I installed new OS, beta2, installed in Depot - Qt5.
And tried to run CudaText for Haiku x32.
Archive XZ is here http://uvviewsoft.com/c/
I cannot run it yet, I always get error like “cannot find libQt5Pas.so.1” -
this file is present in my package and I even copied it to
Packages are created at http://github.com/haikuports/haikuports if you want to include them in our package manager. Their wiki has a rather complete documentation on how to write a recipe file, and you can submit your work in progress as a pull request there if you need help getting it to work.
If you want to distribute hpkg files yourself, you can also create one manually using the ‘package’ command from Terminal.
