I’m trying to install Haiku 64 bit OS on my computer, but I’m not succeeding. Below is the reported error message:
PANIC: unable to find irq routing for PCI 0: 26: 0
Welcome to Kernel Debugging Land …
Thread 1 “idle thread 1” running on CPU 0
stack trace for thead 1 "idle thread 1"
Kernel stack: 0xffffffff824f6000 to 0xffffffff824fb000
Below I put the configuration of my hardware:
pc-positivo
description: All In One
product: DC8BT11
vendor: Positivo Informatica SA
version: 1.09.U
serial: 1AF078G8X
width: 64 bits
capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
configuration: boot=normal chassis=all-in-one family=To be filled by O.E.M. uuid=8065A8F1-0F06-E611-BDF4-C32AFDBA4800
*-core
description: Motherboard
product: DC8BT11
physical id: 0
version: To be filled by O.E.M.
serial: 1AF078G8X
slot: To be filled by O.E.M.
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: 1.09.U
date: 05/27/2015
capacity: 960KiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi
*-memory
description: System Memory
physical id: 28
slot: System board or motherboard
*-bank:0
description: DIMM DDR3 1333 MHz (0.8 ns)
product: TMT425S6CFR6A-PBNJ
vendor: Undefined
physical id: 0
serial: 14651166
slot: A1_DIMM0
width: 64 bits
clock: 1333MHz (0.8ns)
*-bank:1
description: DIMM [empty]
product: Array1_PartNumber1
vendor: A1_Manufacturer1
physical id: 1
serial: A1_SerNum1
slot: A1_DIMM1
*-cache:0
description: L1 cache
physical id: 36
slot: CPU Internal L1
capacity: 112KiB
capabilities: internal write-back
configuration: level=1
*-cache:1
description: L2 cache
physical id: 37
slot: CPU Internal L2
capacity: 1MiB
capabilities: internal write-back unified
configuration: level=2
*-cpu
description: CPU
product: Intel® Celeron® CPU N2808 @ 1.58GHz
vendor: Intel Corp.
physical id: 38
bus info: cpu@0
version: Intel® Celeron® CPU N2808 @ 1.58GHz
slot: SOCKET 0
capacity: 2400MHz
width: 64 bits
clock: 83MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology tsc_reliable nonstop_tsc aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer rdrand lahf_lm 3dnowprefetch epb tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms dtherm ida arat cpufreq
configuration: cores=2 enabledcores=2 threads=2
*-pci
description: Host bridge
product: Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 0e
width: 32 bits
clock: 33MHz
configuration: driver=iosf_mbi_pci
resources: irq:0
*-display
description: VGA compatible controller
product: Atom Processor Z36xxx/Z37xxx Series Graphics & Display
physical id: 2
bus info: pci@0000:00:02.0
version: 0e
width: 32 bits
clock: 33MHz
capabilities: pm msi vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:91 memory:d0000000-d03fffff memory:c0000000-cfffffff ioport:f080(size=8) memory:c0000-dffff
*-storage
description: SATA controller
product: Atom Processor E3800 Series SATA AHCI Controller
physical id: 13
bus info: pci@0000:00:13.0
version: 0e
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:88 ioport:f070(size=8) ioport:f060(size=4) ioport:f050(size=8) ioport:f040(size=4) ioport:f020(size=32) memory:d0815000-d08157ff
*-usb
description: USB controller
product: Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI
physical id: 14
bus info: pci@0000:00:14.0
version: 0e
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:87 memory:d0800000-d080ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 4.10.0-35-generic xhci-hcd
physical id: 0
bus info: usb@1
logical name: usb1
version: 4.10
capabilities: usb-2.00
configuration: driver=hub slots=6 speed=480Mbit/s
*-usb:0
description: USB hub
product: USB2.0 Hub
vendor: Genesys Logic, Inc.
physical id: 3
bus info: usb@1:3
version: 85.37
configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
*-usb:0
description: Mass storage device
product: Samsung M3 Portable
vendor: JMicron
physical id: 2
bus info: usb@1:3.2
logical name: scsi2
version: e.00
serial: 00000000011E13CA
capabilities: usb-2.10 scsi emulated scsi-host
configuration: driver=usb-storage maxpower=8mA speed=480Mbit/s
*-disk
description: SCSI Disk
product: M3 Portable
vendor: Samsung
physical id: 0.0.0
bus info: scsi@2:0.0.0
logical name: /dev/sdb
version: 3
capabilities: partitioned partitioned:dos
configuration: ansiversion=6 logicalsectorsize=512 sectorsize=512 signature=0005b098
*-volume
description: Windows NTFS volume
physical id: 1
bus info: scsi@2:0.0.0,1
logical name: /dev/sdb1
logical name: /media/everaldo/SAMSUNG
version: 3.1
serial: 046b3faa-3d67-0244-824e-23b477ead028
capacity: 465GiB
capabilities: primary ntfs initialized
configuration: clustersize=4096 created=2015-04-16 23:49:49 filesystem=ntfs label=SAMSUNG mount.fstype=fuseblk mount.options=rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096 state=mounted
*-usb:1
description: Video
product: HD Webcam
vendor: Chicony Electronics Co., Ltd.
physical id: 3
bus info: usb@1:3.3
version: 69.26
configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
*-usb:1
product: USB2.0 Hub
physical id: 4
bus info: usb@1:4
version: 85.37
*-usb:0
description: Keyboard
product: USB Keyboard
vendor: USB
physical id: 1
bus info: usb@1:4.1
version: 1.10
capabilities: usb-1.10
configuration: driver=usbhid maxpower=100mA speed=2Mbit/s
*-usb:1
description: Mouse
product: USB OPTICAL MOUSE
physical id: 2
bus info: usb@1:4.2
version: 1.00
*-usbhost:1
physical id: 1
bus info: usb@2
logical name: usb2
version: 4.10
capabilities: usb-3.00
configuration: driver=hub slots=1 speed=5000Mbit/s
*-generic
description: Encryption controller
product: Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine
physical id: 1a
bus info: pci@0000:00:1a.0
version: 0e
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
configuration: driver=mei_txe latency=0
resources: irq:92 memory:d0500000-d05fffff memory:d0400000-d04fffff
*-multimedia
description: Audio device
product: Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 0e
width: 64 bits
clock: 33MHz
configuration: driver=snd_hda_intel latency=0
resources: irq:94 memory:d0810000-d0813fff
*-pci:0
description: PCI bridge
product: Atom Processor E3800 Series PCI Express Root Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 0e
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:16 ioport:e000(size=4096) memory:d0700000-d07fffff ioport:80000000(size=2097152)
*-network DISABLED
description: Wireless interface
product: RTL8188EE Wireless Network Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: wlp1s0
version: 01
serial: 4e:f8:b6:4d:04:4c
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl8188ee driverversion=4.10.0-35-generic firmware=N/A latency=0 link=no multicast=yes wireless=IEEE 802.11
resources: irq:93 ioport:e000(size=256) memory:d0700000-d0703fff
*-pci:1
product: Atom Processor E3800 Series PCI Express Root Port 2
physical id: 1c.1
bus info: pci@0000:00:1c.1
version: 0e
width: 32 bits
clock: 33MHz
resources: irq:17 ioport:d000(size=4096) memory:d0600000-d06fffff ioport:80200000(size=2097152)
*-generic
description: Unassigned class
product: RTL8411 PCI Express Card Reader
physical id: 0
bus info: pci@0000:02:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list
configuration: driver=rtsx_pci latency=0
resources: irq:89 memory:d0600000-d060ffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0.2
bus info: pci@0000:02:00.2
logical name: enp2s0f2
version: 0a
serial: 80:ee:73:b7:fc:14
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8411-1_0.0.3 06/18/12 ip=192.168.1.64 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:90 ioport:d000(size=256) memory:d0614000-d0614fff memory:d0610000-d0613fff
*-pci:2
product: Atom Processor E3800 Series PCI Express Root Port 3
physical id: 1c.2
bus info: pci@0000:00:1c.2
version: 0e
width: 32 bits
clock: 33MHz
resources: irq:18 ioport:1000(size=4096) memory:80400000-805fffff ioport:80600000(size=2097152)
*-pci:3
product: Atom Processor E3800 Series PCI Express Root Port 4
physical id: 1c.3
bus info: pci@0000:00:1c.3
version: 0e
width: 32 bits
clock: 33MHz
resources: irq:19 ioport:2000(size=4096) memory:80800000-809fffff ioport:80a00000(size=2097152)
*-isa
description: ISA bridge
product: Atom Processor Z36xxx/Z37xxx Series Power Control Unit
physical id: 1f
bus info: pci@0000:00:1f.0
version: 0e
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
configuration: driver=lpc_ich latency=0
resources: irq:0
*-serial UNCLAIMED
description: SMBus
product: Atom Processor E3800 Series SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 0e
width: 32 bits
clock: 33MHz
capabilities: pm cap_list
configuration: latency=0
resources: memory:d0814000-d081401f ioport:f000(size=32)
*-scsi:0
physical id: 1
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: ST500LM012 HN-M5
vendor: Seagate
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: 0001
serial: S33RJ5EFB09173
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=cd021324-04e7-4506-8308-209925c0588f logicalsectorsize=512 sectorsize=4096
*-volume:0
vendor: Windows
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
version: 3.1
serial: 200b-17c2
capacity: 449MiB
capabilities: boot precious readonly hidden nomount ntfs initialized
configuration: clustersize=4096 created=2017-07-15 01:01:31 filesystem=ntfs label=Recuperação modified_by_chkdsk=true mounted_on_nt4=true name=Basic data partition resize_log_file=true state=dirty upgrade_on_mount=true
*-volume:1
description: Windows FAT volume
vendor: MSDOS5.0
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /boot/efi
version: FAT32
serial: fc15-568d
capacity: 99MiB
capabilities: boot fat initialized
configuration: FATs=2 filesystem=fat mount.fstype=vfat mount.options=rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro name=EFI System Partition state=mounted
*-volume:2
description: reserved partition
vendor: Windows
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
serial: 765661cd-0453-497f-ace8-69a9baf63e25
capacity: 15MiB
capabilities: nofs
configuration: name=Microsoft reserved partition
*-volume:3
vendor: Windows
physical id: 4
bus info: scsi@0:0.0.0,4
logical name: /dev/sda4
version: 3.1
serial: 56a2c076-5237-7142-9d85-2ab693e8ab93
capacity: 233GiB
capabilities: ntfs initialized
configuration: clustersize=4096 created=2017-07-15 01:02:20 filesystem=ntfs label=Windows name=Basic data partition state=clean
*-volume:4
description: Linux swap volume
vendor: Linux
physical id: 5
bus info: scsi@0:0.0.0,5
logical name: /dev/sda5
version: 1
serial: 9286c90c-25b8-4046-b251-ee6d5f87eb99
capacity: 4078MiB
capabilities: nofs swap initialized
configuration: filesystem=swap pagesize=4095
*-volume:5
description: EXT4 volume
vendor: Linux
physical id: 6
bus info: scsi@0:0.0.0,6
logical name: /dev/sda6
version: 1.0
serial: eccffdcb-8ace-46e9-a869-423ee8e335ec
capabilities: journaled extended_attributes large_files huge_files dir_nlink 64bit extents ext4 ext2 initialized
configuration: created=2017-06-11 18:56:51 filesystem=ext4 label=REMIXOS lastmountpoint=/mnt modified=2017-10-14 01:38:26 mounted=2017-10-14 01:21:48 state=clean
*-volume:6
vendor: Linux
physical id: 7
bus info: scsi@0:0.0.0,7
logical name: /dev/sda7
logical name: /
version: 1.0
serial: fd90e110-d706-434c-bb1c-1275e9f528da
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
configuration: created=2017-07-15 13:42:24 filesystem=ext4 lastmountpoint=/ modified=2017-10-21 18:26:21 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2017-10-21 18:26:26 state=mounted
*-volume:7
vendor: Linux
physical id: 8
bus info: scsi@0:0.0.0,8
logical name: /dev/sda8
version: 1.0
serial: b2eaffb4-927a-4100-940f-70fb2b7109d8
configuration: created=2017-08-02 02:20:34 filesystem=ext4 label=Fedora lastmountpoint=/ modified=2017-10-14 20:47:22 mounted=2017-10-14 23:47:28 state=clean
*-volume:8
vendor: Linux
physical id: 9
bus info: scsi@0:0.0.0,9
logical name: /dev/sda9
version: 1.0
serial: 81e3d592-4889-4aa4-8d50-13e88f1637f2
configuration: created=2017-10-09 20:59:28 filesystem=ext4 label=BigLinux lastmountpoint=/ modified=2017-10-20 21:11:29 mounted=2017-10-20 23:11:34 state=clean
*-scsi:1
physical id: 2
logical name: scsi1
*-cdrom
description: DVD-RAM writer
product: CDDVDW SN-208FB
vendor: TSSTcorp
physical id: 0.0.0
bus info: scsi@1:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
version: SB00
capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
configuration: ansiversion=5 status=nodisc
I’ll await for answers.
Everaldo
