Hi All,
I just installed Haiku in virtualbox. But unfortunately it is not detecting the network card. Any suggestions how can I fix it?
Regards
Tiklu
Hi All,
Regards
Tiklu
Have you tried the suggestions in the troubleshooting chapter of the VirtualBox guide?
Hi Richie,
Thanks for the link you sent. I will test it today as soon as I reach home. And will update.
Regards
Tiklu
Unless you installed a nightly build, you will need to change the NIC to “Intel PRO/1000 MT Desktop” since the default one doesn’t not have a driver in R1/alpha3.
Hi Richie,
Thanks buddy, your suggestion just worked and now I am getting full network in my Haiku box. Next step try to compile mono.
Regards
Tiklu
