x08bd0000 0x08bd0000 0x08bd1000 lib /boot/system/lib/libicudata.so.56.1
41601 0x08bfc000 0x08e5f000 0x08e5f000 0x08e6c000 lib /boot/system/lib/libicui18n.so.56.1
41548 0x62108000 0x62110000 0x00000000 0x00000000 system commpage
Areas:
ID Base End Size (KiB) Protection Locking Name
186248 0x00102000 0x0010a000 32 rw- full rld heap
186284 0x00111000 0x00119000 32 rw- full rld heap
186135 0x0011d000 0x0011e000 4 rw-S full rld_debug
186285 0x00124000 0x0012c000 32 rw- full rld heap
186134 0x00134000 0x00144000 64 rw- full rld heap
186287 0x001f5000 0x00205000 64 rw- full rld heap
186286 0x0029a000 0x002aa000 64 rw- full rld heap
186232 0x002ef000 0x0030b000 112 r-x full libswresample.so.1.2.101_seg0ro
186233 0x0030b000 0x0030c000 4 rw- full libswresample.so.1.2.101_seg1rw
186273 0x00504000 0x00520000 112 r-x full libsupc++.so_seg0ro
186274 0x00520000 0x00522000 8 rw- full libsupc++.so_seg1rw
186183 0x0052e000 0x005da000 688 r-x full libsqlite3.so.0.8.6_seg0ro
186184 0x005da000 0x005de000 16 rw- full libsqlite3.so.0.8.6_seg1rw
186298 0x00625000 0x00649000 144 r-x full libqhaiku.so_seg0ro
186299 0x00649000 0x0064b000 8 rw- full libqhaiku.so_seg1rw
186269 0x006c2000 0x0082d000 1452 r-x full libicuuc.so.56.1_seg0ro
186270 0x0082d000 0x00839000 48 rw- full libicuuc.so.56.1_seg1rw
186226 0x0083d000 0x0084e000 68 r-x full libbz2.so.1.0.6_seg0ro
186227 0x0084e000 0x00850000 8 rw- full libbz2.so.1.0.6_seg1rw
186141 0x008bd000 0x008c6000 36 r-x full libtoxav.so.0.0.0_seg0ro
186142 0x008c6000 0x008c7000 4 rw- full libtoxav.so.0.0.0_seg1rw
186240 0x008e3000 0x008fc000 100 r-x full libtheoradec.so.1.1.4_seg0ro
186241 0x008fc000 0x008fd000 4 rw- full libtheoradec.so.1.1.4_seg1rw
186150 0x00907000 0x009a6000 636 r-x full libvpx.so.1.0.0_seg0ro
186151 0x009a6000 0x009a8000 8 rw- full libvpx.so.1.0.0_seg1rw
186152 0x009a8000 0x009b2000 40 rw- full libvpx.so.1.0.0_seg2rw
186132 0x009c4000 0x009e0000 112 r-x full runtime_loader_seg0ro
186133 0x009e0000 0x009e1000 4 rw- full runtime_loader_seg1rw
186282 0x00a01000 0x00af8000 988 r-x full libtextencoding.so_seg0ro
186283 0x00af8000 0x00afa000 8 rw- full libtextencoding.so_seg1rw
186238 0x00bc6000 0x00c0c000 280 r-x full libtheoraenc.so.1.1.2_seg0ro
186239 0x00c0c000 0x00c0e000 8 rw- full libtheoraenc.so.1.1.2_seg1rw
186158 0x00ce2000 0x00ece000 1968 r-x full libavformat.so.56.40.101_seg0ro
186159 0x00ece000 0x00eda000 48 rw- full libavformat.so.56.40.101_seg1rw
186228 0x00f41000 0x00f58000 92 r-x full libz.so.1.2.8_seg0ro
186229 0x00f58000 0x00f59000 4 rw- full libz.so.1.2.8_seg1rw
186201 0x00fe0000 0x0100f000 188 r-x full libQt5Xml.so.5.5.1_seg0ro
186202 0x0100f000 0x01011000 8 rw- full libQt5Xml.so.5.5.1_seg1rw
186234 0x01017000 0x01091000 488 r-x full libvorbisenc.so.2.0.11_seg0ro
186235 0x01091000 0x010a3000 72 rw- full libvorbisenc.so.2.0.11_seg1rw
186264 0x010a7000 0x010b1000 40 r-x full libiculx.so.56.1_seg0ro
186265 0x010b1000 0x010b3000 8 rw- full libiculx.so.56.1_seg1rw
186178 0x010b9000 0x010f4000 236 r-x full libjpeg.so.9.1.0_seg0ro
186179 0x010f4000 0x010f6000 8 rw- full libjpeg.so.9.1.0_seg1rw
186214 0x010fa000 0x01112000 96 r-x full libgcc_s.so.1_seg0ro
186215 0x01112000 0x01113000 4 rw- full libgcc_s.so.1_seg1rw
186305 0x01176000 0x011f1000 492 r-x full libfreetype.so.6.12.0_seg0ro
186306 0x011f1000 0x011f5000 16 rw- full libfreetype.so.6.12.0_seg1rw
186187 0x011f6000 0x01228000 200 r-x full libfilteraudio.so.0.0.0_seg0ro
186188 0x01228000 0x0122a000 8 rw- full libfilteraudio.so.0.0.0_seg1rw
186168 0x01230000 0x01395000 1428 r-x full libswscale.so.3.1.101_seg0ro
186169 0x01395000 0x01396000 4 rw- full libswscale.so.3.1.101_seg1rw
186170 0x01396000 0x0139e000 32 rw- full libswscale.so.3.1.101_seg2rw
186191 0x013a4000 0x013e8000 272 r-x full libQt5Svg.so.5.5.1_seg0ro
186192 0x013e8000 0x013ea000 8 rw- full libQt5Svg.so.5.5.1_seg1rw
186189 0x013f0000 0x01436000 280 r-x full libQt5OpenGL.so.5.5.1_seg0ro
186190 0x01436000 0x01439000 12 rw- full libQt5OpenGL.so.5.5.1_seg1rw
186160 0x0144c000 0x01451000 20 r-x full libavdevice.so.56.4.100_seg0ro
186161 0x01451000 0x01452000 4 rw- full libavdevice.so.56.4.100_seg1rw
186218 0x014a0000 0x014d7000 220 r-x full libnetwork.so_seg0ro
186219 0x014d7000 0x014d9000 8 rw- full libnetwork.so_seg1rw
186220 0x014d9000 0x014df000 24 rw- full libnetwork.so_seg2rw
186153 0x01526000 0x01584000 376 r-x full libsodium.so.13.2.0_seg0ro
186154 0x01584000 0x0158e000 40 rw- full libsodium.so.13.2.0_seg1rw
186138 0x015f2000 0x01624000 200 r-x full libtoxcore.so.0.0.0_seg0ro
186139 0x01624000 0x01625000 4 rw- full libtoxcore.so.0.0.0_seg1rw
186140 0x01625000 0x01626000 4 rw- full libtoxcore.so.0.0.0_seg2rw
186175 0x016dd000 0x0171c000 252 r-x full libjasper.so.1.0.0_seg0ro
186176 0x0171c000 0x0171f000 12 rw- full libjasper.so.1.0.0_seg1rw
186177 0x0171f000 0x01725000 24 rw- full libjasper.so.1.0.0_seg2rw
186211 0x01731000 0x0187d000 1328 r-x full libstdc++.so.6.0.21_seg0ro
186212 0x0187d000 0x01884000 28 rw- full libstdc++.so.6.0.21_seg1rw
186213 0x01884000 0x0188b000 28 rw- full libstdc++.so.6.0.21_seg2rw
186242 0x0189d000 0x018af000 72 r-x full libspeex.so.1.5.0_seg0ro
186245 0x018af000 0x018b1000 8 rw- full libspeex.so.1.5.0_seg1rw
186155 0x018ba000 0x018f2000 224 r-x full libopenal.so.1.13.0_seg0ro
186156 0x018f2000 0x018f4000 8 rw- full libopenal.so.1.13.0_seg1rw
186157 0x018f4000 0x018f5000 4 rw- full libopenal.so.1.13.0_seg2rw
186143 0x0190e000 0x01910000 8 r-x full libtoxencryptsave.so.0.0.0_seg0
186144 0x01910000 0x01911000 4 rw- full libtoxencryptsave.so.0.0.0_seg1
186148 0x01926000 0x01968000 264 r-x full libopus.so.0.5.2_seg0ro
186149 0x01968000 0x01969000 4 rw- full libopus.so.0.5.2_seg1rw
186303 0x0196d000 0x0199f000 200 r-x full libfontconfig.so.1.9.0_seg0ro
186304 0x0199f000 0x019a5000 24 rw- full libfontconfig.so.1.9.0_seg1rw
186203 0x019d2000 0x01a03000 196 r-x full libQt5Sql.so.5.5.1_seg0ro
186204 0x01a03000 0x01a05000 8 rw- full libQt5Sql.so.5.5.1_seg1rw
186136 0x01a1a000 0x01fb3000 5732 r-x full qtox_seg0ro
186137 0x01fb3000 0x01fbf000 48 rw- full qtox_seg1rw
186185 0x01fbf000 0x01fc8000 36 r-x full libqrencode.so.3.4.4_seg0ro
186186 0x01fc8000 0x01fc9000 4 rw- full libqrencode.so.3.4.4_seg1rw
186271 0x01fc9000 0x01fcd000 16 r-x full libbsd.so_seg0ro
186272 0x01fcd000 0x01fce000 4 rw- full libbsd.so_seg1rw
186171 0x01fcf000 0x01ff9000 168 r-x full libpng16.so.16.20.0_seg0ro
186172 0x01ff9000 0x01ffa000 4 rw- full libpng16.so.16.20.0_seg1rw
186165 0x01ffd000 0x02062000 404 r-x full libavutil.so.54.31.100_seg0ro
186166 0x02062000 0x02063000 4 rw- full libavutil.so.54.31.100_seg1rw
186167 0x02063000 0x02077000 80 rw- full libavutil.so.54.31.100_seg2rw
186254 0x02077000 0x0208b000 80 r-x full libtranslation.so_seg0ro
186255 0x0208b000 0x0208c000 4 rw- full libtranslation.so_seg1rw
186236 0x0208f000 0x020b7000 160 r-x full libvorbis.so.0.4.8_seg0ro
186237 0x020b7000 0x020b8000 4 rw- full libvorbis.so.0.4.8_seg1rw
186280 0x020b9000 0x020be000 20 r-x full libogg.so.0.8.2_seg0ro
186281 0x020be000 0x020bf000 4 rw- full libogg.so.0.8.2_seg1rw
186145 0x020c0000 0x020c1000 4 r-x full libtoxdns.so.0.0.0_seg0ro
186146 0x020c1000 0x020c2000 4 rw- full libtoxdns.so.0.0.0_seg1rw
186147 0x020c2000 0x020c3000 4 rw- full libtoxdns.so.0.0.0_seg2rw
186223 0x020c3000 0x0210b000 288 r-x full libmodplug.so.1.0.0_seg0ro
186224 0x0210b000 0x0210c000 4 rw- full libmodplug.so.1.0.0_seg1rw
186225 0x0210c000 0x021ba000 696 rw- full libmodplug.so.1.0.0_seg2rw
186221 0x021bc000 0x02249000 564 r-x full libmedia.so_seg0ro
186222 0x02249000 0x0224e000 20 rw- full libmedia.so_seg1rw
186260 0x02251000 0x0225b000 40 r-x full libicuio.so.56.1_seg0ro
186261 0x0225b000 0x0225c000 4 rw- full libicuio.so.56.1_seg1rw
186208 0x02263000 0x02296000 204 r-x full libGL.so_seg0ro
186209 0x02296000 0x02299000 12 rw- full libGL.so_seg1rw
186210 0x02299000 0x0229a000 4 rw- full libGL.so_seg2rw
186275 0x0229c000 0x022b6000 104 r-x full libpostproc.so.53.3.100_seg0ro
186276 0x022b6000 0x022b7000 4 rw- full libpostproc.so.53.3.100_seg1rw
186277 0x022b7000 0x022b8000 4 rw- full libpostproc.so.53.3.100_seg2rw
186199 0x022bb000 0x023cf000 1104 r-x full libQt5Network.so.5.5.1_seg0ro
186200 0x023cf000 0x023d3000 16 rw- full libQt5Network.so.5.5.1_seg1rw
186249 0x023d3000 0x02538000 1428 r-x full libicuuc.so.55.1_seg0ro
186250 0x02538000 0x02544000 48 rw- full libicuuc.so.55.1_seg1rw
186251 0x02544000 0x02546000 8 rw- full libicuuc.so.55.1_seg2rw
186180 0x02546000 0x02622000 880 r-x full libroot.so_seg0ro
186181 0x02622000 0x0262c000 40 rw- full libroot.so_seg1rw
186182 0x0262c000 0x02667000 236 rw- full libroot.so_seg2rw
186293 0x02669000 0x02679000 64 r-x full libroot-addon-icu.so_seg0ro
186294 0x02679000 0x0267b000 8 rw- full libroot-addon-icu.so_seg1rw
186278 0x02687000 0x026a6000 124 r-x full libavresample.so.2.1.0_seg0ro
186279 0x026a6000 0x026a8000 8 rw- full libavresample.so.2.1.0_seg1rw
186262 0x026b8000 0x0270a000 328 r-x full libicule.so.56.1_seg0ro
186263 0x0270a000 0x0270c000 8 rw- full libicule.so.56.1_seg1rw
186173 0x0272f000 0x02785000 344 r-x full libtiff.so.3.9.6_seg0ro
186174 0x02785000 0x02788000 12 rw- full libtiff.so.3.9.6_seg1rw
186266 0x02795000 0x027bf000 168 r-x full libicutu.so.56.1_seg0ro
186267 0x027bf000 0x027c1000 8 rw- full libicutu.so.56.1_seg1rw
186268 0x027c1000 0x027f3000 200 rw- full libicutu.so.56.1_seg2rw
186307 0x0280a000 0x02873000 420 r-x full libQt5DBus.so.5.5.1_seg0ro
186308 0x02873000 0x02875000 8 rw- full libQt5DBus.so.5.5.1_seg1rw
186162 0x028b6000 0x034b2000 12272 r-x full libavcodec.so.56.60.100_seg0ro
186163 0x034b2000 0x034c7000 84 rw- full libavcodec.so.56.60.100_seg1rw
186164 0x034c7000 0x03b48000 6660 rw- full libavcodec.so.56.60.100_seg2rw
186309 0x03b90000 0x03cb4000 1168 r-x full libxml2.so.2.9.3_seg0ro
186310 0x03cb4000 0x03cbb000 28 rw- full libxml2.so.2.9.3_seg1rw
186311 0x03cbb000 0x03cbc000 4 rw- full libxml2.so.2.9.3_seg2rw
186196 0x03cc3000 0x0416a000 4764 r-x full libQt5Gui.so.5.5.1_seg0ro
186197 0x0416a000 0x0417a000 64 rw- full libQt5Gui.so.5.5.1_seg1rw
186198 0x0417a000 0x0417e000 16 rw- full libQt5Gui.so.5.5.1_seg2rw
186193 0x04272000 0x04788000 5208 r-x full libQt5Widgets.so.5.5.1_seg0ro
186194 0x04788000 0x047a2000 104 rw- full libQt5Widgets.so.5.5.1_seg1rw
186195 0x047a2000 0x047a3000 4 rw- full libQt5Widgets.so.5.5.1_seg2rw
186216 0x048c6000 0x04b9f000 2916 r-x full libbe.so_seg0ro
186217 0x04b9f000 0x04bba000 108 rw- full libbe.so_seg1rw
186230 0x04d3a000 0x04f42000 2080 r-x full libavfilter.so.5.40.101_seg0ro
186231 0x04f42000 0x04f47000 20 rw- full libavfilter.so.5.40.101_seg1rw
186205 0x04f59000 0x05424000 4908 r-x full libQt5Core.so.5.5.1_seg0ro
186206 0x05424000 0x0542d000 36 rw- full libQt5Core.so.5.5.1_seg1rw
186207 0x0542d000 0x05430000 12 rw- full libQt5Core.so.5.5.1_seg2rw
186246 0x05529000 0x0576e000 2324 r-x full libicui18n.so.55.1_seg0ro
186247 0x0576e000 0x0577b000 52 rw- full libicui18n.so.55.1_seg1rw
186300 0x05784000 0x058fe000 1512 r-x full libtracker.so_seg0ro
186301 0x058fe000 0x0590b000 52 rw- full libtracker.so_seg1rw
186302 0x0590b000 0x0590c000 4 rw- full libtracker.so_seg2rw
186252 0x05910000 0x071c8000 25312 r-x full libicudata.so.55.1_seg0ro
186253 0x071c8000 0x071c9000 4 rw- full libicudata.so.55.1_seg1rw
186256 0x073eb000 0x08bd0000 24468 r-x full libicudata.so.56.1_seg0ro
186257 0x08bd0000 0x08bd1000 4 rw- full libicudata.so.56.1_seg1rw
186258 0x08bfc000 0x08e5f000 2444 r-x full libicui18n.so.56.1_seg0ro
186259 0x08e5f000 0x08e6c000 52 rw- full libicui18n.so.56.1_seg1rw
186290 0x18572000 0x18632000 768 rw- full heap
186129 0x609c0000 0x609c4000 16 rw- full user area
186131 0x62108000 0x62110000 32 r-xSk full commpage
186316 0x62110000 0x62111000 4 rw-S full server_memory
186400 0x70eeb000 0x70f30000 276 rw-s full pthread func_3398_stack
186130 0x711c6000 0x721cc000 16408 rw-s full qtox_3394_stack
186318 0x721cc000 0x721ec000 128 rw-S full server_memory
186320 0x7a7ce000 0x7a813000 276 rw-s full BApplication_thread_3397_stack
Protection Flags: r - read, w - write, x - execute, s - stack, o - overcommit, c - cloneable, S - shared, k - kernel
Semaphores:
ID Count Last Holder Name
51779 0 0 some BBlockCache lock
51780 0 0 Catalog
51781 0 0 some BLocker
51782 0 0 some BLocker
51783 0 0 token space
51784 0 0 BLooperList lock
51785 0 0 AppServerLink_sLock
51786 0 0 LocaleRosterData
51787 0 0 some BLocker
51788 0 0 Catalog
51789 0 0 media plugin manager
51790 0 0 shared buffer list
51791 0 0 port pool
51792 0 0 add-on manager
51793 0 0 media theme lock
51794 0 0 BMediaRoster::Roster locker
51795 0 0 some BLocker
51796 0 0 Catalog
51797 0 0 Catalog
51798 0 0 PeriodicUpdatePoses
51799 0 0 Light Lock
51800 0 0 Light Lock
51801 0 0 undo
51802 0 0 some BLocker
51803 0 0 some BLocker
51804 0 0 BMessageQueue Lock
51805 0 0 AppLooperPort
51817 0 0 screen list
51818 0 0 clipboard
51819 0 0 width buffer
and the source code file.
I hope someone can help so the haiku commutnity could have a skype-like app.
Oh, i forgot to mention, i did not patch that ipc.cpp file, but if needed i can provide the patch i used for the other files.
In the past there was no shared memory support in the haiku Qt port. I don’t know if this was fixed. I built Qt4 with shared memory but I don’t remember if it worked. Is Qt 5 in the repo yet? You could try compiling against that, it is more likely to have support. It may be that this needs to be fixed first though: https://dev.haiku-os.org/ticket/2657
yes Qt5 is in the repo, qtox does not support Qt4 anyway.
Well, if it can not be executed in haiku because of that ticket than i’ll give up, unless one of the devs comes up with some workaround.
