I tried installing Haiku inside of Parallels on a 2018 Mac mini. Installation was for the most part pretty smooth but now that I’m using it I’m having serious problems trying to get the mouse to work right.
Mostly there is just some kind of insane lag as I move the mouse cursor around. If I move it really really slow it seems cool. If I move at a normal speed then the cursor will trail behind extremely slowly. For example if I moved it quickly a few inches across the screen it might take 30 seconds for the mouse to catch up. It’s basically unusable.
Has anyone else experienced this or know any work arounds?
Just I just use virtual box?
