https://eu.hpkg.haiku-os.org/haikuports/r1beta4/ not found
https://eu.hpkg.haiku-os.org/haikuports/ forbidden
fixed by:
pkgman add-repo https://eu.hpkg.haiku-os.org/haiku/r1beta5/$(getarch)/current
pkgman add-repo https://eu.hpkg.haiku-os.org/haikuports/r1beta5/$(getarch)/current
pkgman full-sync
reading through Get Haiku! | Haiku Project
finally thanks, if you had not removed r1beta4, I would probably never realized there were a new version!
Did you try pkgman full-sync after boot?
I did.
Before adding the repositories for beta5, it was saying ports repository not found.
Btw: This tab crash in Iceweasel, the reply button don’t work in Falkon, and I hope it will work in Web!
How did you see those error messages?
(It’s been a few month I couldn’t update my main BeOS VM, but I didn’t have time to investigate, would like to know where to look next time ^^)
Edit: there may be a mistake in the documentation, https://eu.hpkg.haiku-os.org/haikuports/r1beta5/$(getarch)/current should be https://eu.hpkg.haiku-os.org/haikuports/master/$(getarch)/current (or there is a missing tree on the package website)
Ahoy @dufresnep ,
Of course, you can select any browser for your web activities,
but for Haiku services I really recommend Webpositive !.. :))
I admit I do not use ‘One Browser For All’ - so if you are such a user/person … just simply ignore my advice. :j
