HaikuWebKit 1.9.6 was released.
- WebKit 616.1.22 (current, 7/19/2023)
Buildmaster(s) are stuck atm, so it’s not yet available.
So you want to help with WebKit?
I heard that some more people may be interesting in helping with WebKit. So here is a summary of the current state, the things I think need work, or the possible future paths to explore.
Keeping WebKitLegacy up and running
The Web moves fast these days. So we have to stay very up to date with upstream WebKit. Until we have a nice and shiny WebKit2 browser, and, anyways, even after that, we need to keep things up to date.
Currently I take care of this myself. The reason is, it involves merging changes from upstream with our branch, and that’s pretty much impossible to review as a Github pull request (it would show everything that’s changed in the upstream WebKit code, which is usually a lot).
Anyways, here’s how I do it:
There are usually some function that have changed prototype and the Haiku implementation needs to be updated, and the occasional merge conflict in one of the few files that have specific code for multiple platforms (typically we just add || OS(HAIKU) to existing cases, but there are a few places where we have to do our own thing.
This brings me to the next two topics…
Upstreaming our changes
A lot of Haiku specific code is maintained in our fork of the WebKit repository. The reason for this is I never took the time to upstream all these things. There are no easily extracted commits (because the only way to keep up with upstream is to use merge instead of rebase), and as a result, the relevant changes have to be manually re-done as separate, nice and clean commits that upstream will accept (hopefully).
The process is something like this:
Where to start with the upstreaming changes: probably WebCore, WTF and JavaScriptCore. If we start submitting anything substantial, the WebKit upstream will require us to provide a buildbot to build our code. That is then used to build patches submitted to their bugzilla or github, and verify that the code does not break our build.
Until we get this working, we can still submit changes that fix cross-platform code (there are a handful of these in our fork), or that just add Haiku to the list of OS using a specific codepath. Which are also the ones more likely to cause problem when merging upstream changes, so that would still be very helpful.
Merging the code in the WebKitLegacyDirectory is probably not going to happen since upstream is slowly removing that directory (only the iOS port still has it, to run very old iOS apps that need the legacy API).
Fixing and improving the test suite
This is a bit more complex work and requires in-depth investigation of problems.
WebKit comes with several thounsands of tests. Normally, every bug fix or change should be submitted with a corresponding test.
These are non-regression tests, and, in the cross platform and configurable nature of WebKit, there is no hope that all tests will ever run on all platforms and configurations. So, the idea is that there is a “TestExpectations” file for each platform, that can define which tests to skip (because the feature is not implemented and there’s no point), which are expected to fail, which are expected to pass. After making a change, a developer can then run the tests and see if anything was broken or fixed. The bots on WebKit build infrastructure also check for this, and when someone submit a patch, they will warn if tests were broken (or fixed without updating the TestExpectations files).
The testsuite used to run on Haiku, but last time I tried it it completely crashed my machine (probably an app_server crash), and also I ran into problems with Debugger. The testsuite runs one process per core, and configures debug_server to save debug reports if any of them crash. However, Debugger gets very confused if we ask it to save multiple debug reports at the same time. As a result, we end up with several instances of Debugger trying to save debug reports, and eventually the system runs out of memory. Fixing this would be great, because then, the testsuite would have more chances to run.
Experimenting with cross-platform code
The current implementation of WebKit for Haiku tries very hard to use the native APIs for everything. We have scaled back for now on the HTTP implementation, and are using cURL for that (it fixed several bugs compared to our own HTTP library). But for everything else, and in particular for all graphic rendering, we use offscreen BBitmap and BView.
It would be interesting to experiment with using cairo. This can easily be done beind a compile time option (mainly disabling the Haiku specific drawing code when the Cairo one is enabled). There is some integration needed so that in the end, cairo renders to a BBitmap that can be send on screen as usual.
It would be interesting to have this as an option, even if only to compare the rendering and decide if bugs are on WebKit side or in our platform specific code. But it would also fix several problems/limitations of the current drawing code: lack of support for shadows, for font ligatures, for some drawing compositing modes, etc.
The web inspector
WebKit codes with a web inspector. This is mostly implemented as an html/javascript app, that interfaces with the WebKit core and allows to inspect the content of pages. Surely this would be helpful to debug some of the rendering issues. It is “almost completely” implemented, I am not sure what is missing, but I think not a lot.
There is also a “remote inspector” that allows to connect from another machine (used on the iOS version, because running the web inspector on an iPhone is no fun, and similarly in game consoles, embedded systems, …), maybe that is worth exploring too but I have not researched it a lot.
Working on WebKit2
WebKit2 is a new interface to the WebKit engine that runs several parts of the code in different processes. There is at minimum a “web” process that does the html/css/javascript, an “UI” process that does the display (that’s the actual web browser), and a “network” process that does, well, all the network things.
This allows the web browser to be a lot less complicated and just communicate with the other processes. It also means the browser is unlikely to completely crash, instead, most likely the web process will crash, which does not imply losing your list of open tabs, non-saved cookies, etc. It also allows to run multiple web processes, for example, one per browser tab, so the whole browser is not completely frozen when one tab crashes.
Most of the work to get this built and a simple testing browser on top of it has already been done (by Rajagopalan Gandhagaran in Google Summer of Code). However, the code needed a lot of cleanup, and is now several years behind. I have a branch that I rebase every few months with an up to date but non-working version of this code. The main problem is the way the different processes establish connections between each other. Basically the expectation is that the web process creates a socketpair() (similar to a pipe(), but with UDP-like datagram behavior), and then passes each end of the socketpair to the two other processes, and the connection between the UI and network process is establised in this way. Passing file descriptor to the other processes is possible, but in the current attempt to implement WebKit2, we had decided to use BLooper/BMessage instead. So, it would mean that the web process needs to create a BMessenger targetting a BLooper in another app that it knows nothing about (and the other app may even not be running yet). This seems just about possible, but we may need some new APIs here or just do some workaround/hack instead.
Unfortunately, I am busy with many other things and I have been unable to work at this problem long enough to fit it all in my mind and find a solution. I can only look at it every few months, and by the time I have reloaded all the info in my mind, I run out of time again. So, help on investigating this and getting it up and running would be great.
There is also another option here: as mentioned, the other platforms use a socketpair(). We have an implementation of that now, so we could just as well stop trying to push BMessage beyond what they are supposed to do, and use socketpairs like everyone else. This would allow to run WebKit2 with a lot less platform specific code to write, since we could use the “Unix” variant of most stuff (MainProcessUnix, etc) instead of having to write our own. However, it creaet the possible issue that the main thread will not be a BApplication, and, at least for the UI Process (the web browser, that needs to open BWindows to interact with the user), that might be a problem. Or maybe it will work just fine, I’m not really sure.
Continuing the work to merge the webkitlegacy and webkit2 branches
There is normally no conflict between WebKit2 and WebKitLegacy. They can be enabled separately or together, and the cmake build will take care of configuring and building everything. However, our current WebKit2 branch also has a number of hacks and work-in-progress things in shared directories (for example, adding a lot of tracing in WebCore classes around the process initialization). It would be great to get all this code cleaned, rebased, and ready for merging into the WebKitLegacy branch. This way we would have only one branch to maintain, instead of two, making both the upstream merging/rebasing and the submission of patches to upstream a lot easier.
The indentation is also all over the place (in both branches, really) due to Haiku and WebKit not agreeing on the Great War of Space vs Tabs, and I think the decision that all .h files for WebKitLegacy providing the public API that Haiku apps can use would follow Haiku coding guidelines, while everything else would follow WebKit style. This is a bit confusing and hard to maintain.
Certainly not the most exciting work: rebasing changes, cleaning indentation, cleaning commit history and removing debug traces or splitting them to separate commits. But, it would be very helpful.
I hope this gives a good overview of the needed work, and also that a lot of it is caused by decisions and problems on our side, and not at all the fault of WebKit upstream. I also hope it inspires more people in having a go at it and see if they can fix one or two small things.
In any case, thanks for reading this to the end! ![]()
Keeping all this on track with upstream is a monster of a job, we should all be proud on the work you are doing (and did) to keep this going, big thanks from here!!! ![]()
EDIT: don’t wont to forget all the other people stepping in from time to time here, big thanks!!! ![]()
This represents indeed an insane amount of work done silently months after months.
I understand that manpower is the main problem but, is there anything people could do to help, outside of the webkit work? For example, add a feature to an Haiku kit or to Genio (if you use it) in order to make things easier, at least less painful.
I do all my work with Vim, and I have no plans to switch to anything else ![]()
Any help is welcome. There are several dozen bugs reported against WebKit and WebPositive in haiku bugtracker. Some of them are not directly related to WebKit, for example, the problems with font ligatures (leading to the icon misrendering in Gerrit) is more of an app_server problem, I think? @madmax would know better, he did a lot of very helpful work in the font rendering side of things already.
On WebPositive itself, there are also many small changes that can be done that do not really need touching the WebKit engine, or just simple changes: for example, fixing the right click popup menu which has an hardcoded “Search with Google” instead of searching with the default configured search engine.
Making small reproducers for WebKit rendering bugs (instead of having to chase a problem in a very complicated webpage) can also be helpful.
Outside of WebKit, really, anything that fixes bugs so I don’t have to investigate them myself. Somewhere near the top of my TODO list currently:
Really, anything that improves Haiku helps me
So thanks to everyone who works on all these things.
The only thing that is not very helpful to me is porting more and more browsers to Haiku. Over the years I have seen many of them be ported and then abandoned to move on the next new one, for several reasons.
Yep. No ligature (or other substitutions and modern font features) in app_server interface that I know of. Even when a full string is sent for drawing we pick each character apart and take its glyph with no context. Also the source of problems for complex scripts.
There are also bugs hidden in some areas of the app_server, stuff you only trigger when you use several of its features at the same time, the kind of thing you might see in WebKit and nowhere else. Like the rendering issues in blocks with transparency and transforms, some of which are due to app_server bugs, at least in part.
So yes, you don’t have to work directly with WebKit code to improve it.
And yes, I can attest to the fact that some things, like being able to support webfonts at all, required a sizable amount of work in the app_server… so you can certainly assist with improvements to WebPositive without coming anywhere near the browser.
Thanks for the update! It seems quite hard to help with webkit itself. I don’t really have much of an idea on any of those, but I can do some UEFI framebuffer experiments with external monitors.
For hardware I assume it all boils down to supporting newer intel chipsets? Qemu does emulate ICH9 now so someone who knows a bit in that area can probably take a look…
If there are specific bugs that are found, I guess an update here could help find someone to work on it.
And as everyone else pointed out, that is a lot of work!! Thanks for working on it!!
For me the bugs with modern Radeons , haiku itself boots only to a black screen , and connected the monitor to DVI results in a message of resolution not supported , via HDMI a black screen only. It was working on RADEON HD 5670 / 5770 without problems. Radeon R9 Black screens and RX580 , RX460 seems to work.
Xlibe creates the BApplication on a thread other than the main one. It seems to work just fine. So, this shouldn’t be an issue.
On itself it isn’t, but the current WebKit port is very centered on BMessages, mainly because of the way the “RunLoop” class is implemented (as a BHandler, that will either attach itself to the BApplication looper, or create its own BLooper when started in a new thread). And also because there is a lot of communication going through BMessage between the window and the application (with the handling of these messages having to be done in the thread that runs webkit webcore code).
It’s not impossible, but it will require disabling Haiku specific code in several places, and rewriting it to use a different type of messaging in some other places.
From this point, I can at least test WebKit2 builds on Haiku R1B4 with any newer Haiku integration patches for WebKit2 - at least when my time permits…
