No network as qemu guest
Creating a Haiku guest VM in Virt Manager.
  • tried E1000, Virtio and rtl8139
  • did a complete re-install with each adapter change
The network panel reports the name of the device correctly (e.g., Virtio) but cannot reach internet or ping LAN.
I notice in the network panel, IP4 shows DHCP selected but no IP address.
FWIW, I have internet on the host, and I have other VMs that run ok.
Any suggestions?
Bottom of this page could be of some interest…
Thanks @Starcrasher, I did examine that page but the “User Mode” setting is absent in Virt Manager.
I have generally good experiences with Qemu (edit: without VirtManager) And maybe it’s important which host OS.
Greetings
Peter
@PeterW maybe so. Since I can spin up Linux guests on this system with the same settings makes me look at Haiku though.
Is there any network config I’m overlooking in Haiku? I can see the adapter in Haiku – for example, it says ‘virtio’ in Haiku and even says ‘connected’ – but I don’t seem to have an IP in Haiku.
I also have a similar issue — the network comes on and off, displaying the connection status notification permanently refreshing.
If nobody else has a clever solution (network experts?), I think it is a Haiku bug (both @phalange and @bitigchi).
Greetings
Peter
@PeterW thanks for your responses, bug report submitted.17868
Hmmm. Got the same problem. In fact, it is caused by firewalls. I had to tweak things a bit and now it is working. For example, on a Mageia, with Shorewall I had to do this
