Nwe on the FatElk repo:
http://fatelk.com/.../netfs_control-1.0.1.0-1-x86_gcc2.hpkg see http://fatelk.com/NetFS or http://fatelk.com/repo/packages for info.
*note: Web+ has issues with the fatelk.com site due to re-direction.
I have installed and start up your program but i does not understand it. Can you try to make it a little bit self declaring, using tooltips, Infos, add the link to the tutorial into the program (menu).
Its clear design, i like it
Greetings Lelldorin
Very nice.
We probably should integrate this into Tracker in some way eventually.
I updated the program to include a help button… http://fatelk.com/repo/packages/netfs_control-1.0.2.0-1-x86_gcc2.hpkg
Ok i have seen the documentation, but why you make the window so smal? you have enough place to show it. The user should read it more confortable.
