Memory leak in hrev 58449 and a couple other observations
hrev 58449
I’m running the following script on five 64-bit Haiku VMs to test Smoothwall Express’ IPsec tunnels among 8 SWE VMs. The five Haikus each have 1GiB RAM, 2 CPUs, and VIRTIO. Networking is kind-of slow, but adequate for my testing (IIRC, the bit rate is about the same for VIRTIO and emulated NIC).
#! /bin/bash
while true; do
  for i in 61 62 63 64 65 66 67 68; do
    ping -s 32000 -c1 -t1 10.$i.1.20 | grep from &
    wait >/dev/null 2>&1
  done&
  sleep .001
done
Ran it a week ago. In time, the Haiku VMs were either comatose or in KDL (though sshd seemed to respond, so I’ve activated sshd). It seemed to look like OOM. So I ran it again, this time watching memory usage. Process Controller’s ‘memory usage’ shows the kernel teams on all five VMs using around 600 MiB after about 20 hours uptime. (After a fresh boot, they use around 85MiB.)
Occasionally when watching mem usage, it dies (popup show an “Oops!” button). But all seems OK after. I saved a core file from one of these croaks.
When does the thread ID roll around to zero? One of the VMs is over 6.15M now.
By default, sshd doesn’t allow remote access to ‘user’ (the only user on Haiku, as you know). Twerking sshd.config to allow root logins fixes this; I think I also had to set a password for ‘user’.
What’s “it” that dies here?
Please check in ActivityMonitor. If the memory used is in cache or otherwise, then this isn’t an issue. (If it’s just “used memory” that’s increased, that may be a problem.)
If it’s indeed a memory leak, you’ll need to drop to KDL to see where the memory has gone. I tried running your test here very briefly, and memory usage went up by .5 MB overall, which isn’t significant but could be a leak.
The relevant command to run in KDL is slabs, this shows allocator usage. A comparison between a fresh boot and then after the leak has happened (and killing all processes that were started) should show where the memory usage increase is, if it’s in allocator use anyway. (If it’s somewhere else, that’ll be much harder to track down.)
Was working from memory; got parts of it wrong. ‘It’ is ProcessController in Deskbar; while looking at ‘Memory usage’, that window is replaced by the ‘Oh No!’ popup about Deskbar croaking. But Deskbar seems unaffected after continuing.
Yes, if it was just cached disk, it would be OK; I’m quite familiar with Linux’s disk caching which can push out pert near all LRU pages to keep a file in cache (even to using 64GiB RAM).
All four of the VMs that were pinging locked up this time to black screens; I had to ‘system_reset’ in qemu’s monitor. All I know to find after reboot is previous_syslog (see below; only pasted the end). This is prolly not very useful.
I’ll catch the increased memory usage. It definitely looks like ‘kernel team’ grows in size. (I was preparing screenshots until I happened to look at syslog, where KDL output is stored. :slight_smile: And there are a few lines about the Deskbar croak in there, too.) Patience while kernel team’s memory usage grows. It’s up to 113MiB now; I’ll report again when it is a good deal larger.
[And for others, if it isn’t noted somewhere obvious, “/bin/kernel_debugger” enters KDL (since the 3- or 4-finger salute doesn’t work for me in qemu).]
ps2: probe_mouse Extended PS/2 mouse found
ps2: devfs_publish_device input/mouse/ps2/intelli_0, status = 0x00000000
ps2: devfs_publish_device input/keyboard/at/0, status = 0x00000000
ps2: keyboard found
register_domain(4, link)
slab memory manager: created area 0xffffffff98801000 (21720)
slab memory manager: created area 0xffffffff99001000 (41652)
slab memory manager: created area 0xffffffff99801000 (450671)
slab memory manager: created area 0xffffffff9a001000 (972081)
slab memory manager: created area 0xffffffff9a801000 (1755866)
libroot __mutex_unlock: mutex was not actually locked!
slab memory manager: created area 0xffffffff9b001000 (6561384)
slab memory manager: created area 0xffffffff9b801000 (13385170)
slab memory manager: created area 0xffffffff9c001000 (20437462)
slab memory manager: created area 0xffffffff9c801000 (27409576)
slab memory manager: created area 0xffffffff9d001000 (35793896)
slab memory manager: created area 0xffffffff9d801000 (44099583)
slab memory manager: created area 0xffffffff9e001000 (52987530)
slab memory manager: created area 0xffffffff9e801000 (59967194)
slab memory manager: created area 0xffffffff9f001000 (67620526)
slab memory manager: created area 0xffffffff9f801000 (77341644)
slab memory manager: created area 0xffffffffa0001000 (83833637)
slab memory manager: created area 0xffffffffa0801000 (90793318)
slab memory manager: created area 0xffffffffa1001000 (98299515)
slab memory manager: created area 0xffffffffa1801000 (104848199)
slab memory manager: created area 0xffffffffa2001000 (112325344)
slab memory manager: created area 0xffffffffa2801000 (120996495)
slab memory manager: created area 0xffffffffa3001000 (126009591)
slab memory manager: created area 0xffffffffa3801000 (131627149)
slab memory manager: created area 0xffffffffa4001000 (137992221)
slab memory manager: created area 0xffffffffa4801000 (147000500)
slab memory manager: created area 0xffffffffa5001000 (156646438)
slab memory manager: created area 0xffffffffa5801000 (166560294)
slab memory manager: created area 0xffffffffa6001000 (174273743)
slab memory manager: created area 0xffffffffa6801000 (182375967)
slab memory manager: created area 0xffffffffa7001000 (188020461)
slab memory manager: created area 0xffffffffa7801000 (195934020)
slab memory manager: created area 0xffffffffa8001000 (204212034)
slab memory manager: created area 0xffffffffa8801000 (210990456)
register_domain(9, unix)
slab memory manager: created area 0xffffffffa9001000 (216478325)
slab memory manager: created area 0xffffffffa9801000 (221382172)
slab memory manager: created area 0xffffffffaa001000 (228676536)
slab memory manager: created area 0xffffffffaa801000 (235159545)
slab memory manager: created area 0xffffffffab001000 (243765310)
slab memory manager: created area 0xffffffffab801000 (253059298)
slab memory manager: created area 0xffffffffac001000 (262558055)
slab memory manager: created area 0xffffffffac801000 (272054617)
slab memory manager: created area 0xffffffffad001000 (278349205)
slab memory manager: created area 0xffffffffad801000 (285945843)
slab memory manager: created area 0xffffffffae001000 (293500238)
slab memory manager: created area 0xffffffffae801000 (300919988)
slab memory manager: created area 0xffffffffaf001000 (308703320)
slab memory manager: created area 0xffffffffaf801000 (316954639)
slab memory manager: created area 0xffffffffb0001000 (323380294)
slab memory manager: created area 0xffffffffb0801000 (331832080)
slab memory manager: created area 0xffffffffb1001000 (340833866)
slab memory manager: created area 0xffffffffb1801000 (347848371)
slab memory manager: created area 0xffffffffb2001000 (354570597)
slab memory manager: created area 0xffffffffb2801000 (361654740)
slab memory manager: created area 0xffffffffb3001000 (370274477)
slab memory manager: created area 0xffffffffb3801000 (376962358)
slab memory manager: created area 0xffffffffb4001000 (385193828)
slab memory manager: created area 0xffffffffb4801000 (394095409)
slab memory manager: created area 0xffffffffb5001000 (401917469)
slab memory manager: created area 0xffffffffb5801000 (410204892)
slab memory manager: created area 0xffffffffb6001000 (416973003)
slab memory manager: created area 0xffffffffb6801000 (425219062)
slab memory manager: created area 0xffffffffb7001000 (433975524)
slab memory manager: created area 0xffffffffb7801000 (443927902)
slab memory manager: created area 0xffffffffb8001000 (449309173)
slab memory manager: created area 0xffffffffb8801000 (457681703)
slab memory manager: created area 0xffffffffb9001000 (462609021)
slab memory manager: created area 0xffffffffb9801000 (467833151)
slab memory manager: created area 0xffffffffba001000 (475711199)
slab memory manager: created area 0xffffffffba801000 (481927302)
slab memory manager: created area 0xffffffffbb001000 (491028224)
slab memory manager: created area 0xffffffffbb801000 (499261663)
slab memory manager: created area 0xffffffffbc001000 (505643515)
slab memory manager: created area 0xffffffffbc801000 (513270278)
slab memory manager: created area 0xffffffffbd001000 (522719987)
slab memory manager: created area 0xffffffffbd801000 (530238490)
slab memory manager: created area 0xffffffffbe001000 (536738447)
slab memory manager: created area 0xffffffffbe801000 (542573604)
slab memory manager: created area 0xffffffffbf001000 (547947559)
slab memory manager: created area 0xffffffffbf801000 (554777502)
slab memory manager: created area 0xffffffffc0001000 (564413456)
slab memory manager: created area 0xffffffffc0801000 (573495425)
slab memory manager: created area 0xffffffffc1001000 (578798934)
slab memory manager: created area 0xffffffffc1801000 (586103711)
slab memory manager: created area 0xffffffffc2001000 (592122488)
slab memory manager: created area 0xffffffffc2801000 (602263227)
slab memory manager: created area 0xffffffffc3001000 (611305014)
slab memory manager: created area 0xffffffffc3801000 (617016632)
slab memory manager: created area 0xffffffffc4001000 (622422418)
slab memory manager: created area 0xffffffffc4801000 (632958717)
slab memory manager: created area 0xffffffffc5001000 (640639495)
slab memory manager: created area 0xffffffffc5801000 (647937667)
slab memory manager: created area 0xffffffffc6001000 (654229334)
slab memory manager: created area 0xffffffffc6801000 (667037323)
low resource pages: normal -> note
low resource pages: note -> normal
slab memory manager: created area 0xffffffffc7001000 (679473154)
low resource pages: critical -> note
low resource pages: critical -> normal
slab memory manager: created area 0xffffffffc7801000 (693361457)
The pings ran for about 7 hours. Here are the slabs report and deskbar excerpts from syslog. I’ll post the entire syslog in the next two posts.
Initial slabs report, post-boot:
KERN: kdebug> slabs
KERN:            address                   name  objsize    align    usage  empty  usedobj    total    flags
KERN: 0xffffffff82006000    block allocator: 16       16       16    45056      0     2586     2772 80000000
KERN: 0xffffffff820061d0    block allocator: 24       24        8   163840      0     6557     6720 80000000
KERN: 0xffffffff820063a0    block allocator: 32       32       32   364544      0    11143    11214 80000000
KERN: 0xffffffff82006570    block allocator: 48       48        8   716800      0    14624    14700 80000000
KERN: 0xffffffff82006720    block allocator: 64       64       64   483328      1     6447     7434 80000000
KERN: 0xffffffff820068d0    block allocator: 80       80        8   266240      0     3201     3250 80000000
KERN: 0xffffffff82006a80    block allocator: 96       96        8    65536      0      632      672 80000000
KERN: 0xffffffff82006c30   block allocator: 112      112        8   184320      0     1609     1620 80000000
KERN: 0xffffffff82006de0   block allocator: 128      128      128   389120      0     2921     2945 80000000
KERN: 0xffffffff82008000   block allocator: 160      160        8   131072      0      795      800 80000000
KERN: 0xffffffff820081b0   block allocator: 192      192        8    65536      0      320      336 80000000
KERN: 0xffffffff82008360   block allocator: 224      224        8   393216      0     1717     1728 80000000
KERN: 0xffffffff82008510   block allocator: 256      256      256    90112      0      324      330 80000000
KERN: 0xffffffff820086c0   block allocator: 320      320        8   126976      0      370      372 80000000
KERN: 0xffffffff820088a0   block allocator: 384      384        8    16384      0       38       40 80000000
KERN: 0xffffffff82008a80   block allocator: 448      448        8   196608      0      429      432 80000000
KERN: 0xffffffff82008c60   block allocator: 512      512      512   167936      0      321      328 80000000
KERN: 0xffffffff8200ae00   block allocator: 640      640        8   131072      0      168      204 80000000
KERN: 0xffffffff8200ac00   block allocator: 768      768        8    65536      0       22       85 80000000
KERN: 0xffffffff8200aa00   block allocator: 896      896        8    65536      0       13       73 80000000
KERN: 0xffffffff8200a800  block allocator: 1024     1024     1024    65536      0       50       64 80000000
KERN: 0xffffffff8200a600  block allocator: 1280     1280        8   655360      0      478      510 80000000
KERN: 0xffffffff8200a400  block allocator: 1536     1536        8    65536      0       17       42 80000000
KERN: 0xffffffff8200a200  block allocator: 1792     1792        8    65536      0       17       36 80000000
KERN: 0xffffffff8200a000  block allocator: 2048     2048     2048   131072      0       50       64 80000000
KERN: 0xffffffff8200be00  block allocator: 2560     2560        8   131072      0       29       50 88000000
KERN: 0xffffffff8200bc00  block allocator: 3072     3072        8    65536      0        5       21 88000000
KERN: 0xffffffff8200ba00  block allocator: 3584     3584        8    65536      0        4       18 88000000
KERN: 0xffffffff8200b800  block allocator: 4096     4096     4096  4456448      1     1063     1088 88000000
KERN: 0xffffffff8200b600  block allocator: 4608     4608        8    65536      0        5       14 88000000
KERN: 0xffffffff8200b400  block allocator: 5120     5120        8    65536      0        4       12 88000000
KERN: 0xffffffff8200b200  block allocator: 5632     5632        8    65536      0        2       11 88000000
KERN: 0xffffffff8200b000  block allocator: 6144     6144        8    65536      0        4       10 88000000
KERN: 0xffffffff8200ce00  block allocator: 6656     6656        8    65536      0        3        9 88000000
KERN: 0xffffffff8200cc00  block allocator: 7168     7168        8    65536      0        1        9 88000000
KERN: 0xffffffff8200ca00  block allocator: 7680     7680        8    65536      1        0        8 88000000
KERN: 0xffffffff8200c800  block allocator: 8192     8192     8192   589824      0       70       72 88000000
KERN: 0xffffffff8200de00             cache refs       16        8    53248      0     3067     3276        0
KERN: 0xffffffff8200dc40            anon caches      232        8   323584      0     1335     1343        0
KERN: 0xffffffff8200da80    anon no-swap caches      208        8    73728      0      339      342        0
KERN: 0xffffffff8200d8c0           vnode caches      232        8   303104      0     1257     1258        0
KERN: 0xffffffff8200d700          device caches      208        8     4096      0       11       19        0
KERN: 0xffffffff8200d540            null caches      200        8    32768      0      141      160        0
KERN: 0xffffffff8200d380           kernel areas      208        8    69632      0      318      323        0
KERN: 0xffffffff8200d1c0  kernel address ranges       88        8    32768      0      356      360        0
KERN: 0xffffffff8200d000        page mappings 0       48        8  1245184      0    25472    25916 20000000
KERN: 0xffffffff82028e08        page mappings 1       48        8  1245184      0    25414    25916 20000000
KERN: 0xffffffff8200c200                threads     3520       64   458752      0      120      126        0
KERN: 0xffffffff8200c000         vfs path names     1024        8    65536      0       31       64        0
KERN: 0xffffffff82028c48             vfs vnodes      128        8   237568      0     1776     1798        0
KERN: 0xffffffff82028a88                vfs fds       48        8     8192      0      110      168        0
KERN: 0xffffffff820288c8          cached blocks      104        8   524288      0      500     5040 20000000
KERN: 0xffffffff82028708    cache notifications       72        8     4096      0        4       56        0
KERN: 0xffffffff82028548              swapblock      160        8   671744    164        0     4100        0
KERN: 0xffffffff823d9c00               scsi ccb      296        8     8192      0       14       26        0
KERN: 0xffffffff823d9a00          scsi temp s/g      528        8    65536      0        1      124        0
KERN: 0xffffffff823d9800    block cache buffers     4096        8  4194304      0     1011     1024 20000000
KERN: 0xffffffff823d9600     pkgfs heap buffers    65536        8   524288      0        6        8        0
KERN: 0xffffffff8263aa90   pkgfs TKAVLTreeNodes       40        8  3719168      0    91695    91708  8000000
KERN: 0xffffffff8263a010 pkgfs PackageDirectorys       88        8   225280      0     2473     2475  8000000
KERN: 0xffffffff82641e18 pkgfs PackageNodeAttributes       48        8  2519040      0    51578    51660  8000000
KERN: 0xffffffff82641c58     pkgfs PackageFiles       96        8  2248704      0    23022    23058  8000000
KERN: 0xffffffff82641718  pkgfs PackageSymlinks       80        8   528384      0     6431     6450  8000000
KERN: 0xffffffff953e7700 pkgfs UnpackingDirectorys      200        8   278528      0     1355     1360  8000000
KERN: 0xffffffff953e7540 pkgfs UnpackingLeafNodes       96        8  2838528      0    29075    29106  8000000
KERN: 0xffffffff95cb7a00       net buffer cache      360        8    20480      0       50       55        0
KERN: 0xffffffff95bd7000        data node cache     2048        8   131072      0       50       64        0
KERN: kdebug> exit
First slabs report, before starting pings:
KERN: kdebug> slabs
KERN: 0xffffffff82006000    block allocator: 16       16       16    57344      0     3394     3528 80000000
KERN: 0xffffffff820061d0    block allocator: 24       24        8   167936      0     6737     6888 80000000
KERN: 0xffffffff820063a0    block allocator: 32       32       32   368640      0    11324    11340 80000000
KERN: 0xffffffff82006570    block allocator: 48       48        8   720896      0    14770    14784 80000000
KERN: 0xffffffff820068d0    block allocator: 80       80        8   303104      0     3656     3700 80000000
KERN: 0xffffffff82006a80    block allocator: 96       96        8  1851392      0    18973    18984 80000000
KERN: 0xffffffff82006c30   block allocator: 112      112        8   233472      0     2018     2052 80000000
KERN: 0xffffffff82006de0   block allocator: 128      128      128   409600      0     3086     3100 80000000
KERN: 0xffffffff82008000   block allocator: 160      160        8   192512      0     1165     1175 80000000
KERN: 0xffffffff820081b0   block allocator: 192      192        8    73728      0      376      378 80000000
KERN: 0xffffffff82008360   block allocator: 224      224        8  1306624      0     4488     5742 80000000
KERN: 0xffffffff82008510   block allocator: 256      256      256    90112      0      325      330 80000000
KERN: 0xffffffff820086c0   block allocator: 320      320        8   155648      0      449      456 80000000
KERN: 0xffffffff820088a0   block allocator: 384      384        8    24576      0       57       60 80000000
KERN: 0xffffffff82008a80   block allocator: 448      448        8   208896      0      455      459 80000000
KERN: 0xffffffff82008c60   block allocator: 512      512      512   180224      0      347      352 80000000
KERN: 0xffffffff8200ae00   block allocator: 640      640        8   262144      0      391      408 80000000
KERN: 0xffffffff8200ac00   block allocator: 768      768        8    65536      0       23       85 80000000
KERN: 0xffffffff8200aa00   block allocator: 896      896        8    65536      0       34       73 80000000
KERN: 0xffffffff8200a800  block allocator: 1024     1024     1024   131072      0       73      128 80000000
KERN: 0xffffffff8200a600  block allocator: 1280     1280        8  2228224      1     1278     1734 80000000
KERN: 0xffffffff8200a400  block allocator: 1536     1536        8    65536      0       25       42 80000000
KERN: 0xffffffff8200a200  block allocator: 1792     1792        8    65536      0       25       36 80000000
KERN: 0xffffffff8200a000  block allocator: 2048     2048     2048   131072      0       61       64 80000000
KERN: 0xffffffff8200be00  block allocator: 2560     2560        8   327680      0       95      125 88000000
KERN: 0xffffffff8200b800  block allocator: 4096     4096     4096  4849664      0     1133     1184 88000000
KERN: 0xffffffff8200b600  block allocator: 4608     4608        8   131072      1        6       28 88000000
KERN: 0xffffffff8200c800  block allocator: 8192     8192     8192   589824      0       69       72 88000000
KERN: 0xffffffff8200de00             cache refs       16        8   135168      0     6436     8316        0
KERN: 0xffffffff8200dc40            anon caches      232        8  1536000      1     4574     6375        0
KERN: 0xffffffff8200da80    anon no-swap caches      208        8   114688      0      530      532        0
KERN: 0xffffffff8200d8c0           vnode caches      232        8   311296      0     1276     1292        0
KERN: 0xffffffff8200d540            null caches      200        8    32768      0      146      160        0
KERN: 0xffffffff8200d380           kernel areas      208        8   102400      0      464      475        0
KERN: 0xffffffff8200d1c0  kernel address ranges       88        8    49152      0      537      540        0
KERN: 0xffffffff8200d000        page mappings 0       48        8  2949120      0    47061    61380 20000000
KERN: 0xffffffff82028e08        page mappings 1       48        8  3014656      0    47152    62744 20000000
KERN: 0xffffffff8200c200                threads     3520       64   851968      0      214      234        0
KERN: 0xffffffff8200c000         vfs path names     1024        8    65536      0       44       64        0
KERN: 0xffffffff82028c48             vfs vnodes      128        8   253952      0     1921     1922        0
KERN: 0xffffffff82028a88                vfs fds       48        8    16384      0      283      336        0
KERN: 0xffffffff820288c8          cached blocks      104        8   524288      0      504     5040 20000000
KERN: 0xffffffff823d9c00               scsi ccb      296        8     8192      0       21       26        0
KERN: 0xffffffff823d9800    block cache buffers     4096        8  4194304      0     1013     1024 20000000
KERN: 0xffffffff823d9600     pkgfs heap buffers    65536        8   524288      0        8        8        0
KERN: 0xffffffff95cb7a00       net buffer cache      360        8    86016      1      211      231        0
KERN: 0xffffffff95bd7000        data node cache     2048        8  1507328      0      446      736        0
KERN: kdebug> exit
Last slabs report, after stopping all ping activity:
KERN: kdebug> slabs
KERN: 0xffffffff82006000    block allocator: 16       16       16    65536      0     3558     4032 80000000
KERN: 0xffffffff820061d0    block allocator: 24       24        8   172032      0     6910     7056 80000000
KERN: 0xffffffff820063a0    block allocator: 32       32       32   372736      0    11394    11466 80000000
KERN: 0xffffffff82006570    block allocator: 48       48        8   724992      0    14818    14868 80000000
KERN: 0xffffffff820068d0    block allocator: 80       80        8   323584      0     3918     3950 80000000
KERN: 0xffffffff82006a80    block allocator: 96       96        8 94969856      0   973809   973812 80000000
KERN: 0xffffffff82006c30   block allocator: 112      112        8   258048      0     2252     2268 80000000
KERN: 0xffffffff82006de0   block allocator: 128      128      128   438272      0     3308     3317 80000000
KERN: 0xffffffff82008000   block allocator: 160      160        8   217088      0     1308     1325 80000000
KERN: 0xffffffff820081b0   block allocator: 192      192        8    86016      0      438      441 80000000
KERN: 0xffffffff82008360   block allocator: 224      224        8  1826816     87     4364     8028 80000000
KERN: 0xffffffff820086c0   block allocator: 320      320        8   180224      0      517      528 80000000
KERN: 0xffffffff82008a80   block allocator: 448      448        8   212992      0      460      468 80000000
KERN: 0xffffffff82008c60   block allocator: 512      512      512   188416      0      346      368 80000000
KERN: 0xffffffff8200ae00   block allocator: 640      640        8   327680      0      396      510 80000000
KERN: 0xffffffff8200ac00   block allocator: 768      768        8    65536      0       26       85 80000000
KERN: 0xffffffff8200a800  block allocator: 1024     1024     1024   131072      0       77      128 80000000
KERN: 0xffffffff8200a600  block allocator: 1280     1280        8  2949120      8     1174     2295 80000000
KERN: 0xffffffff8200a400  block allocator: 1536     1536        8   131072      0       48       84 80000000
KERN: 0xffffffff8200a200  block allocator: 1792     1792        8   131072      0       42       72 80000000
KERN: 0xffffffff8200be00  block allocator: 2560     2560        8   458752      1       89      175 88000000
KERN: 0xffffffff8200b800  block allocator: 4096     4096     4096  5046272      3     1127     1232 88000000
KERN: 0xffffffff8200b600  block allocator: 4608     4608        8   196608      2        5       42 88000000
KERN: 0xffffffff8200de00             cache refs       16        8   172032      0     6150    10584        0
KERN: 0xffffffff8200dc40            anon caches      232        8  2039808     90     4299     8466        0
KERN: 0xffffffff8200da80    anon no-swap caches      208        8   139264      0      629      646        0
KERN: 0xffffffff8200d8c0           vnode caches      232        8   311296      0     1290     1292        0
KERN: 0xffffffff8200d540            null caches      200        8    32768      0      159      160        0
KERN: 0xffffffff8200d380           kernel areas      208        8   110592      0      499      513        0
KERN: 0xffffffff8200d1c0  kernel address ranges       88        8    53248      0      578      585        0
KERN: 0xffffffff8200d000        page mappings 0       48        8  3866624      0    48742    80476 20000000
KERN: 0xffffffff82028e08        page mappings 1       48        8  3866624      0    48766    80476 20000000
KERN: 0xffffffff8200c200                threads     3520       64  1048576      1      227      288        0
KERN: 0xffffffff8200c000         vfs path names     1024        8    65536      0       48       64        0
KERN: 0xffffffff82028c48             vfs vnodes      128        8   258048      0     1945     1953        0
KERN: 0xffffffff82028a88                vfs fds       48        8    20480      0      356      420        0
KERN: 0xffffffff820288c8          cached blocks      104        8   524288      0      519     5040 20000000
KERN: 0xffffffff82028708    cache notifications       72        8     4096      0        7       56        0
KERN: 0xffffffff823d9c00               scsi ccb      296        8    12288      0       35       39        0
KERN: 0xffffffff823d9800    block cache buffers     4096        8  4718592      0     1069     1152 20000000
KERN: 0xffffffff95cb7a00       net buffer cache      360        8   405504     62      291     1089        0
KERN: 0xffffffff95bd7000        data node cache     2048        8  2555904     10      665     1248        0
KERN: kdebug> exit
Deskbar crash from syslog:
KERN: debug_server: Thread 24554 entered the debugger: General protection fault
KERN: stack trace, current PC 0xc70b991fc0  </boot/system/lib/libbe.so> _ZNK5BView6WindowEv + 0:
KERN:   (0x7f7e4841c860)  0xc70b944eb3  </boot/system/lib/libbe.so> _ZN5BMenu6_TrackEPil.localalias + 0x1a3
KERN:   (0x7f7e4841c920)  0xc70b94538b  </boot/system/lib/libbe.so> _ZN5BMenu5TrackEbP5BRect + 0x4b
KERN:   (0x7f7e4841c960)  0xc70b95a28a  </boot/system/lib/libbe.so> _ZN10BPopUpMenu11_StartTrackE6BPointbbP5BRect + 0x7a
KERN:   (0x7f7e4841c9a0)  0xc70b95a33a  </boot/system/lib/libbe.so> _ZN10BPopUpMenu13_thread_entryEPv + 0x3a
KERN:   (0x7f7e4841c9d0)  0x22f3ed16189  </boot/system/lib/libroot.so> thread_entry + 0x19
KERN: debug_server: Killing team 119 (/boot/system/Deskbar)
KERN: debug_server: TeamDebugHandler::Init(): Failed to get info for team 119: Operation on invalid team
KERN: debug_server: KillTeam(): Error getting info for team 119: Operation on invalid team
KERN: debug_server: Killing team 119 ()
syslog, part 1:
KERN: kernel entry at 0xffffffff80069970
KERN: Welcome to kernel debugger output!
KERN: Haiku revision: hrev58449, debug level: 2
KERN: CPU: no microcode provided
KERN: CPU 0: type 0 family 15 extended_family 8 model 1 extended_model 7 stepping 0, string 'AuthenticAMD'
KERN: CPU 0: vendor 'AMD' model name 'AMD Ryzen 9 3950X 16-Core Processor            '
KERN: CPU 0: apic id 0, package 0, core 0, smt 0
KERN: CPU 0: features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clfsh mmx fxsr sse sse2 htt sse3 pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt tscdeadline aes xsave avx f16c rdrnd hypervisor syscall nx mmxext ffxsr pdpe1gb long arat tsc_adjust bmi1 avx2 smep bmi2 rdseed adx smap cflushopt clwb sha_ni umip rdpid stibp msr_arch ssbd xsaveopt xsavec xgetbv1 clzero ibpb amd_ssbd virt_ssbd
KERN: CPU 0: patch_level 0x0
KERN: using PAT for memory type configuration
KERN: PAT MSR on CPU 0 before init: 0x7040600070406
KERN: PAT MSR on CPU 0 after init: 0x7040100070406
KERN: reserve_io_interrupt_vectors: reserved 16 vectors starting from 0
KERN: mark_page_range_in_use(0x0, 0x100): start page is before free list
KERN: mark_page_range_in_use(0x0, 0xa0): start page is before free list
KERN: Welcome to syslog debug output!
KERN: found x2apic
KERN: enable SMEP
KERN: enable SMAP
KERN: arch_altcodepatch_replace found 24 altcodepatches for tag 1
KERN: arch_altcodepatch_replace found 288 altcodepatches for tag 2
KERN: arch_altcodepatch_replace found 2 altcodepatches for tag 3
KERN: arch_altcodepatch_replace found 4 altcodepatches for tag 4
KERN: enable XSAVEC 0x7 832
KERN: CPU 1: type 0 family 15 extended_family 8 model 1 extended_model 7 stepping 0, string 'AuthenticAMD'
KERN: CPU 1: vendor 'AMD' model name 'AMD Ryzen 9 3950X 16-Core Processor            '
KERN: CPU 1: apic id 1, package 0, core 1, smt 0
KERN: CPU 1: features: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clfsh mmx fxsr sse sse2 htt sse3 pclmulqdq ssse3 fma cx16 sse4_1 sse4_2 x2apic movbe popcnt tscdeadline aes xsave osxsave avx f16c rdrnd hypervisor syscall nx mmxext ffxsr pdpe1gb long arat tsc_adjust bmi1 avx2 smep bmi2 rdseed adx smap cflushopt clwb sha_ni umip rdpid stibp msr_arch ssbd xsaveopt xsavec xgetbv1 clzero ibpb amd_ssbd virt_ssbd
KERN: CPU 1: patch_level 0x0
KERN: PAT MSR on CPU 1 before init: 0x7040600070406
KERN: PAT MSR on CPU 1 after init: 0x7040100070406
KERN: setting up x2apic for CPU 0: apic id 0, version 327700
KERN: CPU 0: logical apic id: 0x1
KERN: x86_init_fpu: CPU has SSE... enabling FXSR and XMM.
KERN: reserve_io_interrupt_vectors: reserved 3 vectors starting from 221
KERN: reserve_io_interrupt_vectors: reserved 1 vectors starting from 219
KERN: arch_init_timer: using APIC timer.
KERN: allocate_commpage_entry(2, 16) -> 0x0000000000000200
KERN: scheduler_init: found 2 logical cpus and 0 cache levels
KERN: scheduler switches: single core: false, cpu load tracking: false, core load tracking: true
KERN: scheduler: switching to low latency mode
KERN: msi support enabled
KERN: setting up x2apic for CPU 1: apic id 1, version 327700
KERN: CPU 1: logical apic id: 0x2
KERN: slab memory manager: created area 0xffffffff80801000 (156)
KERN: allocate_commpage_entry(3, 69) -> 0x0000000000000210
KERN: PCI: pci_module_init
KERN: assuming memory type 50000000 for overlapping 0x0, 0x1000 area 161 from existing 0x0, 0xa0000 area 3
KERN: assuming memory type 50000000 for overlapping 0x9f000, 0x1000 area 162 from existing 0x0, 0xa0000 area 3
KERN: ACPI: RSDP 0x00000000000F59D0 000014 (v00 BOCHS )
KERN: ACPI: RSDT 0x000000003FFE2E51 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
KERN: ACPI: FACP 0x000000003FFE2B51 0000F4 (v03 BOCHS  BXPC     00000001 BXPC 00000001)
KERN: ACPI: DSDT 0x000000003FFE0040 002B11 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
KERN: ACPI: FACS 0x000000003FFE0000 000040
KERN: ACPI: APIC 0x000000003FFE2C45 000170 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
KERN: ACPI: HPET 0x000000003FFE2DB5 000038 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
KERN: ACPI: MCFG 0x000000003FFE2DED 00003C (v01 BOCHS  BXPC     00000001 BXPC 00000001)
KERN: ACPI: WAET 0x000000003FFE2E29 000028 (v01 BOCHS  BXPC     00000001 BXPC 00000001)
KERN: ACPI: Forced DSDT copy: length 0x02B11 copied locally, original unmapped
KERN: ACPI: 1 ACPI AML tables successfully acquired and loaded
KERN: ACPI: Enabled 2 GPEs in block 00 to 3F
KERN: publish device: node 0xffffffff8202da00, path acpi/namespace, module bus_managers/acpi/namespace/device_v1
KERN: publish device: node 0xffffffff8202da00, path acpi/call, module bus_managers/acpi/call/device_v1
KERN: registering power button
KERN: initialize PCI controller from ACPI
KERN: PCI: range from ACPI [0(1),ff(1)] with length 100
KERN: PCI: range from ACPI [0(1),cf7(1)] with length cf8
KERN: PCI: range from ACPI [d00(1),ffff(1)] with length f300
KERN: PCI: range from ACPI [a0000(1),bffff(1)] with length 20000
KERN: PCI: range from ACPI [40000000(1),afffffff(1)] with length 70000000
KERN: PCI: range from ACPI [c0000000(1),febfffff(1)] with length 3ec00000
KERN: PCI: range from ACPI [100000000(1),8ffffffff(1)] with length 800000000
KERN: PCI: mechanism addr: b0000000, seg: 0, start: 0, end: ff
KERN: found io-apic with address 0xfec00000, global interrupt base 0, apic-id 0
KERN: mapping io-apic 0 at physical address 0xfec00000
KERN: io-apic 0 has range 0-23, 24 entries, version 0x00170011, apic-id 0
KERN: setting ACPI interrupt model to APIC
KERN: IRQ routing table with 4 entries
KERN: address 0x2ffff; pin 0; source 0xffffffff82502ed0 0; pci 0:2 pin 1 func mask 1; bios irq: 11; gsi 22; config 0x0a
KERN: address 0x3ffff; pin 0; source 0xffffffff82502d80 0; pci 0:3 pin 1 func mask 1; bios irq: 11; gsi 23; config 0x0a
KERN: address 0x4ffff; pin 0; source 0xffffffff825001b8 0; pci 0:4 pin 1 func mask 1; bios irq: 10; gsi 20; config 0x0a
KERN: address 0x1fffff; pin 0; source 0xffffffff825006f8 0; pci 0:31 pin 1 func mask c; bios irq: 10; gsi 16; config 0x0a
KERN: found interrupt override for bus 0, source irq 0, global irq 2, flags 0x00000000
KERN: found interrupt override for bus 0, source irq 5, global irq 5, flags 0x0000000d
KERN: found interrupt override for bus 0, source irq 9, global irq 9, flags 0x0000000d
KERN: found interrupt override for bus 0, source irq 10, global irq 10, flags 0x0000000d
KERN: found interrupt override for bus 0, source irq 11, global irq 11, flags 0x0000000d
KERN: free_io_interrupt_vectors: freeing 16 vectors starting from 0
KERN: reserve_io_interrupt_vectors: reserved 24 vectors starting from 0
KERN: using io-apics for interrupt routing
KERN: PCI: [dom 0, bus  0] bus   0, device  0, function  0: vendor 8086, device 29c0, revision 00
KERN: PCI:   class_base 06, class_function 00, class_api 00
KERN: PCI:   vendor 8086: Intel Corporation
KERN: PCI:   device 29c0: 82G33/G31/P35/P31 Express DRAM Controller (QEMU Virtual Machine)
KERN: PCI:   info: Bridge (Host bridge)
KERN: PCI:   line_size 00, latency 00, header_type 00, BIST 00
KERN: PCI:   ROM base host 00000000, pci 00000000, size 00000000
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 1100, subsystem_vendor_id 1af4
KERN: PCI:   interrupt_line 00, interrupt_pin 00, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 1: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 2: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 3: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 4: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   base reg 5: host 00000000, pci 00000000, size 00000000, flags 00
KERN: PCI:   Capabilities: (not supported)
KERN: PCI: [dom 0, bus  0] bus   0, device  1, function  0: vendor 1234, device 1111, revision 02
KERN: PCI:   class_base 03, class_function 00, class_api 00
KERN: PCI:   vendor 1234: Unknown
KERN: PCI:   device 1111: Unknown
KERN: PCI:   info: Display controller (VGA compatible controller, VGA controller)
KERN: PCI:   ROM base host febc0000, pci febc0000, size 00010000
KERN: PCI:   base reg 0: host fd000000, pci fd000000, size 01000000, flags 08
KERN: PCI:   base KERN: reg 2: host febd4000, pci febd4000, size 00001000, flags 00
KERN: PCI: [dom 0, bus  0] bus   0, device  2, function  0: vendor 1af4, device 1000, revision 00
KERN: PCI:   class_base 02, class_function 00, class_api 00
KERN: PCI:   vendor 1af4: Red Hat, Inc.
KERN: PCI:   device 1000: Virtio network device
KERN: PCI:   info: Network controller (Ethernet controller)
KERN: PCI:   ROM base host feb80000, pci feb80000, size 00040000
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 0001, subsystem_vendor_id 1af4
KERN: PCI:   interrupt_line 16, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 0000c080, pci 0000c080, size 00000020, flags 01
KERN: PCI:   base reg 4: host 00000000fe000000, pci 00000000fe000000, size 00004000, flags 0c 00
KERN: PCI:   Capabilities: vendspec, vendspec, vendspec, vendspec, vendspec
KERN: PCI: [dom 0, bus  0] bus   0, device  3, function  0: vendor 1af4, device 1004, revision 00
KERN: PCI:   class_base 01, class_function 00, class_api 00
KERN: PCI:   device 1004: Virtio SCSI
KERN: PCI:   info: Mass storage controller (SCSI storage controller)
KERN: PCI:   cardbus_CIS 00000000, subsystem_id 0008, subsystem_vendor_id 1af4
KERN: PCI:   interrupt_line 17, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 0000c000, pci 0000c000, size 00000040, flags 01
KERN: PCI:   base reg 1: host febd5000, pci febd5000, size 00001000, flags 00
KERN: PCI:   base reg 4: host 00000000fe004000, pci 00000000fe004000, size 00004000, flags 0c 00
KERN: PCI:   Capabilities: MSI-X, vendspec, vendspec, vendspec, vendspec, vendspec
KERN: PCI: [dom 0, bus  0] bus   0, device  4, function  0: vendor 1b36, device 000d, revision 01
KERN: PCI:   class_base 0c, class_function 03, class_api 30
KERN: PCI:   vendor 1b36: Red Hat, Inc.
KERN: PCI:   device 000d: QEMU XHCI Host Controller
KERN: PCI:   info: Serial bus controller (USB controller, XHCI)
KERN: PCI:   interrupt_line 14, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 0: host 00000000febd0000, pci 00000000febd0000, size 00004000, flags 04 00
KERN: PCI:   Capabilities: MSI-X, PCIe
KERN: PCI:   Extended capabilities: (empty list)
KERN: PCI: [dom 0, bus  0] bus   0, device 31, function  0: vendor 8086, device 2918, revision 02
KERN: PCI:   class_base 06, class_function 01, class_api 00
KERN: PCI:   device 2918: 82801IB (ICH9) LPC Interface Controller (QEMU Virtual Machine)
KERN: PCI:   info: Bridge (ISA bridge)
KERN: PCI:   line_size 00, latency 00, header_type 80, BIST 00
KERN: PCI: [dom 0, bus  0] bus   0, device 31, function  2: vendor 8086, device 2922, revision 02
KERN: PCI:   class_base 01, class_function 06, class_api 01
KERN: PCI:   device 2922: 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] (QEMU Virtual Machine)
KERN: PCI:   info: Mass storage controller (SATA controller, AHCI 1.0)
KERN: PCI:   interrupt_line 10, interrupt_pin 01, min_grant 00, max_latency 00
KERN: PCI:   base reg 4: host 0000c0a0, pci 0000c0a0, size 00000020, flags 01
KERN: PCI:   base reg 5: host febd6000, pci febd6000, size 00001000, flags 00
KERN: PCI:   Capabilities: MSI, SATA
KERN: PCI: [dom 0, bus  0] bus   0, device 31, function  3: vendor 8086, device 2930, revision 02
KERN: PCI:   class_base 0c, class_function 05, class_api 00
KERN: PCI:   device 2930: 82801I (ICH9 Family) SMBus Controller (QEMU Virtual Machine)
KERN: PCI:   info: Serial bus controller (SMBus)
KERN: PCI:   base reg 4: host 00000700, pci 00000700, size 00000040, flags 01
KERN: usb xhci -1: interface version: 0x0100
KERN: usb xhci -1: structural parameters: 1:0x08001040 2:0x0000000f 3:0x00000000
KERN: usb xhci -1: capability parameters: 0x00087001
KERN: usb xhci -1: starting XHCI host controller
KERN: usb xhci -1: successfully started the controller
KERN: usb hub 2: port 0: device removed
KERN: usb hub 2: port 1: device removed
KERN: usb hub 2: port 2: device removed
KERN: usb hub 2: port 3: device removed
KERN: usb hub 2: port 4: new device connected
KERN: usb hub 2: port 5: device removed
KERN: usb hub 2: port 6: device removed
KERN: usb hub 2: port 7: device removed
KERN: get_boot_partitions(): boot volume message:
KERN: KMessage: buffer: 0xffffffff81a41558 (size/capacity: 347/347), flags: 0xa
KERN:   field: "booted from image" (BOOL): false
KERN:   field: "partition offset"  (LLNG): 32768 (0x8000)
KERN:   field: "packaged"          (BOOL): true
KERN:   field: "boot method"       (LONG): 0 (0x0)
KERN:   field: "boot drive number" (LLNG): 128 (0x80)
KERN:   field: "disk identifier"   (RAWT): data at 0xffffffff81a41664, 79 bytes
KERN: get_boot_partitions(): boot method type: 0
KERN: allocate_io_interrupt_vectors: allocated 4 vectors starting from 24
KERN: msi_allocate_vectors: allocated 4 vectors starting from 24
KERN: msix configured for 4 vectors
KERN: msi-x enabled: 0x8004
KERN: virtio_pci: using MSI-X count 4 starting at 24
KERN: publish device: node 0xffffffff8256f520, path disk/scsi/0/0/0/raw, module drivers/disk/scsi/scsi_disk/device_v1
KERN: publish device: node 0xffffffff8256f020, path disk/scsi/0/1/0/raw, module drivers/disk/scsi/scsi_cd/device_v1
KERN: ahci: AHCI controller Intel ICH9 (AHCI mode) found!
KERN: ahci: ahci_register_device
KERN: ahci: ahci_init_driver
KERN: ahci: ahci_sim_init_bus
KERN: ahci: ahci_sim_init_bus: pciDevice 0xffffffff8256eda0
KERN: ahci: AHCIController::Init 0:31:2 vendor 8086, device 2922
KERN: ahci: PCI SATA capability found at offset 0xa8
KERN: ahci: satacr0 = 0x00100012, satacr1 = 0x00000048
KERN: ahci: pcicmd old 0x0107
KERN: ahci: pcicmd new 0x0106
KERN: allocate_io_interrupt_vectors: allocated 1 vectors starting from 28
KERN: msi_allocate_vectors: allocated 1 vectors starting from 28
KERN: msi enabled: 0x0081
KERN: ahci: using MSI vector 28
KERN: ahci: registers at 0xfebd6000, size 0x1000
KERN: ahci: mapping physical address 0xfebd6000 with 4096 bytes for AHCI HBA regs
KERN: ahci: physical = 0xfebd6000, virtual = 0xffffffff811ed000, offset = 0, phyadr = 0xfebd6000, mapadr = 0xffffffff811ed000, size = 4096, area = 0x000000e4
KERN: ahci: cap: Interface Speed Support: generation 1
KERN: ahci: cap: Number of Command Slots: 32 (raw 0x1f)
KERN: ahci: cap: Number of Ports: 6 (raw 0x5)
KERN: ahci: cap: Supports Port Multiplier: no
KERN: ahci: cap: Supports External SATA: no
KERN: ahci: cap: Enclosure Management Supported: no
KERN: ahci: cap: FIS-based Switching Control: no
KERN: ahci: cap: Supports Command List Override: no
KERN: ahci: cap: Supports Staggered Spin-up: no
KERN: ahci: cap: Supports Mechanical Presence Switch: no
KERN: ahci: cap: Supports 64-bit Addressing: yes
KERN: ahci: cap: Supports Native Command Queuing: yes
KERN: ahci: cap: Supports SNotification Register: no
KERN: ahci: cap: Supports AHCI mode only: yes
KERN: ahci: ghc: AHCI Enable: yes
KERN: ahci: Ports Implemented Mask: 0x00003f Number of Available Ports: 6
KERN: ahci: AHCI Version 0001.00.00 Interrupt 28
KERN: ahci: allocating 4096 bytes for AHCI port 0
KERN: ahci: area = 229, size = 4096, virt = 0xffffffff811ee000, phy = 0x2e3c000
KERN: ahci: allocating 4096 bytes for AHCI port 1
KERN: ahci: area = 230, size = 4096, virt = 0xffffffff811ef000, phy = 0x2e3d000
KERN: ahci: allocating 4096 bytes for AHCI port 2
KERN: ahci: area = 231, size = 4096, virt = 0xffffffff811f0000, phy = 0x2e3e000
KERN: ahci: allocating 4096 bytes for AHCI port 3
KERN: ahci: area = 232, size = 4096, virt = 0xffffffff811f1000, phy = 0x2e3f000
KERN: ahci: allocating 4096 bytes for AHCI port 4
KERN: ahci: area = 233, size = 4096, virt = 0xffffffff811f2000, phy = 0x2e40000
KERN: ahci: allocating 4096 bytes for AHCI port 5
KERN: ahci: area = 234, size = 4096, virt = 0xffffffff811f3000, phy = 0x2e41000
KERN: ahci: cookie = 0xffffffff8227b900
KERN: ahci: ahci_path_inquiry, cookie 0xffffffff8227b900
Last message repeated 1 time
KERN: ahci: ahci_scan_bus, cookie 0xffffffff8227b900
KERN: vpd_page_get:
KERN: vpd_page_inquiry:
KERN: vpd_page_get:
KERN: periph_check_capacity: TRIM: Setting trim support to UNMAP
KERN: DMAResource@0xffffffff8256f480: low/high 0/ffffffffffffffff, max segment count 254, align 1, boundary 0, max transfer 65536, max segment size 33553920
KERN: slab memory manager: created area 0xffffffff95001000 (236)
KERN: vpd_page_get:
KERN: vpd_page_get:
KERN: periph_check_capacity: TRIM: Setting trim support to disabled
KERN: identify(0, 0xffffffff82571980)
KERN: raw_command:
KERN: 01. 00:02.00 (length 188:47.11)
KERN: identify(0, 0xffffffff82571968)
KERN: raw_command:
KERN: device 0: /dev/disk/scsi/0/0/0/raw
KERN:   media status:      No error
KERN:   device flags:      2
KERN:   offset:            0
KERN:   size:              11051794432 (10539.812 MB)
KERN:   content size:      11051794432
KERN:   block size:        512
KERN:   physical block size: 512
KERN:   child count:       1
KERN:   index:             -1
KERN:   status:            0
KERN:   flags:             5
KERN:   volume:            -1
KERN:   disk system:       partitioning_systems/intel/map/v1
KERN:   name:              QEMU QEMU HARDDISK
KERN:   content name:      <NULL>
KERN:   type:              <NULL>
KERN:   content type:      Intel Partition Map
KERN:   params:            <NULL>
KERN:   content params:    <NULL>
KERN:   partition 2: /dev/disk/scsi/0/0/0/0
KERN:     offset:            32768
KERN:     size:              11050942464 (10539 MB)
KERN:     content size:      11050942464
KERN:     block size:        4096
KERN:     child count:       0
KERN:     index:             0
KERN:     status:            0
KERN:     flags:             2
KERN:     volume:            -1
KERN:     disk system:       file_systems/bfs/v1
KERN:     name:              <NULL>
KERN:     content name:      Haiku
KERN:     type:              Be File System
KERN:     content type:      Be File System
KERN:     params:            type = 235 ; active = 1
KERN: device 1: /dev/disk/scsi/0/1/0/raw
KERN:   media status:      No media present
KERN:   device flags:      5
KERN: Identified boot partition by partition offset.
KERN: vpd_page_get:
KERN: vpd_page_get:
KERN: vpd_page_get:
KERN: vpd_page_get:
KERN: bfs: mounted "Haiku" (root node at 524288, device = /dev/disk/scsi/0/0/0/0)
KERN: Mounted boot partition: /dev/disk/scsi/0/0/0/0
KERN: unknown: [25058640:    15] Adding packages from "/boot/system/packages"
KERN: unknown: [25059724:    15] Failed to open packages activation file: No such file or directory
KERN: unknown: [25060810:    15] Loading packages from activation file failed. Loading all packages in packages directory.
KERN: slab memory manager: created area 0xffffffff95801000 (276)
KERN: slab memory manager: created area 0xffffffff96001000 (277)
KERN: unknown: [25303256:    15] StringPool usage:
KERN: unknown: [25303767:    15]   total unique strings:       24769,   437283 bytes, overhead: 396304 bytes + 262144 bytes
KERN: unknown: [25305060:    15]   total strings with dups:   130167,  1738197 bytes
KERN: unknown: [25305947:    15]   unshared strings:            1150
KERN: unknown: [25306618:    15]   bytes saved:               642466
KERN: unknown: [25308401:    15] Adding packages from "/boot/home/config/packages"
KERN: unknown: [25309451:    15] Failed to open packages activation file: No such file or directory
KERN: unknown: [25310459:    15] Loading packages from activation file failed. Loading all packages in packages directory.
KERN: unknown: [25313244:    15] StringPool usage:
KERN: unknown: [25313736:    15]   total unique strings:       24769,   437283 bytes, overhead: 396304 bytes + 262144 bytes
KERN: unknown: [25314994:    15]   total strings with dups:   130178,  1738262 bytes
KERN: unknown: [25315840:    15]   unshared strings:            1146
KERN: unknown: [25316523:    15]   bytes saved:               642531
KERN: module: Search for file_cache/launch_speedup/v1 failed.
KERN: smbios_scan
KERN: found System Information at 0xffffffff950f1c4b
KERN: found vendor 1 product 2
KERN: smbios_scan found vendor QEMU product Standard PC (Q35 + ICH9, 2009)
KERN: publish device: node 0xffffffff95292020, path disk/virtual/ram/control, module drivers/disk/virtual/ram_disk/control/device_v1
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/zero
KERN: usb_modeswitch: init_hardware()
KERN: usb_modeswitch: init_driver()
KERN: usb_modeswitch: trying module bus_managers/usb/v3.1
KERN: usb_modeswitch: publish_devices()
KERN: usb_modeswitch: uninit_driver()
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/usb_modeswitch
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/tty
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/null
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/dprintf
KERN: con_init: trying module console/frame_buffer/v1
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/console
KERN: mtrr: [cpu 1] MTRRs are enabled
KERN: mtrr: [cpu 1] default type is 6 write-back
KERN: mtrr: [cpu 1] fixed range MTRRs are enabled
KERN: mtrr: [cpu 1] 0: base: 0xc0000000; length: 0x40000000; type: 0 uncacheable
KERN: ignoring MTRRs due to PAT support
KERN: allocate_commpage_entry(4, 16) -> 0x0000000000000258
KERN: no valid cpufreq module found
KERN: no valid cpuidle module found
KERN: kernel debugger extension "debugger/run_on_exit/v1": loaded
KERN: kernel debugger extension "debugger/usb_keyboard/v1": loaded
KERN: kernel debugger extension "debugger/invalidate_on_exit/v1": loaded
KERN: kernel debugger extension "debugger/hangman/v1": loaded
KERN: kernel debugger extension "debugger/disasm/v1": loaded
KERN: publish device: node 0xffffffff8206d0c0, path random, module bus_managers/random/device_v1
KERN: publish device: node 0xffffffff8206d0c0, path urandom, module bus_managers/random/device_v1
KERN: publish device: node 0xffffffff82074e88, path power/button/power_fixed, module driverKERN: s/power/acpi_button/device_v1
KERN: register_domain(9, unix)
KERN: package_daemon: [25935862:    41] root at "/boot" (device: 3, node: 524288) registered
KERN: package_daemon: [25936840:    41] volume at "/boot/system" registered
KERN: package_daemon: [25937680:    41] volume at "/boot/home/config" registered
KERN: register_domain(5, internet6)
KERN: register_domain(1, internet)
KERN: unregister_domain(0xffffffff95e47400, 9, unix)
KERN: unregister_domain(0xffffffff95e47280, 1, internet)
KERN: unregister_domain(0xffffffff95e47300, 5, internet6)
KERN: unregister_domain(0xffffffff95e47280, 5, internet6)
KERN: register_domain(4, link)
KERN: unregister_domain(0xffffffff95e47280, 4, link)
KERN: unregister_domain(0xffffffff95e47000, 1, internet)
KERN: unregister_domain(0xffffffff95e47480, 5, internet6)
KERN: unregister_domain(0xffffffff95e47000, 5, internet6)
KERN: Test: and [file_exists [/system/bin/FirstBootPrompt], or [not [file_exists [/boot/home/config/settings/Locale settings]], readonly ]] -> 0
KERN: slab memory manager: created area 0xffffffff96801000 (4948)
KERN: unregister_domain(0xffffffff95e47400, 1, internet)
KERN: unregister_domain(0xffffffff95cbfe80, 9, unix)
KERN: unregister_domain(0xffffffff95cbfd80, 1, internet)
KERN: unregister_domain(0xffffffff95cbfe00, 5, internet6)
KERN: unregister_domain(0xffffffff95cbfd80, 5, internet6)
KERN: publish device: node 0xffffffff95cb9798, path net/virtio/0, module drivers/network/virtio_net/device_v1
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/net/usb_rndis
KERN: usb_davicom:00.26.307:init_driver::ver.0.9.5
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/net/usb_davicom
KERN: usb_asix:00.26.311:init_driver::ver.0.10.1
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/net/usb_asix
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/net/pegasus
KERN: etherpci: init_driver init_driver: etherpci not found
KERN: unregister_domain(0xffffffff95f4c380, 9, unix)
KERN: unregister_domain(0xffffffff95f4c280, 1, internet)
KERN: unregister_domain(0xffffffff95f4c300, 5, internet6)
KERN: unregister_domain(0xffffffff95f4c280, 5, internet6)
KERN: unregister_domain(0xffffffff95f4c300, 9, unix)
KERN: unregister_domain(0xffffffff95e47700, 1, internet)
KERN: unregister_domain(0xffffffff95f4c380, 5, internet6)
KERN: unregister_domain(0xffffffff95e47700, 5, internet6)
KERN: virtio_pci: using legacy interrupt 22
KERN: virtio_net: no mtu feature
KERN: virtio_net: ioctl: unknown message 2716
KERN: package_daemon: [26405459:    57] Failed to open packages activation file /boot/system/packages/administrative/activated-packages: No such file or directory
KERN: package_daemon: [26407968:    57] Failed to get activated packages info from activated packages file. Assuming all package files in package directory are activated.
KERN: package_daemon: [26409827:    57] The latest volume state is also the currently active one
KERN: package_daemon: [26410786:    57] Volume::InitialVerify((nil), (nil))
KERN: package_daemon: [26419334:    57] KERN: Volume::InitialVerify(): volume at "/boot/system" is consistent
KERN: package_daemon: [26420777:    57] Failed to open packages activation file /boot/home/config/packages/administrative/activated-packages: No such file or directory
KERN: package_daemon: [26422522:    57] Failed to get activated packages info from activated packages file. Assuming all package files in package directory are activated.
KERN: package_daemon: [26424314:    57] The latest volume state is also the currently active one
KERN: package_daemon: [26425340:    57] Volume::InitialVerify(0x118ad4066680, (nil))
KERN: package_daemon: [26427677:    57] Volume::InitialVerify(): volume at "/boot/home/config" is consistent
syslog part 2
AUTH 'sshd'[107]: error: setsockopt IPV6_V6ONLY: Operation not supported
AUTH 'sshd'[107]: Server listening on :: port 22.
AUTH 'sshd'[107]: Server listening on 0.0.0.0 port 22.
AUTH 'sshd'[107]: error: Couldn't create pid file "/packages/openssh-9.8p1-2/.self/var/run/sshd.pid": No such file or directory
KERN: radeon_hd: init_hardware
KERN: Radeon - init_hardware: Version: 5.1.6.0
KERN: Radeon - Radeon_CardDetect: no supported devices found
KERN: nvidia: CALLED init_hardware
KERN: nvidia: init_hardware: no supported device found
KERN: intel_extreme: CALLED status_t init_hardware()
KERN: devfs: "intel_810" api_version missing
KERN: i810: init_hardware() - no supported devices
KERN: ati: init_hardware() - no supported devices
KERN: vesa: init_hardware()
KERN: vesa: init_driver()
KERN: vesa: publish_devices()
KERN: vesa: find_device()
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/graphics/vesa
KERN: framebuffer: init_hardware()
KERN: assuming memory type 20000000 for overlapping 0xfd000000, 0x1000000 area 8037 from existing 0xfd000000, 0x12c000 area 138
KERN: vesa: vesa_init() completed successfully!
KERN: vesa: acc: vesa.accelerant
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/input/wacom
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/input/usb_hid
KERN: ps2_hid: init_hardware
KERN: ps2_hid: init_driver
KERN: ps2_hid: publish_devices
KERN: ps2_hid: uninit_driver
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/input/ps2_hid
USER: Notify of added/removed/started/stopped device
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/bus/usb_raw
KERN: sis7018:init_hardware:ver:2.0.2
KERN: loaded driver /boot/system/add-ons/kernel/drivers/dev/audio/hmulti/usb_audio
KERN: emuxki: init_hardware()
KERN: echo3g: init_hardware()
KERN: echo3g: no card found
KERN: auvia: init_hardware()
KERN: auich: init_hardware()
KERN: ALPS not supported: 10 00 64
KERN: ps2: probe_mouse Extended PS/2 mouse found
KERN: ps2: devfs_publish_device input/mouse/ps2/intelli_0, status = 0x00000000
KERN: ps2: devfs_publish_device input/keyboard/at/0, status = 0x00000000
KERN: ps2: keyboard found
DAEMON 'app_server': Application for user 0 does not support the current server protocol (0).
Last message repeated 7 times
AUTH 'sshd-session'[394]: Accepted password for user from 10.68.1.10 port 36668 ssh2
KERN: USER: User command requested kernel debugger.
KERN: Welcome to Kernel Debugging Land...
KERN: Thread 425 "kernel_debugger" running on CPU 0
EDIT: <<<< initial slabs report >>>>
KERN: slab memory manager: created area 0xffffffff98001000 (14991)
KERN: slab memory manager: created area 0xffffffff98801000 (26258)
KERN: slab memory manager: created area 0xffffffff99001000 (46147)
KERN: slab memory manager: created area 0xffffffff99801000 (428759)
KERN: slab memory manager: created area 0xffffffff9a001000 (1222485)
KERN: Thread 21323 "kernel_debugger" running on CPU 1
EDIT: <<<< first slabs report >>>>
KERN: libroot __mutex_unlock: mutex was not actually locked!
KERN: Thread 42883 "kernel_debugger" running on CPU 0
EDIT: <<<< This slabs report was made while all pings were running >>>>
KERN: kdebug> slabs
KERN: 0xffffffff82006000    block allocator: 16       16       16    57344      0     3276     3528 80000000
KERN: 0xffffffff820063a0    block allocator: 32       32       32   368640      0    11339    11340 80000000
KERN: 0xffffffff82006570    block allocator: 48       48        8   720896      0    14779    14784 80000000
KERN: 0xffffffff82006a80    block allocator: 96       96        8  3719168      0    38111    38136 80000000
KERN: 0xffffffff82006c30   block allocator: 112      112        8   233472      0     2029     2052 80000000
KERN: 0xffffffff82006de0   block allocator: 128      128      128   409600      0     3097     3100 80000000
KERN: 0xffffffff820081b0   block allocator: 192      192        8    77824      0      379      399 80000000
KERN: 0xffffffff82008360   block allocator: 224      224        8  1314816      7     2237     5778 80000000
KERN: 0xffffffff820086c0   block allocator: 320      320        8   159744      0      467      468 80000000
KERN: 0xffffffff82008c60   block allocator: 512      512      512   180224      0      326      352 80000000
KERN: 0xffffffff8200ae00   block allocator: 640      640        8   262144      0      340      408 80000000
KERN: 0xffffffff8200a600  block allocator: 1280     1280        8  2228224      2      558     1734 80000000
KERN: 0xffffffff8200a400  block allocator: 1536     1536        8    65536      0       30       42 80000000
KERN: 0xffffffff8200be00  block allocator: 2560     2560        8   327680      2       33      125 88000000
KERN: 0xffffffff8200b800  block allocator: 4096     4096     4096  4849664      5     1071     1184 88000000
KERN: 0xffffffff8200de00             cache refs       16        8   135168      0     3727     8316        0
KERN: 0xffffffff8200dc40            anon caches      232        8  1536000     28     1986     6375        0
KERN: 0xffffffff8200da80    anon no-swap caches      208        8   118784      0      537      551        0
KERN: 0xffffffff8200d8c0           vnode caches      232        8   311296      0     1277     1292        0
KERN: 0xffffffff8200d1c0  kernel address ranges       88        8    53248      0      548      585        0
KERN: 0xffffffff8200d000        page mappings 0       48        8  3014656      0    30348    62744 20000000
KERN: 0xffffffff82028e08        page mappings 1       48        8  3014656      0    30411    62744 20000000
KERN: 0xffffffff8200c200                threads     3520       64   851968      0      179      234        0
KERN: 0xffffffff823d9800    block cache buffers     4096        8  4194304      0     1022     1024 20000000
KERN: 0xffffffff95cb7a00       net buffer cache      360        8   405504     58      206     1089        0
KERN: 0xffffffff95bd7000        data node cache     2048        8  2555904     30       94     1248        0
KERN: kdebug> exit
KERN: slab memory manager: created area 0xffffffff9a801000 (3727802)
AUTH 'sshd-session'[396]: Received disconnect from 10.68.1.10 port 36668:11: disconnected by user
AUTH 'sshd-session'[396]: Disconnected from user user 10.68.1.10 port 36668
KERN: slab memory manager: created area 0xffffffff9b001000 (4312672)
KERN: slab memory manager: created area 0xffffffff9b801000 (10888357)
KERN: slab memory manager: created area 0xffffffff9c001000 (18751028)
KERN: slab memory manager: created area 0xffffffff9c801000 (26696754)
KERN: slab memory manager: created area 0xffffffff9d001000 (35526354)
KERN: slab memory manager: created area 0xffffffff9d801000 (41300605)
KERN: slab memory manager: created area 0xffffffff9e001000 (46519627)
KERN: slab memory manager: created area 0xffffffff9e801000 (54270001)
KERN: slab memory manager: created area 0xffffffff9f001000 (60459906)
KERN: slab memory manager: created area 0xffffffff9f801000 (68621831)
KERN: slab memory manager: created area 0xffffffffa0001000 (77732815)
KERN: slab memory manager: created area 0xffffffffa0801000 (83575853)
AUTH 'sshd-session'[1095244]: Accepted password for user from 10.68.1.10 port 59352 ssh2
KERN: Thread 1095978 "kernel_debugger" running on CPU 0
EDIT: <<<< last slabs report >>>>
AUTH 'sshd-session'[1096524]: Accepted password for user from 10.68.1.10 port 57220 ssh2
Well, there’s one rather obvious difference in here:
-KERN: 0xffffffff82006a80    block allocator: 96       96        8  1851392      0    18973    18984 80000000
+KERN: 0xffffffff82006a80    block allocator: 96       96        8 94969856      0   973809   973812 80000000
That’s ~1.8MB of usage before running the pings, and then ~90.6MB of usage after. So that looks like where the leak is probably occurring. I’ll see if I can track it further.
Tracked down and fixed at least that memory leak in hrev58483. Let me know how things look after that.
Excellent! I’ll give it a go when it shows up in the nightlies!
Seems stable now (hrev 58485). kernel_team starts at 85MiB after boot, jumps to ±108MiB while pinging, drops to ±104MiB when all the pinging is stopped, back up to ±108, back down to ±104.
[Aside, should I post individual observations in separate threads?]
N
