No bootable drive after installation
I have an old notebook (Dell Inspiron 3521) which I decided to revive. It got additional 4GB of RAM (now 8GB) and I switched HDD with 240GB SSD. It should be quite usable now.
So I have installed Haiku without problems. But when I try to run it just gives a message about no bootable drive.
I found this topic:
so I tried what @nephele suggested there (even thou I created the partition from scratch in the haiku installer) marking Tools-> Write boot sector at the end of the installation. The other thing mentioned by @nephele (marking it as active) I did not do, as I could not find this option anywhere.
Above tries were done with BIOS/UEFI set as Legacy (and in this mode this notebook worked in 3 different Linux distributions over those 11 years of its existance, I wiped out Windows the same day I bought the machine) So I changed setting to UEFI, but then after installation it just gives “Unknown device” 2 times and halts.
How can I boot Haiku, preferably in Legacy mode, but if UEFI is the only option, let it be.
You don’t ever need “write boot sector” If you created the partition table yourself. This is only neccesary if you do something wierd like keeping a partition table and at the same time replace a bootloader like grub that uses a non-standard mbr.
You do however need to set the partition as active.
Check the “creating a partition” section:
Haiku boots!
Thank you.
