I was playing around and added the Network Status applet to my desktop as a replicant. I am trying to remove it. When this applet is located in the deskbar. Bringing up the context menu, there is an option at the bottom, under “Open Network Preferences” that says “Quit”. That “Quit” option is not listed when it is running as a replicant on the desktop. The list stops at “Open Network Preferences” How do I remove this from my desktop?
As you can see in the user guide, there’s a little handle at bottom right corner.
The right click menu is hidden there. You can also grab it by the handle and move it to trash.
Thanks, I didn’t know I could just move it to the trach. Honestly I should have thought of trying that.
