Hi I try to playing a mp3 file with the command line tool mpg123 but that don’t playing the file. I get just some information about my mp3 and it close (return to Terminal command).
Doesn’t work here either. I do get informative error output though:
High Performance MPEG 1.0/2.0/2.5 Audio Player for Layers 1, 2 and 3
version 1.28.0; written and copyright by Michael Hipp and others
free software (LGPL) without any warranty but with best wishes
[src/libout123/libout123.c:out123_open():485] error: Found no driver out of [] working with device <default>.
main: [src/mpg123.c:check_fatal_output():332] error: out123 error 3: failure loading driver module
Doing media_client play MyFile.mp3
works.
Hi!
Thanks you tool work.
I have find this code that use “mpg123” as decoder and “ao” as playback if I understand.
#include <ao/ao.h>
#include <mpg123.h>
#define BITS 8
int main(int argc, char *argv[])
mpg123_handle *mh;
unsigned char *buffer;
size_t buffer_size;
size_t done;
int err;
int driver;
ao_device *dev;
ao_sample_format format;
int channels, encoding;
long rate;
if(argc < 2)
exit(0);
/* initializations */
ao_initialize();
driver = ao_default_driver_id();
mpg123_init();
mh = mpg123_new(NULL, &err);
buffer_size = mpg123_outblock(mh);
buffer = (unsigned char*) malloc(buffer_size * sizeof(unsigned char));
/* open the file and get the decoding format */
mpg123_open(mh, argv[1]);
mpg123_getformat(mh, &rate, &channels, &encoding);
/* set the output format and open the output device */
format.bits = mpg123_encsize(encoding) * BITS;
format.rate = rate;
format.channels = channels;
format.byte_format = AO_FMT_NATIVE;
format.matrix = 0;
dev = ao_open_live(driver, &format, NULL);
/* decode and play */
while (mpg123_read(mh, buffer, buffer_size, &done) == MPG123_OK)
ao_play(dev, buffer, done);
/* clean up */
free(buffer);
ao_close(dev);
mpg123_close(mh);
mpg123_delete(mh);
mpg123_exit();
ao_shutdown();
return 0;
gcc main.c -o play -lmpg123 -lao
That need mpg123 devel and lao devel. The final app work at the same:
play mp3file.mp3
