Hi Friends, I would like to know if there is any support for RTL8111 / 8168/8411 Pci express ethenert controller and also for the audio driver intel corporation 7 Series / c216 Chipset Familiy
It should be, can you post the output of listdev and listusb that would help. Posting the /var/log/syslog file would also help.
I assume you booted up a Haiku live USB or CD and network and sound didn’t work? If not you might want to just give it a try.
To get the data you can use our system analysis Tool beslysat
Nice, i am also doing real hardware testing and after safe mode i have no sound nor network, so i will use this to get the data
thanks, but there is no way to install any software that does not have access to the internet and it is installed in real hardware … I will post here some images of cpu-x in my linux to show the hardware I am using.
description: Desktop computer
product: To be completed by O.E.M. (To be completed by o.e.m.)
manufacturer: To be completed by O.E.M.
version: To be completed by O.E.M.
serial: To be completed by O.E.M.
width: 64-bit
: smbios-2.7 dmi-2.7 smp vsyscall32
configuration: boot = normal chassis = desktop family = To be completed by O.E.M. sku = To be completed by O.E.M. uuid = 00020003-0004-0005-0006-000700080009
*-a testimony
description: Motherboard
product: MAHOBAY
manufacturer: INTEL Corporation
Physical ID: 0
slot: To be filled in by O.E.M.
- -firmware
description: BIOS
manufacturer: American Megatrends Inc.
Physical ID: 0
version: 4.6.5
date: 04/24/2013
capacity: 2496 KiB
sound: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb biosbootspecification uefi - -cache: 0
Description: L2 cache
Substance ID: 3d
slot: Internal CPU L2
capacity: 512KiB
Features: Unified internal write-through
setting: level = 2 - -cache: 1
description: L1 cache
Substance ID: 3e
slot: Internal CPU L1
capacity: 128KiB
Features: Internal write-through data
configuration: level = 1 - -cache: 2
description: L3 cache
Substance ID: 3f
slot: Internal CPU L3
capacity: 2MiB
resources: unified internal write-back
configuration: level = 3
*-memory
description: System Memory
slot: System board or motherboard
- bank: 0
Description: DIMMProject-Id-Version: lshwReport-Msgid-Bugs-To: COMPLETE NAME Date-Revision-EN: 2013-04-07 17: 30 + 0000Last-Translator: Neliton Pereira Jr. <nelitonpjr @ gmail .com> Language-Team: Brazilian Portuguese pt_BR@li.org MIME-Version: 1.0Content-Type: text / plain; charset = UTF-8Content-Transfer-Encoding: 8bitX-Launchpad-Export-Date: 2018-07-31 11: 14 + 0000X-Generator: Launchpad (build 18737) [empty]
product: [empty]
manufacturer: [Empty]
Physical ID: 0
serial: [Empty]
slot: ChannelA-DIMM1
- bank: 0
- bank: 1
Description: DDR3 DIMM Synchronous 1333 MHz (0.8 ns)
product: U3A4G93-13G9BE3B00
manufacturer: Hitachi
Substance ID: 1
serial: 00000000
slot: ChannelB-DIMM1
width: 64-bit
clock: 1333 MHz (0.8 ns)
- bank: 1
- -CPU
description: CPU
Product: Intel® Celeron® 847 @ 1.10GHz Processor
manufacturer: Intel Corp.
Substance ID: 41
Bus info: cpu @ 0
version: Intel ® Celeron ® CPU 847 @ 1.10GHz
slot: SOCKET 0
capacity: 3800MHz
width: 64-bit
clock: 100MHz
: x86-64 fpu fpu_exception wp vme de pse tsc msce pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pb syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer xsave lahf_lm epb pti ssbd ibbs ibpb stibp tpr_shadow vnmi flexpriority ept vpid xsaveopt dtherm arat pln pts flush_l1d cpufreq
configuration: cores = 2 enabledcores = 2 threads = 2 - -pci
description: Host bridge
Product: Second Generation Core Processor Family DRAM Controller
manufacturer: Intel Corporation
Physical ID: 100
bus info: pci @ 0000: 00: 00.0
Release Date: 09
width: 32 bits
clock: 33MHz
*-exhibition
description: VGA compatible driver
product: Integrated graphics controller of the family of second generation processors
Substance ID: 2
Bus info: pci @ 0000: 00: 02.0
Release Date: 09
width: 64-bit
clock: 33MHz
resources: msi pm vga_controller bus_master cap_list rom
configuration: driver = i915 latency = 0
Resource: irq: 26 memory: f7800000-f7bfffff memory: e0000000-efffffff I / O port: f000 (size = 64) memory: c0000-dffff
Hello, but on the internet it must have a life of its own … Tomorrow morning it worked … do not ask me how … but I ended up discovering my sound controller. is a 7 series chipset / high definition audio family c216
Some HDA controllers require correct channel mapping which Haiku doesn’t do correctly. However, booting into another OS first, then booting into Haiku leaves the HDA controller with the correct mapping. This is the recommended practice is to warm boot Haiku on these systems (in order to get HDA sound)
up and down up and down
no sound
Yes…no sound
Did you try installing the OpenSound package? (only available for 32 bit)
