Problem solved!
I installed the ThinkFree Office package via pkgman (instead of dropping in home/config/packages); and worked perfectly.
Thank you for your help!
Problem solved!
The above linked hpkg somewhat works in Haiku nightly (hrev47807), thanks.
It does not appear to register mime types, and seems that it does use a horrible font visualization. Anybody else have this problem?
Also while it works with the radeon accelerant, it does not with the intel_extreme or vesa. I do not know why.
It is working great here, with hrev47853 and intel_extreme - I don’t have either of those problems! It does not work in home/config/packages though, you must use system/packages.
It’s awesome - a fully featured office suite for haiku!
