Optional Packages
I would like to install some of the optional packages. Where can I find a list of the ones avaliable and how do i use that command?
Go to Leaf-Menu / Applications / Terminal and type in:
installoptionalpackage -l
You’ll get a list of installed packages and another list with available packages.
If you want to install BeZillaBrowser for example, just type the command in Terminal window as follows:
installoptionalpackage BeZillaBrowser
You can install multiple packages (if needed) by extending the command with all packages you need:
installoptionalpackage ArmyKnife BeZillaBrowser BurnItNow [4th packagename here] [5th packagename here]
and so an...
Hint: Ensure that your internet connection is up before.
prOSy
