However, the monitor shows an Input Not Supported message after the Haiku bootup screen. VESA driver does work, but it is only limited to 1024x768 resolution; this is odd considering that Linux can output up to 1920x1080. What’s going on? Is this a driver issue?
EDIT: Adding to mention that this was on the Beta 1 release.
Filed with normal priority, since I wasn’t sure whether it deserves to be a high or critical ticket; it does prevent Haiku from being usable, though. What do you think?
