Haiku OS doesn’t boot very fast under Parallels Desktop 14. In syslog I see many package manager errors and kernel error while probing hardware. When checking memory I see that many memory blocks are checked and discarded (which would explain why the ram chip is a slow part in the boot process).
Is it possible to give the kernel a specific configuration so it doesn’t have to discover the hardware all over after each boot? Also: is there is a way to repair package daemon errors? Error in Syslog is “Failed to open package activation file : file not found. Assuming all packages are activated” I only used HaikuDepot to add software, I didn’t kill files manually.
