Yo guys! I downloaded WebPositive and extracted it, but it won’t launch. It says I’m missing some libraries. Where can I get them?
You need to update to a R1-Alpha2 release candidate. ICU is a library heavily used by locale, which was never in Alpha1.
Because Stippy didn’t update his Haiku with the latest library (openSSL&openSSH) you should get Haiku r36316 (04/15/2010) if you want to test a recent web+
I use a Haiku GCC4 Hybrid from the 15.April and cant get Web+(Rev. 421) started. Rev 419 was working…
Missing libs:
libssl and libcrypto…
There is still no GCC4 Alpha 2 Version, maybe I should just try the latest GCC4 Hybrid?
I guess that or wait until Alpha 2. Is there any way of “upgrading” Haiku, or will I have to install over Alpha 1?
Installing over alpha1 will keep everything in your home folder intact, data and settings. Only the system folder is supposed to be upgraded.
Regards,
Humdinger
