I just installed Haiku on my old PC. However i cannot see my network card. In the network the list of devices is empty. It is my first try of Haiku (alpha). The ethernet card has been manufactured by pentagram and it is using Realtek chip RTL 8139d chip.
My Haiku system is packed away so I am not sure if there is /dev/network. Does this exist?
Since you do not have driver in /dev/net then the driver is not loading with your card.
You should file a bug report http://dev.haiku-os.org.
Include listdev output, same as you have above, include syslog ( from /var/log ), state Haiku revision and the issue you have.
First though, try a recent nightly image to see if that works for you.
Great to hear you found another solution. Reporting the bug first and trying to get it fixed would have been better because it may have helped others out. Anyways, enjoy your Haiku install.
KERN: rtl8139: no hardware found.
KERN: rtl81xx: no hardware found.
Haiku has two Realtek drivers (those listed above), each handles specific Realtek network cards. Neither one recognizes your card as supported.
File bug report to have a developer look into it and fix this issue with Realtek driver. Include syslog & listdev output & mention nothing under /dev/net & no network adapter in preferences & Haiku revision. Regards,
EDIT:
For some reason the vendor id was incorrect on your first post
KERN: PCI: vendor 00ec: Unknown
Should have been 10ec (for Realtek). Not sure why this would happen if you did a copy of syslog to your forum post. Strange.
no, made by pentagram should not matter. The driver looks for vendor & device ids (chipset based - example: Realtek 8139), those that you posted above from listdev & syslog. your vendor id: 10ec, device id: 8139
from memory, the rtl8139 driver is haiku native network driver. They still use this for 8139 cards. The rtl81xx is bsd driver and has 8139 card commented out.
These drivers are built with Haiku (part of the OS). Either, the rtl8139 driver has to be fixed, if that is the issue or switch to rtl81xx (by letting it handle 8139 too).
There could also be something happening with your hardware that is causing it to fail - may not be driver issue. For instance, I’ve seen 2 people say turning on PXE, SmartLAN in BIOS solved their network issue. Turning off Plug & Play OS might help too, etc.
You should report it to have a developer look into it further to check the driver since I’m guessing you had this issue with 2 revisions of Haiku.
It was simpler for me to change the motherboard. Now i ma using Asrock board with integrated via rhine network card and it seems to work just fine in fact i am now writing form my Haiku host
The problem might have been the shity motherboard (it sometimes failed to boot) so instead of starting a fire (that something is wrong with the system) i just switched to more reliable motherboard. I am now running BOINC on Haiku
“The problem might have been the shitty motherboard (it sometimes failed to boot)”
Alright, true if it had problems booting it was unreliable to start with. ( I’ve had this problem too on 1 or 2 motherboards and it was blown/bulging capacitors but it could be anything ).
I have already read that No i am planning to port another project on Haiku Because SETI is not enough It might be a little problem, as i never did it before and i use haiuk only for 3 days
