Neutralino.js port attempt
The following quote from the .NET thread got this started.
In my first attempt at porting Neutralino, I attempted to target WebKit_GTK and GTK3 using the existing build infrastructure but BuildZri v1.0.0 didn’t have a clue how to build on Haiku. I tried hotwiring it to think that it was just a flavor of Linux but it wasn’t close enough. The build failed.
The following dependencies are assumed on the Linux build:
  • xrandr
  • xcb
  • WebKit2GTK+ v4
It appears there will be no easy shortcuts on this build. I (or someone else) will have to go through the Python3 build script. If anyone else is interested, the repo is at:
The build instructions are at:
It is necessary to add Haiku; compiler and cpu architecture in BuildZri code:
Neutralinojs uses libraries with Haiku support:
https://github.com/search?q=repo%3Aneutralinojs%2Fneutralinojs%20haiku&type=code
I know. That is what I was concerned about. Having to set up a from-scratch implementation of the build-script, I might as well write it as a HaikuPorter recipe and forget their build script. I’ll still refer to theirs though.
Update:
I just realized that there is a libxcb_devel package in HaikuPorts along with its dependencies. That got a little farther with the fake Linux build. Unfortunately libxrandr is not ported to Haiku so that still didn’t do it. I’ll try to keep tinkering.
libxrandr-devel contains header file and library, it’s an X11 extension, probably depends on Xlibe to work:
https://mageia.pkgs.org/8/mageia-core-release-x86_64/lib64xrandr-devel-1.5.2-2.mga8.x86_64.rpm.html
It would seem that XLibE doesn’t support that extension at this time.
Part of the Infoware code is used, which uses Xrandr for display:
It would modify displays_x11.cpp file for Haiku or create a file for app_server!
