While searching for a console based markdown reader, I came across glow and tried to compile it under Haiku.
It’s written in Go, which is already ported, but sadly I cannot get glow to compile, anyone had any luck with this or can point me to a solution?
This is the error I get for all dependencies, e.g.:
../github.com/charmbracelet/glow/ui/sort.go:5:2: cannot find package "slices" in any of:
/packages/golang-1.4.3-7/.self/non-packaged/lib/go/src/slices (from $GOROOT)
/boot/home/go/src/slices (from $GOPATH)
It seems go does not try to search for packages online.
GOROOT and GOPATH are set correctly from what I see.
The directory layout also follows recommendations in
Lastly, the go mod command mentioned in the Go docs and the SO thread is not available in Haiku:
go mod init
go: unknown subcommand "mod"
