Def something funny going on. Dont think its the dns, as ping to various outfits works just fine.
My syslog is huge…
Quite a lot of rubbish coming from the network part of the log.
Appologies for posting a bit of the syslog.
KERN: package_daemon [16526928: 292] Volume::InitialVerify(0xfebe6db960, (nil))
KERN: package_daemon [16545157: 292] Volume::InitialVerify(): volume at “/boot/home/config” is consistent
KERN: sis19x:00.16.700:init_hardware::SiS19X:init_hardware()
KERN: register_domain(5, internet6)
KERN: unregister_domain(0xffffffff905ebe00, 5, internet6)
KERN: unregister_domain(0xffffffff905ebd00, 5, internet6)
KERN: register_domain(1, internet)
KERN: unregister_domain(0xffffffff905ebd00, 1, internet)
KERN: register_domain(9, unix)
KERN: unregister_domain(0xffffffff905ebd00, 9, unix)
KERN: unregister_domain(0xffffffff905eb580, 5, internet6)
KERN: usb_hid: no handlers for hid device
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/input/usb_hid
KERN: unregister_domain(0xffffffff905eb200, 1, internet)
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/input/wacom
KERN: ps2_hid: init_hardware
KERN: ps2_hid: init_driver
KERN: unregister_domain(0xffffffff905b1d80, 5, internet6)
KERN: unregister_domain(0xffffffff905b1d80, 1, internet)
KERN: unregister_domain(0xffffffff905b1d80, 9, unix)
KERN: ps2_hid: publish_devices
KERN: ps2_hid: uninit_driver
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/input/ps2_hid
KERN: [net/broadcom570x/0] compat_open(0x2)
KERN: slab memory manager: created area 0xffffffff91801000 (4247)
KERN: ifmedia_ioctl: switching bge to KERN: Type: Ethernet
KERN: SubType: autoselect
KERN: ps2: reset failed
KERN: ps2: devfs_publish_device input/mouse/ps2/0, status = 0xffffffff
KERN: ps2: devfs_publish_device input/keyboard/at/0, status = 0x00000000
KERN: /dev/net/broadcom570x/0: media change, media 0x22 quality 1000 speed 10000000
KERN: ps2: keyboard reset failed, status 0x80000001, data 0xff
KERN: ps2: keyboard probing failed
KERN: KeyboardDevice: error when opening /dev/input/keyboard/at/0: No error
KERN: ps2: devfs_unpublish_device input/keyboard/at/0, status = 0x00000000
KERN: usb_hid: keyboard device unhandled control 0x00002710
DAEMON ‘transmission-daemon’[378]: Transmission 2.94 (d8e60ee44f) started (/sources/transmission-2.94/libtransmission/session.c:740)
DAEMON ‘transmission-daemon’[378]: RPC Server Adding address to whitelist: 127.0.0.1 (/sources/transmission-2.94/libtransmission/rpc-server.c:971)
DAEMON ‘transmission-daemon’[378]: RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (/sources/transmission-2.94/libtransmission/rpc-server.c:1213)
DAEMON ‘transmission-daemon’[378]: RPC Server Whitelist enabled (/sources/transmission-2.94/libtransmission/rpc-server.c:1217)
DAEMON ‘transmission-daemon’[378]: DHT Reusing old id (/sources/transmission-2.94/libtransmission/tr-dht.c:307)
DAEMON ‘transmission-daemon’[378]: DHT Bootstrapping from 116 IPv4 nodes (/sources/transmission-2.94/libtransmission/tr-dht.c:156)
DAEMON ‘transmission-daemon’[378]: Using settings from “/boot/home/config/settings/transmission-daemon” (/sources/transmission-2.94/daemon/daemon.c:528)
DAEMON ‘transmission-daemon’[378]: Saved “/boot/home/config/settings/transmission-daemon/settings.json” (/sources/transmission-2.94/libtransmission/variant.c:1266)
DAEMON ‘transmission-daemon’[378]: Loaded 3 torrents (/sources/transmission-2.94/libtransmission/session.c:2034)
KERN: /dev/net/broadcom570x/0: media change, media 0x900030 quality 1000 speed 1000000000
KERN: register_domain(4, link)
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Send DHCP_DISCOVER to 255.255.255.255:67
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Send DHCP_REQUEST to 255.255.255.255:67
DAEMON ‘transmission-daemon’[378]: Port Forwarding State changed from “Not forwarded” to “???” (/sources/transmission-2.94/libtransmission/port-forwarding.c:92)
KERN: bfs: bfs_create_index:2135: File or Directory already exists
KERN: emuxki: init_hardware()
KERN: emuxki: init_driver()
KERN: mpu401: B_MODULE_INIT
KERN: pci_reserve_device(1, 10, 0, emuxki)
KERN: emuxki: setup_emuxki(0xffffffff915ac140)
KERN: emuxki: audio/hmulti/emuxki/1 deviceid = 0x04 chiprev = 4 model = 2002 enhanced at 9400
KERN: emuxki: PCI command before: 5
KERN: emuxki: PCI command after: 5
KERN: emuxki: codec reset
KERN: emuxki: codec vendor id = 0x83847650
KERN: emuxki: codec description = SigmaTel
KERN: emuxki: codec 3d enhancement = SigmaTel
KERN: emuxki: writing codec registers
KERN: emuxki: codec master output = 0x00
KERN: emuxki: codec aux output = 0x00
KERN: emuxki: codec mono output = 0x8000
KERN: emuxki: codec pcm output = 0x808
KERN: emuxki: codec line in = 0x8808
KERN: emuxki: codec record line in= 0x404
KERN: emuxki: codec record gain = 0x8000
KERN: emuxki: installing interrupt : 10
KERN: emuxki: setup_emuxki done
KERN: emuxki: publish_devices()
KERN: emuxki: publish midi/emuxki/1
KERN: emuxki: publish audio/hmulti/emuxki/1
KERN: emuxki: emuxki: find_device(midi/emuxki/1)
KERN: emuxki: emuxki: find_device(audio/hmulti/emuxki/1)
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/audio/hmulti/emuxki
KERN: echo3g: init_hardware()
KERN: echo3g: no card found
KERN: auvia: init_hardware()
KERN: auich: init_hardware()
KERN: sis7018:init_hardware:ver:2.0.2
KERN: emuxki: emuxki_pmem_alloc : numblocks : 1
KERN: emuxki: emuxki_pmem_alloc : 0
KERN: emuxki: emuxki_pmem_alloc : j == numblocks 1
KERN: emuxki: emuxki_pmem_alloc : j == numblocks emuxki_mem_new ok
KERN: emuxki: emuxki_pmem_alloc : j == numblocks returning
KERN: emuxki: emuxki_pmem_alloc : 1
KERN: emuxki: emuxki_pmem_alloc : 2
KERN: emuxki: emuxki_pmem_alloc : 3
KERN: emuxki: emuxki_pmem_alloc : 4
KERN: emuxki: set_enabled_channels 0 : enabled
KERN: emuxki: set_enabled_channels 1 : enabled
KERN: emuxki: set_enabled_channels 2 : enabled
KERN: emuxki: set_enabled_channels 3 : enabled
KERN: emuxki: name : Record
KERN: emuxki: multi->control_count 67
KERN: Highpoint-IDE: supports_device()
Last message repeated 1 time
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/bus/usb_raw
KERN: /dev/net/broadcom570x/0: media change, media 0x900026 quality 1000 speed 10000000
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Received DHCP_OFFER from 192.168.1.1
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Received DHCP_NACK from 192.168.1.1
DAEMON ‘DHCP’: your_address: 192.168.1.109
DAEMON ‘DHCP’: server: 192.168.1.1
DAEMON ‘DHCP’: lease time: 60 seconds
DAEMON ‘DHCP’: subnet: 255.255.255.0
DAEMON ‘DHCP’: gateway: 192.168.1.1
DAEMON ‘DHCP’: nameserver[0]: 192.168.1.1
DAEMON ‘DHCP’: domain name: “dlinkrouter”
DAEMON ‘DHCP’: UNKNOWN OPTION 60 (0x3c)
DAEMON ‘DHCP’: UNKNOWN OPTION 125 (0x7d)
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Send DHCP_REQUEST for 192.168.1.109 to 255.255.255.255:67
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Received DHCP_ACK from 192.168.1.1
DAEMON ‘DHCP’: lease time: 28800 seconds
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: DHCP status = No error
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Ignoring DHCP_OFFER not for us from 192.168.1.1
DAEMON ‘DHCP’: /dev/net/broadcom570x/0: Ignoring DHCP_ACK not for us from 192.168.1.1
KERN: acquire_advisory_lock(vnode = 0xffffffff90
c65280, flock = 0xffffffff9168aeb0, wait = no)
KERN: acquire_advisory_lock(vnode = 0xffffffff90c7b180, flock = 0xffffffff9168aeb0, wait = no)
KERN: Last message repeated 14 times.
KERN: Disabling unhandled io interrupt 9
KERN: vm_soft_fault: va 0xbbadb000 not covered by area in address space
KERN: vm_page_fault: vm_soft_fault returned error ‘Bad address’ on fault at 0xbbadbeef, ip 0x1aa71dc1f7c, write 1, user 1, thread 0xa3a
KERN: vm_page_fault: thread “WebCore: Worker” (2618) in team “WebPositive” (1393) tried to write address 0xbbadbeef, ip 0x1aa71dc1f7c (“libJavaScriptCore.so.18.7.4_seg” +0xe0ef7c)
KERN: debug_server: Thread 2618 entered the debugger: Segment violation
KERN: vm_page_fault: vm_soft_fault returned error ‘Bad address’ on fault at 0xbbadbeef, ip 0x1aa71dc1f7c, write 1, user 1, thread 0xa38
KERN: vm_page_fault: thread “WebCore: Worker” (2616) in team “WebPositive” (1393) tried to write address 0xbbadbeef, ip 0x1aa71dc1f7c (“libJavaScriptCore.so.18.7.4_seg” +0xe0ef7c)
KERN: vm_page_fault: vm_soft_fault returned error ‘Bad address’ on fault at 0xbbadbeef, ip 0x1aa71dc1f7c, write 1, user 1, thread 0xa3b
KERN: vm_page_fault: thread “WebCore: Worker” (2619) in team “WebPositive” (1393) tried to write address 0xbbadbeef, ip 0x1aa71dc1f7c (“libJavaScriptCore.so.18.7.4_seg” +0xe0ef7c)
KERN: low resource memory: normal -> critical
KERN: stack trace, current PC 0x1aa71dc1f7c WTFCrash + 0x1c:
KERN: (0x7f7bf7385250) 0x1aa71d02cdd _ZN3JSC4Wasm6Memory6createENS0_9PageCountES2_ON3WTF8FunctionIFvNS1_14NotifyPressureEEEEONS4_IFvNS1_16SyncTryToReclaimEEEEONS4_IFvNS1_11GrowSuccessES2_S2_EEE + 0xa9d
KERN: (0x7f7bf7385330) 0x1aa71d4c31a _ZN3JSCL28constructJSWebAssemblyMemoryEPNS_9ExecStateE + 0x42a
KERN: 0xffffffff90e4d750->VMAnonymousCache::_Commit(4303355904): Failed to reserve 4303355904 bytes of RAM
KERN: low resource memory: critical -> warning
KERN: (0x7f7bf73853b0) 0x76c1fa74 (mmap area + 0x3b4a74)
KERN: vm_page_fault: vm_soft_fault returned error ‘Bad address’ on fault at 0xbbadbeef, ip 0x1aa71dc1f7c, write 1, user 1, thread 0xa3c
KERN: vm_page_fault: thread “WebCore: Worker” (2620) in team “WebPositive” (1393) tried to write address 0xbbadbeef, ip 0x1aa71dc1f7c (“libJavaScriptCore.so.18.7.4_seg” +0xe0ef7c)
KERN: (0x7f7bf73853c0) 0x1aa7198f177 llint_entry + 0x7478 (closest symbol)
KERN: (0x7f7bf7385460) 0x1aa71987b17 vmEntryToJavaScript + 0x130 (closest symbol)
KERN: (0x7f7bf73854d0) 0x1aa7192e071 _ZN3JSC7JITCode7executeEPNS_2VMEPNS_14ProtoCallFrameE + 0x61
KERN: (0x7f7bf7385500) 0x1aa719044be _ZN3JSC11Interpreter14executeProgramERKNS_10SourceCodeEPNS_9ExecStateEPNS_8JSObjectE + 0x9fe
KERN: (0x7f7bf7385f20) 0x1aa71b036cc _ZN3JSC8evaluateEPNS_9ExecStateERKNS_10SourceCodeENS_7JSValueERN3WTF8NakedPtrINS_9ExceptionEEE + 0xec
KERN: (0x7f7bf7385f80) 0x1ce72d3c98a _ZN7WebCore22WorkerScriptController8evaluateERKNS_16ScriptSourceCodeERN3WTF8NakedPtrIN3JSC9ExceptionEEEPNS4_6StringE + 0x9a
KERN: (0x7f7bf7386010) 0x1ce72d3cc8a _ZN7WebCore22WorkerScriptController8evaluateERKNS_16ScriptSourceCodeEPN3WTF6StringE + 0x4a
KERN: (0x7f7bf7386050) 0x1ce737481fb _ZN7WebCore12WorkerThread12workerThreadEv + 0x35b
KERN: (0x7f7bf7386140) 0x1aa71ddfc3c _ZN3WTF6Thread10entryPointEPNS0_16NewThreadContextE + 0x6c
KERN: (0x7f7bf7386170) 0x1aa71e138b9 _ZN3WTFL19wtfThreadEntryPointEPv + 0x9
KERN: (0x7f7bf7386180) 0x1078bd62709 ZL20pthread_thread_entryPvS + 0xb
KERN: low resource memory: warning -> note
KERN: debug_server: Killing team 1393 (/boot/system/apps/WebPositive)
KERN: debug_server: TeamDebugHandler::Init(): Failed to get info for team 1393: Operation on invalid team
KERN: debug_server: KillTeam(): Error getting info for team 1393: Operation on invalid team
KERN: debug_server: Killing team 1393 ()
KERN: low resource memory: note -> normal
KERN: acquire_advisory_lock(vnode = 0xffffffff90c65280, flock = 0xffffffff9172aeb0, wait = no)
KERN: acquire_advisory_lock(vnode = 0xffffffff90c7b180, flock = 0xffffffff9172aeb0, wait = no)KERN: Last message repeated 14 times.
KERN: Last message repeated 2 times.
KERN: acquire_advisory_lock(vnode = 0xffffffff90c65280, flock = 0xffffffff9161ceb0, wait = no)
KERN: acquire_advisory_lock(vnode = 0xffffffff90379700, flock = 0xffffffff9161ceb0, wait = no)
KERN: bfs: Remove:2125: No such file or directory
KERN: bfs: Could not find value in index “size”!
KERN: bfs: Could not find value in index “last_modified”!
