Before filing a bug, I’d like to be sure if I’m doing all right:
I took a gif on the net, splitted in its single fotograms with gifsicle (gifsicle -e filename), (tried also to convert single fotograms to pngs) then used moe to generate the animation (Moe --add-anime=animename --wait=1 files[…])
Then it places the attribute on the first file, but when I launch moe with this file, the first frame compares and then Moe crashes.
Need help for a basic task, AFAIK zipOmatic should create a compressed file that includes the source binary file + attributes, right?
But if I zip the file mentioned before it compresses only the binary data and not the attributes. In this specific case the attribute is quite big 410kb compared to the single image 11.17kb… the compressed file is 11.33kb. It obviously does not contain the 410kb of attributes
Where am I wrong?
It appears to be related to the size of the added attribute.
Regular zipping up from Terminal reveals:
zip warning: not enough space in extra field for attributes
In a test, a 4 KiB attribute worked, a 100 KiB didn’t. Icon-O-Matic Zip-O-Matic pretends to work, but only zips up the file itself, stripping all attributes.
Consider his suggestion. Even if that is by design, a better error message should be presented, so to make clear that the attributes were not included and why.
